DIY Front Brake Pads - Page 10 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Honda Civic Do It Yourself Articles > DIY Honda Civic Suspension
Old 10-22-2010, 03:41 AM   #181 (permalink)
Same here just changed my last week at around 30k. Replaced front and rear pads and resurfaced the rotors.
my1stsi is offline   Reply With Quote
Old 10-26-2010, 03:27 PM   #182 (permalink)
I M Legend's Avatar
What pads are most of you using? Particularly the ones who DO NOT track the car. I'm just looking for regular street pads.
I M Legend is offline   Reply With Quote
Old 10-26-2010, 03:35 PM   #183 (permalink)
08 black si sedan's Avatar
Nick
I just used the ceramic pads for the front. I got them from consumer auto parts. It was $ 40 or $ 45 i can't remember.
08 black si sedan is offline   Reply With Quote
Old 10-27-2010, 04:27 PM   #185 (permalink)
aac0036's Avatar
Drew
Those are pretty close to the stock pads. You could use Tire Rack, they categorize everything as Autocross/Track, street, performance street, and have ratings and reviews for everything if you're not sure.
aac0036 is offline   Reply With Quote
Old 10-28-2010, 01:44 PM   #186 (permalink)
SI-YA's Avatar
Graham
I'd recommend Eagle pads, but beware the dust from ceramic.
I've got a set of black konigs and it doesn't take more than 48 hours to get those things COATED in dust after a carwash. I would have just bought the hawk HP if I could do it again, not the Hawk HPC... Still amazing bite though, and the EBC 3GD rotors I installed with it are pretty brilliant too, I'm just concerned about their life since they seem to be wearing fast.
SI-YA is offline   Reply With Quote
Old 10-28-2010, 03:18 PM   #187 (permalink)
I M Legend's Avatar
Thanks guys, I think I will go with OEM pads since I found them for around $40 at Majestic Honda.
Old 11-05-2010, 11:14 AM   #188 (permalink)
[MK]'s Avatar
Retarded question, how do i get the rotars off, first time doing my brakes
thanks
[MK] is offline   Reply With Quote
Old 11-15-2010, 11:16 AM   #189 (permalink)
RCHamel3's Avatar
Rob
thanks
After you remove the wheel and brake caliper from the rotor, you should be able to pull it right off.
RCHamel3 is offline   Reply With Quote
Old 01-18-2011, 09:57 PM   #190 (permalink)
Will06SI's Avatar
Function over Form..
74k still on my stock pads but i def need brakes soon might do a Stoptech 4 piston kit or just slotted rotors and hawk hp + pads..
Will06SI is offline   Reply With Quote
Old 01-26-2011, 03:46 PM   #191 (permalink)
CatchThaBeat's Avatar
Brandon
Thanks! Helped a ton.
CatchThaBeat is offline   Reply With Quote
Old 02-24-2011, 10:33 PM   #192 (permalink)
maximus20895's Avatar
Max
How necessary is it to use M-77 assembly paste? Is it a must or what?
maximus20895 is offline   Reply With Quote
Old 02-25-2011, 10:14 AM   #193 (permalink)
SteveOFG2's Avatar
Steve-O
not a must, just what honda does. you can use any anti-seize compound or brake paste.
SteveOFG2 is offline   Reply With Quote
Old 02-25-2011, 10:30 AM   #194 (permalink)
RCHamel3's Avatar
Rob
On avg. how long do rotors last under normal (not abusive) driving before needing to be resurfaced? What is the best way to tell?
I am around 48k and the bakes still have some life left and I want to replace the brakes myself, but I also don't want to have to resurface the rotors shortly after..
Thanx in advance!
Old 02-25-2011, 11:07 AM   #195 (permalink)
SI-YA's Avatar
Graham
Get their thickness checked, then do the work yourself if you need to replace them.
Regardless of the wear I replaced mine at about 30k, I didn't want to wonder how they were holding up. I've still got them stashed in case I need them, but I bought an EBC 3GD rotor set all around, and it's made me happy with 20k + miles so far.
Old 02-25-2011, 11:17 AM   #196 (permalink)
Max
You can feel for any chips etc on the rotor. Also, there should be a number that says the how thick it can be before you need to replace. It will be like 18mm or something. Just take a 18mm wrench (if that's the number) and see if it can fit over the rotor. If it can you need to replace.
Old 02-28-2011, 10:09 AM   #197 (permalink)
RCHamel3's Avatar
Rob
ok. thank you guys.
Old 03-16-2011, 12:48 AM   #198 (permalink)
thanks.
Stalk is offline   Reply With Quote
Old 03-17-2011, 12:47 AM   #199 (permalink)
just got some Hawk HPSs. I assume the paste that comes in the pack is equivalent to the M77?
dehydratedH2O is offline   Reply With Quote
Old 03-17-2011, 06:10 PM   #200 (permalink)
SI-YA's Avatar
Graham
It works just fine.
Price for Front HFP rotors and pads. CivicCoupe06 Inside and Out 2 06-30-2009 11:20 PM
Brakes (06' Si) Parts-list: Torredo Suspension and Brakes 5 04-02-2009 07:06 PM
Removing mud flaps and front and rear brake cooling vents...? Johnold Inside and Out 14 04-02-2007 07:20 PM
new brake pads at 25000 miles turktech Civic Coupe And Sedan 5 03-13-2007 08:34 PM
