? about Hondata IMG - Page 2 - 8th Generation Honda Civic Forum
Old 08-16-2006, 11:31 PM   1 links from elsewhere to this Post. Click to view. #21 (permalink)
mishima8's Avatar
Originally Posted by 60103
allright just finished installing mine, took me about 2 hours. I just took the stud out, figured it was the safest thing to do. I also did the throttle body coolant bypass also.
I didn't do this, I wasn't sure how to do it. Is there a write up? I also didn't relocate the ground, is there a REAL reason to relocate it? Thanks!
mishima8 is offline   Reply With Quote
Old 08-17-2006, 03:13 PM   #22 (permalink)
60103's Avatar
Ken
im guessing your asking about the coolant bypass, ill take a pic so you can see what you have to do.
relocating the ground i would assume is bc your taking out the metal gasket which help grounding from the manifold to the block, but theres 2 studs and 6 bolts to do that, so i dont see the point.
60103 is offline   Reply With Quote
Old 08-17-2006, 03:20 PM   #23 (permalink)
mishima8's Avatar
Cool, it would be much appreciated. I am doing some more work on the car this weekend and can probably combine things. Thanks!!!!
Old 08-17-2006, 03:33 PM   #24 (permalink)
60103's Avatar
Ken
Throttle Body Coolant ByPass
take both hoses off the bottom of the TB:
remove the shorter hose completely, and run the longer hose to where you took the shorter one off of:
here are a couple pics to see exactly where it is:
Old 08-17-2006, 04:20 PM   #25 (permalink)
mishima8's Avatar
I think I got it. I will try it this weekend. Appreciate it.
LinkBack to this Thread: http://www.8thcivic.com/forums/do-yourself-articles/12593-about-hondata-img.html
? about Hondata IMG - 8th Generation Honda Civic Forum This thread Refback 01-03-2008 03:49 AM
33whp and 30wtq from hondata reflash and DCRH!! 06redsi Civic SI 165 03-28-2009 01:21 AM
Hondata Reflash Tim CorSport 14 07-26-2006 11:29 PM
My SI with Fujita SRI and Hondata IMG Snoppy Civic SI 10 07-19-2006 02:48 AM
IMG install?!? SonicK20Z Intake & Spacer Discussion 1 06-21-2006 06:45 PM
Hondata almost there!!!!!!!!!!! Ep3racer954 Civic SI 9 02-20-2006 06:23 PM
