Rear speaker mounts - 8th Generation Honda Civic Forum
Old 08-07-2006, 01:01 PM   #1 (permalink)
Rear speaker mounts
I took out the rear speakers in my LX sedan and attempted to put in some 6.5" Pioneer speakers, but it looks like i'm going to have trouble getting them to mount correctly. The stock speakers have some special clips and appear to sit up a little from the frame. They also only use 1 screw. What's the best way to mount my Pioneers? I already read the rear speaker install tutorial in the Audio Forum, which clearly explained how to remove the stocks, but does not go into how to actually mount aftermarket speakers. Thanks in advance for your help.
JHemperly is offline
Old 08-07-2006, 01:46 PM   #2 (permalink)
moxom's Avatar
2 solutions:
A. buy 1" spacers rings and mount your speakers to said rings.
B. Gut out the current speakers and leave the outer frame which you would then mount your speakers to.
moxom is offline   Reply With Quote
Old 08-07-2006, 05:42 PM   #3 (permalink)
The original frame has the speaker cone glued to it. Would it be easy to just cut the speaker out and put the new one in it, or is there more to it than that? I also don't want to rip out the stock speaker cones if i don't have to.
Spacer rings might be an option, but i don't know where i'd put the other 2 screws, since the original speaker used 1 screw.
JHemperly is offline   Reply With Quote
Old 08-07-2006, 07:03 PM   #4 (permalink)
I just replaced all the speakers in my car last weekend.
I used 1" spacer rings for the rear deck and doors for my 6.5" speakers. Just pop out the stock speakers drill 4 holes to mount your spacer ring. Bolt it up screw in your speakers and your good to go.
My rears were Coaxial's that stuck up a bit higher than normal I had to trim the ring down to 3/4" and trim off the extra plastic on the grill. I also had to trim off the extra plastic in the front door panels.
Mobieus is offline   Reply With Quote
2006 Civic Rear Speaker Install Guide webby Audio 36 10-18-2011 09:12 PM
noise from rear... hfp suspension and progress rear sway bar rippars Mechanical Problems & Technical Chat 8 07-01-2008 09:42 PM
Rear Disk Brakes Noise ONEtdiddy Mechanical Problems & Technical Chat 9 06-02-2006 01:43 PM
Has anybody removed the rear speaker tray on a coupe? galaxycivic Do It Yourself Articles 6 05-20-2006 01:21 AM
Rear Speaker Install Guide brolewis I.C.E., Electrical, Security, & Navigation 7 12-29-2005 12:53 AM
