DIY: 2nd GEAR GRIND FIX!!!!- Clutch Adjust - Page 8 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Honda Civic Do It Yourself Articles > DIY Honda Civic Transmission
Old 03-29-2010, 07:19 PM   #141 (permalink)
f2kboost's Avatar
Farooq
add me to the list...did the DIY this morning and just got back from an hour drive...def. felt a difference thanks AK!!
f2kboost is offline   Reply With Quote
Old 03-29-2010, 07:38 PM   #142 (permalink)
Kyle
I had a weird experience after powershifting from first to second. It didnt grind but after I let off the clutch, the power lagged then came back like my clutch was slipping but was fine after that. Im gonna turn the rod a little back. It was a weird experience and I hope my clutch is ok...
Galaxy Grey Si Coupe is offline   Reply With Quote
Old 03-29-2010, 07:52 PM   #143 (permalink)
08nightblacksi's Avatar
Kevin
i just did it and it seems fine but my engagement point seems like its sooner. idk. i just have to give some more time driving it and i gotta take it to the track to see if it really works. thanks for the DIY!
08nightblacksi is offline   Reply With Quote
Old 03-29-2010, 08:27 PM   #144 (permalink)
Poweraide's Avatar
I did mine. I didn't turn the rod all the way. I turned it about 2 full turns. Its hard to tell.
It feels a little better, it is still a little notchy. I may turn it just a little more.
Poweraide is offline   Reply With Quote
Old 03-29-2010, 08:36 PM   #145 (permalink)
yella fogz r hella JDM
redsi4's Avatar
redsi4 is offline   Reply With Quote
Old 03-29-2010, 08:43 PM   #146 (permalink)
michinsi's Avatar
McTomalds
I don't grind 2nd at all.
michinsi is offline   Reply With Quote
Old 03-29-2010, 08:45 PM   #147 (permalink)
FijiBlueFG2HT's Avatar
Mitch [Ryan #3]
So whose gonna be first to need a new clutch?
FijiBlueFG2HT is offline   Reply With Quote
Old 03-29-2010, 08:55 PM   #148 (permalink)
silentkillz1's Avatar
i just did this in less than 5mins, took it for a spin(car was driven 30mins prior to this) and it seems like it did the trick, but it might also be in my head. I did redline first and shifted into second very smoothly with no grind. Overall drive was "better" i mean i did feel a difference. I'll post up how it feels after a another day or two since the grinds happen most in the morning. I think this diy did the trick though.
silentkillz1 is offline   Reply With Quote
Old 03-29-2010, 09:37 PM   #149 (permalink)
the 8k rev's Avatar
Kickin' ass, takin' names...
well even if this trick takes a few years off the clutch, it'll be long after i trade it in anyways...smooth shifts all the way until then!
the 8k rev is offline   Reply With Quote
Old 03-29-2010, 10:07 PM   #150 (permalink)
lilwill8929's Avatar
William
I turned the rod too far and need to turn it back some. Any tips as the rod is really lubed up and i can't get a grip on it to turn it back. How should i do it?
lilwill8929 is offline   Reply With Quote
Old 03-29-2010, 10:11 PM   #151 (permalink)
the 8k rev's Avatar
needle nose pliers...
Old 03-29-2010, 10:12 PM   #152 (permalink)
William
Tried those but even they couldn't grip it. Will it wear out my clutch or anything if I turned it too far??
Old 03-29-2010, 11:03 PM   #153 (permalink)
SiAzul's Avatar
Mario
gonna try this one
SiAzul is offline   Reply With Quote
Old 03-29-2010, 11:27 PM   #154 (permalink)
GameTraveler's Avatar
@AK47, tried to PM you, but it's full. I think you asked about Carbon Synchro's in an earlier post:
SynchroTech Transmissions
I know there are others, but this shop showed up in the Feb 2010 Import Tuner mag.
Import Tuner article
For a simple Si rebuild, I was told
The Synchros are brass with a carbon fiber lining that aids in smoother shifting. The sleeve are steel. These are OEM JDM Honda parts used in the Japanese models.
