#163 (permalink) |
great diy! used it last night...only thing is, you have to remove the bracket that holds your brake line first or your caliper won't come off due to the tension....with that being said, even a novide can complete this job in under an hour with this diy.....thanks op!
#164 (permalink) |
also if yous can help, i carn t find a oil seection on hear so il just ask yous.
i went in to a auto shop, and gave details about my... car 2007civic type s GTI, he then selected a oil from the chart which is: Fully synth 5W30, which does match the handbook when i checked after i bought it, but the ACEA(what ever this is) dosent match. it says in manual ACEA A1/B1 ACEA A3/B3 or ACEA A5/B5 but this oil which he selected says, meets requirements of: ACER C2 is this anygood would you know???? thanks again.... |
#166 (permalink) |
Did this job this morning....went to Autozone and borrowed their loaner disc brake caliper tool. It's free to use, but requires a $55 deposit that is fully refunded when you return the tool.
Went to load this thread as I started and wouldn't you know it...."database error... the page wouldn't load. My observations post job: 1. I only released the parking brake, I didn't pull the eye hooks at the caliper disengaging it altogether. 2. I don't see how you could possibly slide the caliper off without creating additional slack in the lines by removing a securing bolt/retaining clip. I chose the one on the back side bottom that only had one bolt. 3. I didn't open the bleed valves or bleed the brakes. 4. My parking brake tension has returned without any adjustment. 5. The back of the pad that goes on the piston side has a nub on it that appears to eventually seat itself in the grooves of the piston. I'm not sure how this happens or when it happens. I could clearly see the image of the "X" of the piston on the old pad and this nub was certainly in the image left by the piston. Hopefully that makes sense. |
#168 (permalink) |
So I think I'm going to try to do my brakes for the first time this weekend with this write-up. My one question I have is it mandatory to open the bleeder screws or not really? I just don't want to hassle with bleeding the brakes. The main reason I don't want to hassle with it is I'm not that comfortable with it. Reason being that I dont know what size tubing to get and also in the pdf that someone attached it says "Starting at the front left loosen the brake bleed screw to allow air to escape the system then tighten the screw securely" when are you supposed to do this? i thought the clear tube was attached to the screw at this point. Sorry but like I said, first time on one of these.
#169 (permalink) | |
![]() Join Date: May 2006
#170 (permalink) |
I just did my rear brake pads with this and it went perfectly! So much nicer than spending the $$$ to have a shop do it. I used a piston compressor with the brake fluid resivoir off and it went well. what I did was really take my time compressing the piston so to not 'shock' the system with a burst of backwards pressure at once. Doing this, i didnt need to bleed the system. thanks for the help!
#171 (permalink) |
im doing my rears tomorrow i did my fronts no problem. i used a C clamp to push the piston in on the fronts..for the rear can i use the C clamp to get the piston back in or will i need a special tool? also should i have the E brake down?
#173 (permalink) | |
thanks guys! |
#178 (permalink) |
I just did this on my civic Sunday. It took about 2 hours and 45 minutes but I also cleaned each wheel before i put it back on.
All i can say is take brake fluid cap off and get the square thing from Sears they all worked great. |
#180 (permalink) |
I didn't read the whole 9 pages, but did anyone ever change their rear rotors (did not see a DIY for it in this section) ?
Think I'm gonna need an air ratchet to succeed (clearance issues with the tools I have). I tried today, all I was able to do with hand tools was the pad replacement procedure. So all I ended up doing was a simple service... clean out the crud, inspected my pads and re-lubed everything. For the street I'm ok, but I want to get my new rotors on there with my Hawk HP+ pads for when I'm gonna start lapping this season... |
LinkBack to this Thread: http://www.8thcivic.com/forums/diy-honda-civic-suspension/71378-diy-changing-rear-brake-pads.html
| 8th Generation Honda Civic Forum | This thread | Refback | 12-30-2007 09:39 PM | |
| DIY: Changing Manual Transmission Fluid | BATANG CITY JAIL | DIY Honda Civic Transmission | 1336 | 08-26-2012 05:24 PM |
| Changing the brake fluid for track.. Suggested? | Rownan | Suspension and Brakes | 16 | 09-04-2007 01:09 AM |
| Brake pads starting to squeal | The Shishpanik | Suspension and Brakes | 1 | 05-15-2007 11:31 PM |
| Changing your brake pads | mtbiker278 | Mechanical Problems & Technical Chat | 19 | 05-12-2007 03:53 PM |
| changing only rear spring? | CivicWithNav | Suspension and Brakes | 6 | 05-16-2006 04:53 PM |
