#61 (permalink) | |
Alex
#70 (permalink) |
Stephen
DO NOT JUST TURN IT A TON.
Turn it 1 full rotation or so at a time, and test where it grabs after you turn it. Get it grabbing where you want, and then tighten the nut back up. If the rod isn't turning, try pressing or pulling up the pedal while turning, as that can bind the rod. |
#71 (permalink) |
Kyle
Didnt work... I grinded 3 out of 7 WOT runs. Maybe I messed up. I turned the rod toward the left and then locked the nut back hand tight. You think when I was turning the bolt back it pushed the rod? I want this to work SOOO bad!!!! Im gonna try again.
Update: I tried it again and now its REALLY hard to get it into second. The one time I could it grinded. I think I turned it the wrong way because the pressure point is at the floor now, did I turn it the wrong way? Last edited by Galaxy Grey Si Coupe; 03-27-2010 at 10:39 PM. |
#72 (permalink) | |
#73 (permalink) |
Kyle
Yep I see that now
![]() I turned it the right way and now it still grinds, but it goes into second now. Before, it would just deny me to get into second, now it goes in but still grinds. I think if I can turn it a little more, it will stop grinding... It just wont budge though. |
#74 (permalink) | |
#76 (permalink) | ||
![]() Quote:
#79 (permalink) | |
#80 (permalink) |
Kyle
Alright thanks for the help. If this DIY works I would be so happy! I shall try this tomorrow, my car is already cooling down in the garage. If it wasnt such a weird angle, it would be so much easier....
| Tags |
| 2nd gear fix |
LinkBack to this Thread: http://www.8thcivic.com/forums/diy-honda-civic-transmission/203074-diy-2nd-gear-grind-fix-clutch-adjust.html
| Civic Si- Proper Shifting After 2nd Gear Fix - YouTube | This thread | Refback | 09-20-2011 08:59 PM | |
| Civic Si- Proper Shifting After 2nd Gear Fix - YouTube | This thread | Refback | 09-05-2011 06:42 PM | |
| ‪Civic Si- Proper Shifting After 2nd Gear Fix‬‏ - YouTube | This thread | Refback | 08-03-2011 12:43 AM | |
| • View topic - DIY Clutch Adjustment | This thread | Refback | 08-02-2011 01:10 PM | |
| How do I adjust the clutch pedal? - Page 2 - Club RSX Message Board | This thread | Refback | 07-26-2011 07:14 PM | |
| Ask All Your Noob Transmission Questions Here v2 - Club RSX Message Board | This thread | Refback | 07-07-2011 09:16 PM | |
| 3rd gear (or any gear) grind fix! - Club RSX Message Board | This thread | Refback | 06-30-2011 09:35 AM | |
| How do I adjust the clutch pedal? - Page 2 - Club RSX Message Board | This thread | Refback | 06-29-2011 11:52 AM | |
| 2nd gear grind | ericz0r | Ontario | 46 | 05-30-2010 07:34 PM |
| 2nd gear grind FIX!!! READ | Gimenez | Civic SI | 43 | 09-24-2009 08:31 PM |
| Hoping for 2nd gear grind fix: Redline MTF | Grey2.0SI | Civic SI | 9 | 09-04-2009 05:26 PM |
| 2nd gear grind | Baddrummerboyy | Mechanical Problems & Technical Chat | 14 | 06-10-2009 07:27 AM |
