DIY Oem Fog Lights with Parking Lights/ 06si - Page 6 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Honda Civic Do It Yourself Articles > DIY Honda Civic Lighting
Old 03-23-2008, 03:15 AM   #101 (permalink)
HkyGrL2's Avatar
Cendy :D
nevermind
HkyGrL2 is offline   Reply With Quote
Old 04-10-2008, 05:12 AM   #102 (permalink)
can some1 show how its done in an 07 si? cuz its different in mine and im lost.
mrtupac is offline   Reply With Quote
Old 04-17-2008, 10:14 PM   #103 (permalink)
zippob09's Avatar
John
this thread was great untill a bunch of people started asking very odd questions.
zippob09 is offline   Reply With Quote
Old 05-02-2008, 06:25 PM   #104 (permalink)
ASHRAF's Avatar
i was planning to get the stalk setup, will it turn the fogs on if it was on parking light mode, or will it just allow me to turn it on if it was on headlight mode
ASHRAF is offline   Reply With Quote
Old 05-14-2008, 03:56 PM   #105 (permalink)
joon joon's Avatar
so has anyone done this for an 07 or 08??
joon joon is online now   Reply With Quote
Old 05-14-2008, 04:15 PM   #106 (permalink)
jlannoo's Avatar
With the stalk I think its just with the headlights
jlannoo is offline   Reply With Quote
Old 05-14-2008, 04:34 PM   #107 (permalink)
joon joon's Avatar
i think i got it... just used a volt meter.. checked which wire got a ground when the switch is on now i gotta figure out which wire gets 12vs when the parking lights are on..
Old 05-15-2008, 10:23 AM   #108 (permalink)
joon joon's Avatar
i'm stumped.. still havent gotten it... anyone else tried this??.. i know i'm still trying..
Old 05-15-2008, 11:30 AM   #109 (permalink)
joon joon's Avatar
found some wiring diagrams here at school so i'mma try this again.. hopefully get it this time
Old 05-26-2008, 04:22 AM   #110 (permalink)
08taffetawhite's Avatar
OR..........
if you installed your oem fogs youself you can hardwire the positive wire into the wire going into the parking light bulb! just an idea
08taffetawhite is offline   Reply With Quote
Old 05-26-2008, 10:37 AM   #111 (permalink)
Gone's Avatar
Andy
^^^ Is it really that easy?
Gone is offline   Reply With Quote
Old 05-26-2008, 02:09 PM   #112 (permalink)
the only thing with my idea, and im currently in the process of doing it, is i keep blowing fuses, seeing what else i can do since i have oem fogs but not an oem connector i have a basic neg and positive wire coming out of the fogs
Old 05-27-2008, 09:19 PM   #113 (permalink)
bump for better pictures and maybe step by step directions. i still don't know what TAP means? me=noob.
HipHopMenace is offline   Reply With Quote
Old 05-28-2008, 09:48 AM   #114 (permalink)
Have you tried a larger fuse? I'm just guessing, but if it works, I'm going to do the same thing, so please keep us posted. If one can wire the side marker lights into the parking lights, then we should be able to do the same with the fogs... Although the latter uses more power... I don't know.
ivtec20 is offline   Reply With Quote
Old 05-28-2008, 11:15 AM   #115 (permalink)
joon joon's Avatar
well the side markers arent on a switch... and dont use a larger fuse cuz then that could cause some problems.. if u dont know y ur blowing fuses with the original size amp then dont step it up diagnois it..
Old 05-28-2008, 11:58 AM   #116 (permalink)
I think he's trying to not use the switch and run the foglights directly off the parking lights.
Old 05-28-2008, 11:15 PM   #117 (permalink)
I wish the pictures were better. Focus on the subject and not the background
Zaistlin is offline   Reply With Quote
Old 06-06-2008, 01:43 AM   #118 (permalink)
kicker_jace's Avatar
Jayson
Questions
1. Can you still use the OEM switch to turn off/on the fogs?
2. When the High Beams is switched on, does the fogs go off like OEM setup?
kicker_jace is offline   Reply With Quote
Old 06-06-2008, 09:21 AM   #119 (permalink)
Jayson
forget my questions...
ill answer it.
1. it does work with the switch
2. its goes on with the high beams
awesome diy.
Old 06-20-2008, 03:49 AM   #120 (permalink)
vingavina's Avatar
so there is no way for me to do this with the stalk switch?
vingavina is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/diy-honda-civic-lighting/29997-diy-oem-fog-lights-parking-lights-06si.html
Lighting [Archive] - 8th Generation Honda Civic Forum This thread Refback 02-15-2008 12:11 PM
06 Civic Fog Light Install Guide (pics!) - Page 4 - ClubCivic.com - Honda Civic Forum This thread Refback 12-06-2007 06:57 PM
installed my oem fog lights - 8th Generation Honda Civic Forum This thread Refback 12-05-2007 11:11 PM
OEM harness on k2motors fog lights reelbigfish241 Lighting, H.I.D.'s, & Neon 45 04-17-2010 08:53 AM
OEM Fogs, I want the fogs to turn on with parking lights Hotwheels Lighting, H.I.D.'s, & Neon 33 11-10-2008 01:29 PM
Anyone wired fog lights with parking lights? BamaCivic Lighting, H.I.D.'s, & Neon 1 11-16-2006 01:08 PM
