Ok well, i guess the first thing is to go buy some sealant i bought my from ace hardware or just get some that is clear and flexiable.
2nd thing : remove all the plastic clips from under the bumper and the 2 goldish bolts then romove the 2 screws (one on each side of the bumper by the tires)
3rd thing : pop your hood and romove the plastic cover over the front grill
then you see to allens screws and romove those
4th thing: time to romove you bumper (make sure you have something down on the floor so you don't scratch it) start removing you bumper from 1 side then the other side then the middle it seemed easy that way
5th thing : go preheat your oven to 275
6th thing : ok well, now time to remove you headlights there are 5 10mm bolts holding them in. start with the bolts on the bottom of the head light and on the side then remove the black metal bar around them. ok time to take out the last 2 bolts then pull your headlight out and unplug everything and then remove the bulbs
7th thing : put the headlight down on a cloth or something and flip it over so you see the back side. see the 4 silver screws well, remove those and place them aside for later
8th thing : go put you headlight in the oven for 6 mins at 275 and make sure to watch it and not leave it in there to long that would be bad
9th thing : have 4 common screw drivers ready for you. and start pushing it in under the black plastic towards the top where the driving light is and then work you way around but do the area where the turn signal is last. then just pull apart SLOWLY!!!
10th thing : ok on the lense part of the headlight there are 2 screws that need to be taken out then just remove the chorme and orange plastic then put back the chorme peice and screw it in
11th thing : make sure you use a razor blade to cut out and of that black **** around the lense and housing then that sealent i told you to buy put it on the the housing and slowly put you lense back on the housing
12th thing: those 4 silver screws that you took out ealier well put thoise back in and then let the head light dry for however long it says on the sealent (you might have to use clamps to hold some of the headlight together if you want i didn't need to tho)
13th thing : repeat steps 6th-12th
14th thing : put your bumper back on the same way you took it off
15th thing : shut your hood and step back and look at what you did :SHOCKED:
IF YOU BREAK YOUR HEADLIGHTS, BUMPER , SCREWS OR ANYTHING THAT HAS TO DO WITH THIS DIY PROJECT IT IS NOT MY FAULT YOU JUST WASN'T SKILLED ENOUGH TO TRY THIS.
If anyone seen something i might of missed please post and if you do this please post before and after pictures i wanna see what this looks like on different colors of si
