Old 06-21-2008, 12:08 PM   #1 (permalink)
Lockout Key Blank?
Been to two honda dealerships and three locksmiths trying to get a simple, no transponder "Lockout Key" cut.
What I need is a couple of hideable "key only" (no electronics, no transponder) so that in the event that I lock the key in the car (it's possible) I can simply open the door.
Can anyone point to a "no transponder" key blank I can ask a locksmith for?
2008 Honda Civic Hybrid
Thanks in advance,
Beverly Howard
bevhoward is offline   Reply With Quote
Old 06-21-2008, 12:33 PM   #2 (permalink)
MurderedCivic's Avatar
are you talkin about just a plain key? because when i got my keys i got two electronic keys and one plain and simple key.
MurderedCivic is offline   Reply With Quote
Old 06-21-2008, 12:35 PM   #3 (permalink)
I think what he's saying is that even your "plain and simple key" (the valet key) can start the car, as it DOES have the immobilizer transponder etc. What he wants is just the blank to unlock the car, and not be able to start it.
perral1 is offline   Reply With Quote
Old 06-22-2008, 06:31 PM   #4 (permalink)
Bingo... couldn't have said it better myself.
At this point, _any_ alternative (non honda) spare key options for the 2008 civic would be of interest.
Beverly Howard
Old 06-22-2008, 06:37 PM   #5 (permalink)
WhiTe~Si~'s Avatar
Reaz
i heard if you get locked out your car, you can use your cell phone to call someone from home and they can put the spare key to the phone an you put your phone to the car door and they press the unlock button it will open...i haven't tried this tho
WhiTe~Si~ is offline   Reply With Quote
Old 06-22-2008, 06:48 PM   #6 (permalink)
Originally Posted by WhiTe~Si~ View Post
you can use your cell phone...
snopes time ;-)
snopes.com: Remote Possibility
At these key difficulties and prices, I may do what I have done a few times in the past... locate the door unlock line and install a hidden pushbutton somewhere.
Beverly Howard
Old 06-22-2008, 06:53 PM   #7 (permalink)
''CA'' All day.
Zeuceone's Avatar
Gertrude
not possibl.
Originally Posted by bizzybearfigiblue View Post
u like da wafflez???
Old 06-22-2008, 07:04 PM   #8 (permalink)
WhiTe~Si~'s Avatar
Reaz
Originally Posted by Zeuceone View Post
not possibl.
is it ? i never tried it , have you done it and hasn't worked?
Old 06-22-2008, 07:14 PM   #9 (permalink)
Blktrax's Avatar
Adam
You just need a Key Blade,
We have them at our dealership; its the metal part of the key and no handle.
Basicly used to test the cutting machine. We use them for people that do exactly what youre talking about. Locked the keys in the trunk or car without the expese of a whole new key/imobilizer/and programming.
Simply put, if they wont sell you one of those just have them cut a vallet key, like $15 bucks, and just tell them you dont want it programmed.
Blktrax is offline   Reply With Quote
Old 06-22-2008, 08:05 PM   #10 (permalink)
asndragonboii's Avatar
I got my key at a lock smith. I think it cost ~$20. It's just the metal. Nothing else, no transponder thing, nothing, just the metal key.. I keep it in my wallet incase i lock my keys in my trunk (again).
Thats why i wanted it just the metal key, so it can fit in my wallet with minimal bulge.
Old 06-22-2008, 09:05 PM   #11 (permalink)
furryferret7888's Avatar
kris
sora uses them all the time
furryferret7888 is offline   Reply With Quote
Old 06-22-2008, 11:47 PM   #12 (permalink)
Good info to go in with... thanks.
As mentioned, shortly after we got the car (late January) went to two local dealers (Austin/Round Rock, TX) and neither had blanks plus, both didn't seem to know what any key would cost... "somewhere between $50 and $125" (wierd)
Beverly Howard
Old 06-23-2008, 09:20 AM   #13 (permalink)
Beverly Howard
If you get it copied at a lock smith, make sure you let them copy the one with the key fob so you can get into the trunk. If you make a copy of the valet, it wont be able to open the trunk.... If you lock your trunk release like i do.
Old 06-24-2008, 03:27 PM   #14 (permalink)
rmfa's Avatar
Ronnie
This is BS. It does not work.
Old 06-27-2008, 10:04 AM   #15 (permalink)
Success... the dealer's the solution.
Success... and the dealer (Round Rock, TX Honda) now had the valet keys for reasonable ($17 _including_ programming) They, and the other dealership in the area, didn't have the 2008 keys when I started this quest.
Adding to the equation, it's almost a 100 mile round trip to the Round Rock dealer, which tends to limit simply "stopping by. I did stop at another Austin locksmith on the way there to get a key cut for my bike and asked about the honda key... $50 for a hardware key and $150 for a transponder key.
During the process, being told "Bring the car and _all_ keys in to get the keys programmed" it finally dawned on exactly what the "Key Programming" process probably is...
I had assumed that the "keys" were programmed to the car, but (duh!) I would now guess that each key simply has an rfid chip with a unique number and the "programming" process is to simply notify the car of the rfid of each acceptable key.
I assume that the computer programming process can't do this incrementally (i.e. "Car, add this key to your current list of approved keys") and the only way to add a key is to wipe the car's existing key list and enter a complete new list by sending a code to the computer to start detecting keys, then using every key to simulate starting the car to build a new list.
Thanks for everyone's help,
Beverly Howard
Old 01-05-2009, 01:42 AM   #16 (permalink)
raybyduhbay's Avatar
Ray
gotta love my compustar that has a window sensor that I can use to tap my secret patern of knocks on the windshield to unlock my car. =D
raybyduhbay is offline   Reply With Quote
Old 01-07-2009, 07:04 PM   #17 (permalink)
boosted:croc's Avatar
Justin
here is my walet key....im a locksmith and these are test blanks
boosted:croc is offline   Reply With Quote
Old 01-10-2009, 07:54 PM   #18 (permalink)
slowcoupe's Avatar
Montira
or you could call me or roadside assistance and we just use our lockout kit and either pop your trunk or unlock your doors from the inside. 8ths are fairly hard to get into though...but pulling the trunk latch has never failed.
slowcoupe is offline   Reply With Quote
blank home screen ryanjacobson 8thcivic.com Site Questions/ Problems 4 11-05-2007 11:59 PM
Blanks on a Blank SiC17 Movies & Music Reviews 0 08-04-2006 02:58 AM
Programming and Cutting Key Blank bskouby Do It Yourself Articles 3 04-06-2006 04:23 PM
Driving a Manual - lockout of 1st Gear tom.smykowski Garage 23 12-21-2005 08:51 AM