My FA5 is being rebuilt by them, and everything that the Import Tuner article had, they're doing the same thing with my tranny--including replacing some of the gears, as David Henson indicated that the tranny must have run a little hot or low on fluids.
Besides the grinding, it was starting to get hard to shift into 5th and 6th at freeway speeds. David indicated that it wasn't with the gears--so I called over to the shop that pulled the unit out. Seems that the pressure plate maybe had about 30K miles left, but was out of spec (I dunno, I'm an computer consultant not a gearhead that I'd like to be); benefit to change it now, instead of later would save on labor fees since it was all apart now, and the shifting should be better with the rebuild.
Ah well, clear you PM inbox, pls, thx!
GameTraveler is offline   Reply With Quote
Old 03-29-2010, 11:28 PM   #155 (permalink)
Cam06 SI's Avatar
Cameron Crooks
interesting...subrscribed. sounds almost too good to be true... might get in there and try this one...you would just think honda would have picked up on it if the fix was this simple lol
Cam06 SI is offline   Reply With Quote
Old 03-29-2010, 11:58 PM   #156 (permalink)
seems like evo drivers have done this also
Clutch Pedal adjustment - evolutionm.net
Old 03-30-2010, 12:00 AM   #157 (permalink)
Branden_Si's Avatar
Branden
hmm im gona try this out and hopefully it truely helps!
im still a lil confused about it though since some people are rotating the rod the wrong way...
is this the correct way? (when looking up at the rod on your back like in the pics)
1. loosen the nut by turning the wrench clockwise
2. rotate the rod clockwise (same direction you turned your wrench right?)
3. tighten the nut by rotating the wrench counter-clockwise
Branden_Si is offline   Reply With Quote
Old 03-30-2010, 12:03 AM   #158 (permalink)
^correct
Old 03-30-2010, 12:06 AM   #159 (permalink)
Streethonda06's Avatar
Greg
thats the fix for mine all better now
Streethonda06 is offline   Reply With Quote
Old 03-30-2010, 12:27 AM   #160 (permalink)
Branden_Si's Avatar
Branden
so to feel that you adjusted it correctly, the engagement point will be later (meaning that the pedal needs to be released more in order to get the car rolling) ????
i want to do this right so i dont have to risk f-ing my ish up
Tags
2nd gear fix
LinkBack to this Thread: http://www.8thcivic.com/forums/diy-honda-civic-transmission/203074-diy-2nd-gear-grind-fix-clutch-adjust.html
Civic Si- Proper Shifting After 2nd Gear Fix - YouTube This thread Refback 09-20-2011 08:59 PM
Civic Si- Proper Shifting After 2nd Gear Fix - YouTube This thread Refback 09-05-2011 06:42 PM
‪Civic Si- Proper Shifting After 2nd Gear Fix‬‏ - YouTube This thread Refback 08-03-2011 12:43 AM
• View topic - DIY Clutch Adjustment This thread Refback 08-02-2011 01:10 PM
How do I adjust the clutch pedal? - Page 2 - Club RSX Message Board This thread Refback 07-26-2011 07:14 PM
Ask All Your Noob Transmission Questions Here v2 - Club RSX Message Board This thread Refback 07-07-2011 09:16 PM
3rd gear (or any gear) grind fix! - Club RSX Message Board This thread Refback 06-30-2011 09:35 AM
How do I adjust the clutch pedal? - Page 2 - Club RSX Message Board This thread Refback 06-29-2011 11:52 AM
2nd gear grind ericz0r Ontario 46 05-30-2010 07:34 PM
2nd gear grind FIX!!! READ Gimenez Civic SI 43 09-24-2009 08:31 PM
Hoping for 2nd gear grind fix: Redline MTF Grey2.0SI Civic SI 9 09-04-2009 05:26 PM
2nd gear grind Baddrummerboyy Mechanical Problems & Technical Chat 14 06-10-2009 07:27 AM
