The purpose of this DIY is to show you how to remove the Ebay Fog Light Lens BEFORE they crack/break. I highly recommend doing this to prevent any frustration in the future.
Tools:
Razorblade
Flathead screwdriver
What I started with.
Take off the plastic surrounding the fog light lens. Four tabs hold it on.
Use the razorblade and go around the lens applying medium to light pressure.
Use your flathead screwdriver to pry the lens off the fog light. This should take very little force as the glue is brittle.
Use any method to get rid of the excess glue that is still stuck to the fog light.
You are all set and ready to do a replacement. Make sure to clean the inside of the housing as some of the pieces of glue probably fell into there. There is another DIY on how to replace the lens with Lexan.
Tools:
Razorblade
