Ken
I got down to the step where you just pull the intake manifold off and it hits on the left side where the belt tensioner is. I tried every angle to get it off and I couldnt so i ended up putting it back togeather last night. Anyone that has done this mod please help me out, thanks.
Its a Si (course i dont think the IMG is out for the other cars) |
#2 (permalink) | |
#4 (permalink) | |
Ken
For more info go here http://www.hondata.com/heatshieldgasket.html |
#9 (permalink) | |
Mike C.
Well, buddy I know exactly the problem that you're having. What I did was took a big pry bar and pried it out and upward. The only problem with this is...that you might end up messing up the bolt threads. Make sure that you're very careful. At first I almost gave up putting this **** in also bro without taking everything apart. Hope this helps and goodluck! |
#12 (permalink) | |
yeah and it helps HOW? that little thing won't drop the temp by too much i don't think... I've had one on my tiburon v6 and it was at least half inch thick... now THAT is a intake manifold "SPACER" this is just simply a gasket... which means it won't be as good as having the spacer |
#13 (permalink) |
That is a good write up. I removed everything and the one bolt below, I think it helped. I then tilted it clock-wise and up and it came out. Then I grabbed the gasket and sliced the tip of my finger. Blood spilled all over and I fainted (just kidding about fainting). The only other thing I did wrong was tear the gasket on the TB. I need to replace it I suppose?
#14 (permalink) | |
#15 (permalink) | |
Ken
#16 (permalink) | |
Silly rabbits. Paying $60 for a name. I paid $26 for the same exact thing.
#17 (permalink) | |
It's not supposed to be a "spacer". It's an alternative to the metal gasket. Made of a special material (i.e. not plastic), it reduces intake temperatures by reducing heat transfer. In other words....metal conducts heat. THIS, does not..... |
#19 (permalink) | |
Do share. |
LinkBack to this Thread: http://www.8thcivic.com/forums/do-yourself-articles/12593-about-hondata-img.html
| ? about Hondata IMG - 8th Generation Honda Civic Forum | This thread | Refback | 01-03-2008 03:49 AM | |
| 33whp and 30wtq from hondata reflash and DCRH!! | 06redsi | Civic SI | 165 | 03-28-2009 01:21 AM |
| Hondata Reflash | Tim | CorSport | 14 | 07-26-2006 11:29 PM |
| My SI with Fujita SRI and Hondata IMG | Snoppy | Civic SI | 10 | 07-19-2006 02:48 AM |
| IMG install?!? | SonicK20Z | Intake & Spacer Discussion | 1 | 06-21-2006 06:45 PM |
| Hondata almost there!!!!!!!!!!! | Ep3racer954 | Civic SI | 9 | 02-20-2006 06:23 PM |
