DIY Front Brake Pads - Page 3 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Honda Civic Do It Yourself Articles > DIY Honda Civic Suspension
Old 02-01-2009, 10:13 PM   #41 (permalink)
No bleeding of the breaks?
Damn its easy ......
ErMasta is offline   Reply With Quote
Old 02-01-2009, 10:17 PM   #42 (permalink)
[hwy]Hagen's Avatar
and yet people pay about $100 for a shop to do it...
[hwy]Hagen is offline   Reply With Quote
Old 02-01-2009, 11:04 PM   #43 (permalink)
lol i hear ya...I waasking cause i used to have to bleed the breaks and for me it was a pain in the ass to do it.
Not bleeding the breaks makes everything much easier and cleaner.
Old 02-01-2009, 11:15 PM   #44 (permalink)
07k20z3ftw's Avatar
Mitch
i looked at my front the other day, getting prty low around 22k and i do alot of engine braking, ill prly use this DIY, suggestions on good pads for street use?
07k20z3ftw is offline   Reply With Quote
Old 02-02-2009, 08:29 AM   #45 (permalink)
tda1337's Avatar
Rick
good pads:
Prostop ceramic (pep boys, they are in my car now)
EBC green/yellow/red stuff
Hawk
Brembo
try and go ceramic or sport semi metallic if possible
i chose ceramic cause i had to replace mine (still had some wear on them) at 28200.
I have HUGE hills i go down and they have to brake heavy
Despite what neone says tho, dont make the same mistake i did
DEF get the rotors resurfaced (i was told dont bother)
you can take them off and bring them to pepboys to get resurfaced (turned) for 20 bux or less
def worth it!
tda1337 is offline   Reply With Quote
Old 02-02-2009, 10:49 AM   #46 (permalink)
say55ow's Avatar
I bought some Hawks HPS for my 07 Si.
After taking out the stock pads, I realized that there are two shims attached to each of the inner and outer pads. Looking at the new pads, it appears to have the a single shim pre glued onto the back of the pad.
So my question is for those who have installed the this particular pad - Do the Hawks HPS pads need the OEM shim on top of the pre glued shim attached to the HPS pads?
Thanks in advance.
say55ow is offline   Reply With Quote
Old 02-02-2009, 02:20 PM   #47 (permalink)
say55ow's Avatar
I contacted a Hawks rep about my question and he said not to use the OEM shims.
I can wait to finally put them suckers in. I'll probably take Friday off to do so!
Old 02-02-2009, 08:32 PM   #48 (permalink)
tda1337's Avatar
Rick
yea i never use the stock shims
they usually just cause noise lol
Old 02-09-2009, 02:09 PM   #49 (permalink)
EuphoricRhythm's Avatar
wow everyone is changing their pads so early
just did my fronts and i have alittle over 63k miles. I also do alot of mountain/ canyon driving. Got the hawk HPS pads and they feel great so far.
EuphoricRhythm is offline   Reply With Quote
Old 02-09-2009, 09:32 PM   #50 (permalink)
tda1337's Avatar
Rick
does neone know if theres a thread on converting rear drum to rear disk?
Old 02-09-2009, 10:34 PM   #51 (permalink)
kck
Not sure if you're referring to this thread?
R18LX's Rear Disc Conversion
kck is offline   Reply With Quote
Old 02-10-2009, 12:40 PM   #52 (permalink)
tda1337's Avatar
Rick
negative ive seen that.
i meant a DIY
Old 02-10-2009, 02:43 PM   #53 (permalink)
say55ow's Avatar
Talking
Wow 63K on stock pads. Amazing. Do you make a lot of mountain/canyon driving to Barona
Old 02-10-2009, 03:56 PM   #54 (permalink)
Taylor Kurtz
ur not braking hard enough if you are driving aggressively. you should be hitting ur brakes hard enough to be able to modulate them and prevent them from lighting up your tires, then getting right back on the gas.
CanyonDriver is offline   Reply With Quote
Old 02-10-2009, 04:06 PM   #55 (permalink)
FG2uner's Avatar
Mark
i have 40k on my si now and its time to change the pads and rotors.... should i do the back too or is it ok not to? i know most of the braking comes from the front.
FG2uner is offline   Reply With Quote
Old 02-10-2009, 04:11 PM   #56 (permalink)
tda1337's Avatar
Rick
rear, no
u should not need to replace ur rotors, just drop em off at pepboys for an hour or two, they will resurface them for CHEAP
pick up a set of ceramic pads
either EBC, Prostop (pepboy brand), Hawk or Brembo suggested
Old 02-10-2009, 04:12 PM   #57 (permalink)
FG2uner's Avatar
Mark
we dont have pepboys here. and the reason i dont wanna resurface them is because the get cut down and warp faster. im getting slotted/ drilled rotors
Old 02-10-2009, 05:01 PM   #58 (permalink)
tda1337's Avatar
Rick
go slotted, drilled does nothing
Old 02-13-2009, 11:12 AM   #59 (permalink)
Teknotik.com
nice write up
Nolan is offline   Reply With Quote
Old 03-08-2009, 11:08 AM   #60 (permalink)
Doeboy211's Avatar
Rob
Where do you but that assembly paste? Honda only or can I get it local? I just bought some Hawk pads and going to attempt to do this myself.
Doeboy211 is online now   Reply With Quote
Price for Front HFP rotors and pads. CivicCoupe06 Inside and Out 2 06-30-2009 11:20 PM
Brakes (06' Si) Parts-list: Torredo Suspension and Brakes 5 04-02-2009 07:06 PM
Removing mud flaps and front and rear brake cooling vents...? Johnold Inside and Out 14 04-02-2007 07:20 PM
new brake pads at 25000 miles turktech Civic Coupe And Sedan 5 03-13-2007 08:34 PM
