Made hydrogen (HHO) in my garage DIY
Anyone else done this or thought about it to increase mpg?
If you google or search in youtube for "hydrogen hho" there are plenty of people supplementing their gasoline with hydrogen using a jar of water, claiming to get fantastic gas mileage. The HHO gas is basically sucked into your intake along with the usual air and you don't need as much petrol to run the engine is the way I understand it. So, since I have a 3000+ mile trip coming up in my Pilot (I have an '06 civic too) I was going to try it out. The curiosity finally got to me and I made some hydrogen in my garage! Video: S4021647.flv - Video - Photobucket - Video and Image Hosting The first design hardly worked at all and consisted of stainless steel cable wrapped around a plastic tube with holes in it, that had another short piece of cable inside: ![]() While I was looking for plastic zip ties at the store I picked up 2 stainless steel bathtub strainers at $1 each. I attached them back to back with the zip ties and plastic spacers in between. Wires were twisted onto each strainer and viola! Another hydrogen generator. This one produced MUCH more bubbling than the steel cable design and used a lot less metal. Ok, it's not installed in my car yet but it was fun just making bubbles!
You need to make a circuit *buy* that will trick the ecu into adjusting the AFR properly, otherwise it's gonna think, hey I'm running too clean, must pump more fuel into the mix, then your mileage goes for the crapper again.
I was looking into this. Keep us posted as to how it works out. Strainers.. nice! *off to the Dollar store* |
I'm not a mechanic or anything but I think that the MAF sensor will adjust the fuel automatically. I've read that having the feeder hose attach to the intake at the right spot is important.
And as for being dangerous it's not a hydrogen bomb but is combustable (just like gasoline, nitrous oxide, etc.) or it wouldn't work. Isn't it worth even investigating it to possibly get 20%-30% increase in mpg? I can't turn back now! I've already invested around $15 in this project!
#9 (permalink) | |
It does bubble pretty good but not as much as stacking a bunch of plates together like I see on youtube. Here's an example of what it SHOULD do, but I don't recommend lighting it like he does! ![]() |
#11 (permalink) | |
I'm sure there are patents for it. All owned by the oil companies
#13 (permalink) |
He died of an aneurysm. My neighbor up the street from me growing up died that way. So did Bruce Lee.
What you don't remember about him was that when he was alive he defrauded investors of money, lost a lawsuit to said investors, and refused to allow a PhD of Engineering to have a hands on review of his prototype. |
#19 (permalink) |
Repeat, there is no such thing as HHO. And there's nothing special about electrolysis [whcih yields H2 + O2, not "HHO"]. In the fifth grade we hooked 9 volt batteries to metal coils in a jar of water and did this. The problem is that for the system to actually produce additional power, one or more of the components in the system (engine, alternator, electrolysis apparatus) has to work in excess of 100% efficiency. Engines work around 25-35% efficiency, electrolysis has a theoretical limit of 92% efficiency (though in practice, it rarely exceeds 60%), and alternators operate in the sub 60% efficiency range.
| DIY: Integrate your battery-free garage door opener into your dash! | TigerDave | Electrical | 72 | 03-23-2009 11:34 PM |
| DIY - 007 Garage Door Opener | b0yd07 | Interior Style Mods | 56 | 02-09-2009 06:02 PM |
| Hydrogen/Nitrogen in tires? | whtdvl | Civic Coupe And Sedan | 37 | 07-28-2007 04:59 PM |
| Hydrogen powered Prius | Celcius | Garage | 5 | 02-07-2006 10:51 PM |
