The McGyver ofall McGyves
![]() Join Date: Jun 2007
Thats Mr. Bart Koscow to YOU!
DIY: Fog Light lenses, plastic and glass
ok lets bigin... these are made from 1/8th inch plastic, although i'd preffer to use 1/4, some think its over kill, and un nessasary, i have bolth, we;ll all the way up to one inch thick... anyway...
this is the trace i took off my stock ones, cov3red in my taking apart and cleaning/ resealing foglights DIY...( fog no more... fixing fog light condensation ) cover your plastic in masking tape to protect it... and mark the patern off... ![]() I happen to have a tabe saw, so i used that to cut them to side, it took about 3min. per lense... ![]() *CUT* ![]() ![]() ![]() ![]() then you need to sand them so there isnt sny marker left... ![]() ![]() DONE!!!, that was easy... ![]() Now to try it with glass..., clean the glass with some glass cleaner and brake clean... but first... LOOK NO CUTS YET... ![]() now clean it with ass cleaner, i mena glass cleaner... ![]() mark off the pattern with a shapie ![]() when cutting clss you need to use cutting out.... this ke3eps the blade lubed... basicly it keeps the score line clean keeps the blade from hitting dirt/dust and jumping... ![]() and!!! ![]() DISASTER!!!, the blade was a dud, so i moved the tip to blade?2(it has 5 posable...) i tried on a few more pieced, but the glass was too thin..., so on the weekend i will do it with a thicker piece... for now...
#10 (permalink) |
HAY... where did you put that 1/8th inch stuff???
that i got from adrian? i want to cut them and tint them with the mirror stuff... |
| Need quick help! FOG Light Lenses | gui | Lighting, H.I.D.'s, & Neon | 18 | 07-03-2008 12:50 AM |
| Anyone Willing to make me 2-4 Fog Light lenses? | CivicCoupe06 | Lighting, H.I.D.'s, & Neon | 32 | 06-19-2008 09:04 PM |
| Is there oem yellow fog light lenses? | augydog | Lighting, H.I.D.'s, & Neon | 6 | 08-06-2006 07:32 PM |
