DIY: 2nd GEAR GRIND FIX!!!!- Clutch Adjust - Page 2 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Honda Civic Do It Yourself Articles > DIY Honda Civic Transmission
Old 03-27-2010, 03:10 AM   #21 (permalink)
'06Siguy's Avatar
Scott
Maybe you should change it to counter-clock wise....because I thought the same thing as the other guy.
http://www.8thcivic.com/forums/signaturepics/sigpic5287_4.gif
'06Siguy is offline   Reply With Quote
Old 03-27-2010, 03:24 AM   #22 (permalink)
Robert
I am going to do this tomorrow. This is ******* awesome if it fixes 2nd.
Varion Icaria is offline   Reply With Quote
Old 03-27-2010, 03:39 AM   #23 (permalink)
JDMFGSI's Avatar
Tommy GuNZ
hhhmmmm...interesting...
JDMFGSI is offline   Reply With Quote
Old 03-27-2010, 04:45 AM   #24 (permalink)
hotboysly's Avatar
Sly
hmm...will give a shot 2morroe
hotboysly is offline   Reply With Quote
Old 03-27-2010, 04:49 AM   #25 (permalink)
8thcivicRidesPoles :)
PainIs4ThaWeak's Avatar
Mike (12.854@110.10)
Hey Alex, could you put a link in this thread to your other thread: 2nd Gear Grind Theory- PLEASE READ!
And vice versa - link to this thread in ^ that thread - (Think it might help everyone a bit)
If we haven't figured it out by then (which I'm sure we will very soon) - I'll be putting in a fresh CC stg 2 clutch, CC flywheel, Omni CMC, Russell SS clutch line, TWM stg 2 shift assembly, motor mounts, switching to Redline MTF, and adjusting the clutch rod as neccessary once I make it back to the states, which will hopefully happen within the next few months. - At which point I'll post results, if we haven't solved this by then.
PainIs4ThaWeak is offline   Reply With Quote
Old 03-27-2010, 02:04 PM   #26 (permalink)
Philly
Thumbs up
OMFG I LOVE YOU this has made me fall in love with my car all over again!
thank you so much gaaaah!!!
Futurepr3 is offline   Reply With Quote
Old 03-27-2010, 02:14 PM   #27 (permalink)
so does the clutch engage higher up now?
Mine picks up halfway up @ 30k miles. I dont want to make it wear out my clutch faster, but that w2as sopme fast shifting i could not pull off without a grind!
blazelate is offline   Reply With Quote
Old 03-27-2010, 02:36 PM   #28 (permalink)
Alex
Same here, man... I'm glad I could help
AK47 Performance is offline   Reply With Quote
Old 03-27-2010, 02:38 PM   #29 (permalink)
Alex
Adjust it, but if your already at halfway you shouldn't be dragging. Test for clutch drag and if you are dragging, give it a little length on the clutch rod. Make sure you clutch is on the floor before you shift, and you should be golden.
test for clutch drag --> 2nd Gear Grind Theory- PLEASE READ!
Old 03-27-2010, 02:46 PM   #30 (permalink)
TuGood2BTru's Avatar
Tommy
Is the rod supposed to give quite a bit? I just adjusted mine and when i turned the rod with my fingers it probably wasn't even half a rotation. I'm about to leave the house so I';; give my review in about 30-60 minutes
TuGood2BTru is offline   Reply With Quote
Old 03-27-2010, 02:55 PM   #31 (permalink)
BBQXXX's Avatar
Corey
In for more results!
BBQXXX is offline   Reply With Quote
Old 03-27-2010, 03:45 PM   #32 (permalink)
Crazi3ge3's Avatar
Benji
ME TOO!
I don't want to cause more problem to my car untill I'm sure it'll work fine.
Crazi3ge3 is offline   Reply With Quote
Old 03-27-2010, 03:48 PM   #33 (permalink)
Crazi3ge3's Avatar
Benji
if im driving normal, im going to have to take my foot off the clutch farther right, to make it start rolling? im confused about how's its going to feel.
Old 03-27-2010, 03:56 PM   #34 (permalink)
Alex
The clutch will engage a little later. It really isn't a big deal, just takes a little getting used to.
Yea you should be able to turn it more then that. Don't be afraid to use a little force. You want the pedal to be stiff from the second you start pushing it. Stock, there is a little soft spot before it gets firm.
Old 03-27-2010, 03:59 PM   #35 (permalink)
Alex
I'm making a list on the original post of the people that experienced positive results from this adjustment. This will help the skeptics get an idea of how well it works! and if it isn't working, more than likely you aren't doing it correctly.
Old 03-27-2010, 04:05 PM   #36 (permalink)
Tommy
Okay well I guess I may need to redo it. I took it for a short spin and it seemed a little bit better, but I still get a notchy 2nd gear. I did not take it for a long enough drive to give a stong opinion about it. I will follow up later in the weekend.
Old 03-27-2010, 04:05 PM   #37 (permalink)
FijiBlueFG2HT's Avatar
Mitch [Ryan #3]
Video or ban.
FijiBlueFG2HT is offline   Reply With Quote
Old 03-27-2010, 04:25 PM   #38 (permalink)
drivelikeyoustoleit's Avatar
Adam
Originally Posted by FijiBlueFG2HT View Post
Video or ban.
uummm there is a video.... link is on the first pages first post from the OP
drivelikeyoustoleit is online now   Reply With Quote
Old 03-27-2010, 04:27 PM   #39 (permalink)
Mitch [Ryan #3]
Ahh, thank you.
Those shifts are not what I would consider, "proper" though. Why is there such a pause between the shift and acceleration? I start accelerating right after the shift.
Maybe if you had a reflash to eliminate rev-hang, it would be different.
Old 03-27-2010, 04:41 PM   #40 (permalink)
JDMFGSI's Avatar
Tommy GuNZ
i just did this...pedal feels firm all the way through...before there was a soft spot..not anymore...havent drove it yet but the diy is simple...will post results when i get back..
Tags
2nd gear fix
LinkBack to this Thread: http://www.8thcivic.com/forums/diy-honda-civic-transmission/203074-diy-2nd-gear-grind-fix-clutch-adjust.html
Civic Si- Proper Shifting After 2nd Gear Fix - YouTube This thread Refback 09-20-2011 08:59 PM
Civic Si- Proper Shifting After 2nd Gear Fix - YouTube This thread Refback 09-05-2011 06:42 PM
‪Civic Si- Proper Shifting After 2nd Gear Fix‬‏ - YouTube This thread Refback 08-03-2011 12:43 AM
• View topic - DIY Clutch Adjustment This thread Refback 08-02-2011 01:10 PM
How do I adjust the clutch pedal? - Page 2 - Club RSX Message Board This thread Refback 07-26-2011 07:14 PM
Ask All Your Noob Transmission Questions Here v2 - Club RSX Message Board This thread Refback 07-07-2011 09:16 PM
3rd gear (or any gear) grind fix! - Club RSX Message Board This thread Refback 06-30-2011 09:35 AM
How do I adjust the clutch pedal? - Page 2 - Club RSX Message Board This thread Refback 06-29-2011 11:52 AM
2nd gear grind ericz0r Ontario 46 05-30-2010 07:34 PM
2nd gear grind FIX!!! READ Gimenez Civic SI 43 09-24-2009 08:31 PM
Hoping for 2nd gear grind fix: Redline MTF Grey2.0SI Civic SI 9 09-04-2009 05:26 PM
2nd gear grind Baddrummerboyy Mechanical Problems & Technical Chat 14 06-10-2009 07:27 AM
