Old 07-22-2008, 02:52 AM   #1 (permalink)
Help from Helm manual owners: torque specs
Need some help from helm manual owners for my 08 LX coupe 1.8 5spd...
Would you be so kind to look up a few torque specs for me.
Drain bolt for engine oil pan
Oil filter for engine
Manual transmission filler bolt
Manual transmission drain bolt
Thank you!
JT-KGY is offline   Reply With Quote
Old 07-22-2008, 03:10 AM   #2 (permalink)
mad monkey's Avatar
Jeremy
Good and tight for all of them. Seriously. The oil filter is not supposed to be torqued by any tool. It should be hand tightened. The drain bolt should be snugged to what you think is tight enough for it to not work itself back out. It see no pressure. Same with the tranny filler bolt and drain bolt. They see no pressure, the torque needed is not alot. The tension would be just the same for the oil drain bolt. I have the manual so don't think I'm trying to be some sarcastic ass. I'm serious...
mad monkey is offline   Reply With Quote
Old 07-22-2008, 03:14 AM   #3 (permalink)
I understand... and I know a lot of trained mechanics do the exact samething.
But I figured that I have torque wrenches (in fact, 3 of them), might as well
find out the correct torque spec to do it for peace of mind...
Old 07-23-2008, 01:59 AM   #4 (permalink)
anyone?
Old 07-23-2008, 03:08 AM   #5 (permalink)
mad monkey's Avatar
Jeremy
ok ok... here you go...
Oil filter = hand tight (and I really don't know how you'd get a torque wrench up there anyway)
Oil drain bolt = 39Nm/29 Ft-lbs
Tranny filler bolt = 44Nm/33 Ft-lbs
Tranny drain bolt = 39Nm/29 Ft-lbs
Old 07-23-2008, 03:11 AM   #6 (permalink)
Thank you thank you!! much appreciated!!!
for oil filter.. usually I use the filter wrench then turn it using the correct
sized torque wrench
Old 07-23-2008, 03:21 AM   #7 (permalink)
mad monkey's Avatar
Jeremy
lol... well all is good then
Tech question about stock numbers....helm manual owners... beans Bolt-Ons And All-Motor 7 12-11-2007 07:46 PM
New Helm Service Manual $135 BigMoney8481 Mechanical Problems & Technical Chat 17 11-08-2007 08:43 AM
Helm Manual price raise? SiConvert887 Bolt-Ons And All-Motor 2 11-01-2007 04:31 PM
Does anyone have the HELM manual for the Si/Coupe? skittleslegend I.C.E., Electrical, Security, & Navigation 0 10-14-2006 11:14 PM
HELM manual available for 2006 Civic Si skittleslegend Civic SI 9 04-19-2006 01:29 AM
