Yea i noticed that the K&N gives you that neat little side box, hell i may just get that one..... i found it for 275, know anyplace else thats cheaper, for a intake i really dont think it matters all that much which brand but I do what to know if i could keep the lower part of the air box or the tube that takes air in
![]() ![]() Join Date: May 2007
Wild VTEC'n Bill
Water will not be an issue whether the base is left in or removed. Personally, I would keep the base in place for two reasons: First, it acts as a partial barrier to heat rising up the header and exhaust. Secondly, with the base left in place along with the cold air tube, a very tiny amount of cooler air will be directed towards the filter. Not much, but better than nothing. Ideally, a filter should be enclosed in an airbox to completely isolate it from heat and to provide a vacuum to which cooler air can be pulled in. This is how the factory cold air works, and in a much greater way, how ram air and cowl induction work. OP. l suggest leaving the base in place.
| Inejn short ram or cold air intake???? | Endo07si | Bolt-Ons And All-Motor | 46 | 07-02-2009 04:14 AM |
| Is the air intake box noisy? | Robotaz | Garage | 3 | 06-11-2008 09:34 PM |
| Putting stock Air Box (intake) back on? DIY? | asdf | Bolt-Ons And All-Motor | 18 | 03-29-2008 09:37 PM |
