Garmin GPS and Center Console - 8th Generation Honda Civic Forum
Old 12-09-2008, 11:04 PM   #1 (permalink)
Hey everyone,
Was wondering if anybody out there has tried to install a GPS unit right over the vent and radio in the new Civics versus the windshield. Also, is it possible to install a power port right about the radio so that a wire doesn't have to run down over the center console? There is a mini USB power connection so thinking about a possible mini USB port with mini USB to mini USB wire, but then there is the whole right amount of volts issue.
ArDarsh is offline
Old 12-09-2008, 11:16 PM   #2 (permalink)
msjwild3's Avatar
Ryan
Just mount it here. This is what I did.
msjwild3 is offline   Reply With Quote
Old 12-10-2008, 05:46 PM   #3 (permalink)
mugenh22a's Avatar
i have my mounted almost like MSJWILD's but i have it mounted in the cubby hole above that. Just use the adhesive disc and the suction mount... works great!
mugenh22a is offline   Reply With Quote
Old 12-11-2008, 07:53 PM   #4 (permalink)
Yah,thats a cool spot to mount it, i had it there for a while in the pocket. But really its a little bit dangerous. because you have to look down to see the screen.
pks17 is offline   Reply With Quote
Old 12-11-2008, 09:22 PM   #5 (permalink)
Here is sort of my concept
I have attached a concept image. Certainly not a piece of art but I think it conveys my idea. I assume the mount part is easy. It's all about the power cord so I don't have some big chunky wire dangling down across the center console. Looking for a clean look, if possible.
ArDarsh is offline   Reply With Quote
Old 12-11-2008, 09:44 PM   #6 (permalink)
[hwy]Hagen's Avatar
#1 Booty-Shaker
i dont have time to show you my set up directly but here is my placement.
i will show you in detail tomorrow.
[hwy]Hagen is online now   Reply With Quote
Old 12-12-2008, 04:07 AM   #7 (permalink)
To hide the wire, just put the AC power cord into your outlet in the center console armrest, then run it under the center console to where ever you mount the gps unit. Simple, but might take a little bit of elbow work. Depending on where you mount it, you might not be able to totally hide wires. Thats why the oem unit is nav is the best.
Old 12-15-2008, 01:16 PM   #8 (permalink)
[hwy]Hagen's Avatar
#1 Booty-Shaker
This is what i did:
Old 12-22-2008, 10:54 AM   #9 (permalink)
IceMurder's Avatar
Chris
ran the wire down the weather stripping and under the dash to the center armrest 12v plug
IceMurder is offline   Reply With Quote
Old 12-26-2008, 03:02 AM   #10 (permalink)
08taffetawhite's Avatar
i suction cupped mine the the small window.. looks nice and you can hardwire!
08taffetawhite is offline   Reply With Quote
Old 12-30-2008, 12:57 AM   #11 (permalink)
this is exactly what i did although not a garimn it's the same thing.
Sle.simon is offline   Reply With Quote
Old 12-30-2008, 01:05 AM   #12 (permalink)
this is mine
Gitrdone42 is offline   Reply With Quote
Old 12-30-2008, 04:52 PM   #13 (permalink)
Victor
I must say, Gitrdone42's setup looks really nice, and not to mention clean. How do you have your wires setup?
azianjustice is offline   Reply With Quote
Old 12-30-2008, 04:56 PM   #14 (permalink)
Mitch's Avatar
Mitch
That small window is a really neat place to mount. I've got mine mounted like IceMurder. I'm planning on hardwiring it some time in the next month.
Mitch is offline   Reply With Quote
Old 12-30-2008, 10:00 PM   #15 (permalink)
I just have mine ran down through the weather stripping and under the dash, it comes back out right under the power point.
I will get a few more pics of the actual wiring
down the door sill
Coming out from the dash
and just another pic
Old 01-10-2009, 02:27 AM   #16 (permalink)
itrgtr's Avatar
the small window is the perfect spot! originally had it in the middle of the windshield but it wasn't a great spot. ended up moving it on the small window as well. it's a pretty good location, wires are out of the way, and less conspicuous from the outside if you have tints
itrgtr is offline   Reply With Quote
Old 01-11-2009, 06:47 PM   #17 (permalink)
I remember on my trip to california, the suction came loose at least 5 times there and back. That was pretty annoying.
also, does it stick to tinted windows?
Old 01-11-2009, 06:53 PM   #18 (permalink)
JFunkLBC's Avatar
johnny
this is exactly what i did with mines. GOOD JOB!
JFunkLBC is offline   Reply With Quote
Old 01-11-2009, 06:58 PM   #19 (permalink)
Admin Ninja
obert's Avatar
obert
Here is mine,I ran the wire down the side and under the dash to the power point.
Old 01-11-2009, 07:05 PM   #20 (permalink)
JFunkLBC's Avatar
johnny
instead of putting the wire behind the consoles and crap. i just let mines dangle under the steering wheel towards the 12v. i just figured i might need to use my garmin on the another car. maybe i'll just buy another cable. instead of having the gps like the one ^^^ up there. i pushed mines more down towards the speeometer console towards the left side =]
DIY: GPS Mount - Center Console (56K go take a walk) Berto Civic Coupe And Sedan 6 03-30-2008 11:46 AM
Anyone Have a Garmin Gps? dbrownk20 Technology 13 12-26-2007 07:00 PM
Garmin StreetPilot Portable GPS Keenyol Technology 0 04-05-2007 02:01 AM
