#2 (permalink) | |
Webby's Minion
The recommended psi is stated both in the car's manual and along the sill of the driver's door. You should follow the recommended pressure. On the Civic sedan, the recommended tire pressure is 32 psi. Never use tire's maximum pressure (unless it's lower than the car manufacturer's recommended pressure) and never go below the recommended pressure stated by your vehicle. This is assuming that you are using the car's recommended tire size for the stock wheels.
Webby's Minion
Yup, the recommended pressure should apply to all tires. There are certain cases where you will want to either lower or add pressure to your tires, but if you partake in those certain activities, then you already know how much to add or reduce.
If you have low profile tires (i.e. 40 series, etc.) then remember to check your tire pressure with a tire pressure gauge more often. It's harder to tell if your slim tires are below pressure simply by looking at them or by doing the old (and very inaccurate) tire kick test. And btw, go by the auto parts store and buy yourself a tire pressure gauge if you haven't already done so. They'll run you a few bucks, but are much more accurate than the tire pressure gauge attached at the end of the air nozzle at the gas station. Forget about the digital gauges...not worth the extra $20 to $60. Get the analog kind...you won't have to ever worry if the batteries run out on analog gauges. |
#7 (permalink) | |
#10 (permalink) | |
I really like the kind with a dial, they are more accurate than the ones that are shaped like a pen, but they usually run a few bucks more |
#11 (permalink) |
all jap cars said they run 7psi. so when i race i make sure they are around that. you can tell the car has more acceleration this way because you can barely keep it on the road.
i use a bicycle pump to put them back to proper inflation. no gauge needed.....36.75 pumps looks and feels good. |
#13 (permalink) | |
#14 (permalink) | |
#15 (permalink) | |
| How important can Rims and Tires Be? | civicnation06 | Wheel And Tire Upgrades | 5 | 07-05-2006 04:34 PM |
| Tires, tires, tires......need some help! | aznives3 | Wheel And Tire Upgrades | 16 | 06-28-2006 10:31 PM |
| Dammit... why did they add summer tires??? | Kabs | Wheel And Tire Upgrades | 9 | 02-24-2006 02:09 AM |
