Old 07-05-2008, 08:44 PM   #1 (permalink)
Removing airbag question please help
i wish to install steering audio control and therefore need to remove my airbag. Can i just unplug the black and yellow connector instead of pulling the negative from the battery terminal as i do not wish to reset ECU. Is there a proper sequence whereby i have to unplug black connector first followed by yellow or just unplug any connector first will do. Greatly appreciated.
tanwn is offline   Reply With Quote
Old 07-05-2008, 08:44 PM   #2 (permalink)
NIGHTHAWKSI's Avatar
Ian
disconnect the battery to be safe.
Old 07-05-2008, 08:49 PM   #3 (permalink)
BlackOut070's Avatar
No more f*ckin black Civics!!!
Disconnect the negative from the battery and wait 10 seconds for it to discharge. Then remove your airbag cover and the connectors. Removing the connections before hand could set the bag off by accident, and you really don't want that shit shooting you in the face at like 100 mph.
BlackOut070 is online now   Reply With Quote
Old 07-05-2008, 08:50 PM   #4 (permalink)
Ian
and then having to replace your airbag $$$$$$$$
Old 07-05-2008, 08:52 PM   #5 (permalink)
...and every broken bone in your face. But don't worry, as long as the battery is disconnected you should be good.
edit: Ian, we gotta stop before we scare this kid lol.
Old 07-05-2008, 08:55 PM   #6 (permalink)
but what's the difference if i pull the black connector on airbag instead? Isn't it the negative terminal also? Please correct me if i'm wrong.
Old 07-05-2008, 08:56 PM   #7 (permalink)
Ian
because it takes about 30 seconds more to do it the right way and remove the negative terminal.
but hey, if that 30 second job is worth the posssabilty of having an airbag go off....good luck
Old 07-05-2008, 08:57 PM   #8 (permalink)
Yea, that would be the negative, but say for some odd reason, a spark jumps or something, that bag is going off. Have you ever seen one go off before?
Old 07-05-2008, 08:59 PM   #9 (permalink)
so i have no choice but to remove the battery negative terminal. so did you guys do the ecu reset afterwards. thanks again
Old 07-05-2008, 09:01 PM   #10 (permalink)
It should reset itself when your turn the car back on.
Oh yea, get your radio code just incase also.
Old 07-05-2008, 09:35 PM   #11 (permalink)
fg2!kid's Avatar
エリク eric
nope its 3 min not 10 or 30 sec
fg2!kid is offline   Reply With Quote
Old 07-06-2008, 01:06 AM   #12 (permalink)
Why are you so worried about the ECU getting reset???
Old 07-06-2008, 04:09 AM   #13 (permalink)
When I was working for Chrysler, that's what it was. Every car is different, as we all know. I was just going off that experience.
Old 07-23-2008, 01:14 PM   #14 (permalink)
i also removed the bag for the audio control mods. i need to align the steering wheel, and getting sick of putting ht ebag in every time. can i drive without the bag? will it screw anything up when i put it back in?
rraabb11 is offline   Reply With Quote
Old 07-24-2008, 08:14 AM   #15 (permalink)
the answer is yes, nothing gets messed up.
Removing LEV, Airbag Stickers? RCKola1011 Inside and Out 5 05-04-2008 12:20 PM
Crashed Si, airbag light ON, no airbag poped out...PICS nevarez_ga Mechanical Problems & Technical Chat 7 05-29-2007 08:49 PM
Re: Airbag Rahm$9 Inside and Out 7 03-27-2007 04:37 PM
Passanger Airbag Light (PS airbag off) djdefcon Civic SI 9 11-03-2006 07:10 PM
Passenger Airbag Off/Airbag Warning Light Ryouko Mechanical Problems & Technical Chat 10 12-28-2005 08:30 PM
