How to install your XenonDepot HID's - Page 25 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Honda Civic Do It Yourself Articles > DIY Honda Civic Lighting
Old 10-31-2012, 07:48 PM   #481 (permalink)
would i need the relays in an 09? Or would the wiring be able to support the initial load?
aarondiaz is online now   Reply With Quote
Old 11-01-2012, 12:48 PM   #482 (permalink)
8thcivic Sponsor
XenonDepot's Avatar
It depends on the kit that you install. XenonDepot Xtreme HID ballasts are super low draw meaning that you will be able to install the kit without the use of a relay harness.
Steve
Honda Civic Parts & Accessories - HID KITS - AUTOMOTIVE LED BULBS - FLOOR MATS & LINERS - CAR COVERS - SEAT COVERS
8thcivic.com SUPER SALE is on! - SAVE $$$
AUTHORIZED 8TH CIVIC VENDOR SINCE 2005 - SHOP WITH CONFIDENCE!
XenonDepot is offline   Reply With Quote
Old 11-01-2012, 01:50 PM   #483 (permalink)
ohhh ok, what ks the best/cheapest kit i can get?
Steve
Old 11-01-2012, 01:55 PM   #484 (permalink)
Steve
ohh ok, what is the best/cheapest kit i can get?
Old 11-05-2012, 07:54 AM   #485 (permalink)
8thcivic Sponsor
XenonDepot's Avatar
best and cheapest don't always go hand in hand. However, if you are looking for an economically priced quality HID kit that will come with a legitimate warranty then I would suggest looking at the Volt HID kit. The current discounted website pricing along with the "8thcivic" coupon code will get you the kit for $89.99 shipped within the continental USA. This is literally the lowest we have ever sold these kits for. Save while you can.
Steve
Old 11-10-2012, 10:15 PM   #486 (permalink)
R1raven2's Avatar
Derrick - R18 Crew Member#2022
just did mine the other day. love them! also went alittle crazy and did the LED DRLs w/ decoders and the LED switchback corner markers/signals..
HID's 6000k
DRL's and corner LED corner markers that switch to amber when turn signal is activated
Up close of the corner markers LED
R1raven2 is offline   Reply With Quote
Old 11-12-2012, 03:34 PM   #487 (permalink)
8thcivic Sponsor
XenonDepot's Avatar
Thank you for taking the time to post up some feedback!
Steve
Old 11-17-2012, 12:36 PM   #488 (permalink)
R_Foundation's Avatar
Thanks Igobuk for this write up, also thanks to whomever for the stickie. I know its been a couple of years but I will be using this in a couple of weeks.
R_Foundation is offline   Reply With Quote
Old 11-17-2012, 04:52 PM   #489 (permalink)
I just installed my 6500k XenonDepot Xtreme HIDs using some of this guide. Lovely is all I can say. I used some of this guide as far as going through the fender liner for the passenger side bulb, but I ended up removing the bumper to make it easier to hide all of the stuff like the ballasts and the relays and wiring. Great write up. And thanks to XenonDepot for a great product.
t1.8matt is offline   Reply With Quote
Old 11-17-2012, 04:55 PM   #490 (permalink)
One question I have for Steve, if the Xtreme HIDs are low draw and don't need a relay harness, why do they come with the relay built into the harness?
Old 11-17-2012, 05:42 PM   #491 (permalink)
Here's a couple shots with my Xtreme HIDs. Gonna have to get some projectors to get a sharper cutoff.
How to install your XenonDepot HID's-img_20121117_172802.jpg   How to install your XenonDepot HID's-img_20121117_172744.jpg   How to install your XenonDepot HID's-img_20121117_172729.jpg
Old 11-19-2012, 01:47 PM   #492 (permalink)
8thcivic Sponsor
XenonDepot's Avatar
t1.8matt: The harness is not built in at all. It can be used or you can choose to simply power the ballasts directly from the OEM headlight wiring. The relay harness is the harness that requires you to run a lead to the power for batter, a ground, a connection to the OEM headlight harness, and a connection to the ballast.
Steve
Old 11-23-2012, 03:47 PM   #493 (permalink)
Steve
right, i didnt' mean built in to the whole harness. but if they're not really needed, why supply them at all? If the civic doesn't technically need them, is it because these aren't vehicle specific kits that the relay is included?
Old 11-23-2012, 04:44 PM   #494 (permalink)
8thcivic Sponsor
XenonDepot's Avatar
Hi,
Some vehicles require the use of a relay harness otherwise you end up getting an error code. Other vehicles require a harness because the OEM headlight harness is not able to supply a stable 12V.
Steve
Old 11-23-2012, 04:46 PM   #495 (permalink)
Hi,
Steve
ok, but just for clarification, our vehicles like my 07 si don't need the relay?
Old 11-23-2012, 04:47 PM   #496 (permalink)
8thcivic Sponsor
XenonDepot's Avatar
Hi,
As long as your vehicle is able to supply a stable 12V from the OE harness then you do not have to use a relay harness. The Xtreme ballasts are low draw ballasts meaning that you can safely power them directly from the OEM wiring without the potential of causing any damage.
Steve
Old 11-25-2012, 03:04 PM   #497 (permalink)
good diy
menebo08 is offline   Reply With Quote
Old 11-26-2012, 01:11 PM   #498 (permalink)
8thcivic Sponsor
XenonDepot's Avatar
This thread was posted 3 years ago yesterday (nov 25/09)... wow.. time goes by quickly.
Steve
Old 12-01-2012, 01:17 PM   #499 (permalink)
OK I installed my xtream kit yesterday using some of this write up, the engine bay on an 2009 is different so I had to mount the driver side ballast in a different place. You definitely need to set aside 2-3 hours for this install so you can take your time. The passenger side took the most time with me having to go thru the wheel cover in order to access the light. I am happy with the product and will tweak it a little later on this evening. Happy Modding..
R_Foundation
Old 12-03-2012, 12:27 PM   #500 (permalink)
8thcivic Sponsor
XenonDepot's Avatar
Thanks for the feedback!!!
LinkBack to this Thread: http://www.8thcivic.com/forums/diy-honda-civic-lighting/186425-how-install-your-xenondepot-hids.html
Modits HID ...pas facile poser ça! AIDEZ MOI! - Club Civic Quebec :: Forum This thread Refback 09-20-2011 05:13 PM
Exclusive Pricing on XenonDepot.com HID Kits & Premium LED Lighting! - Save Big! - Page 3 - Honda Odyssey Forum : Odyssey Minivan Forums This thread Refback 09-01-2011 09:59 PM
XenonDepot HID Install Guide unplugged Lighting, H.I.D.'s, & Neon 106 03-14-2013 08:29 PM
Lookin at Xenondepot Headlight and HID's mako8 Lighting, H.I.D.'s, & Neon 1 11-25-2012 03:05 PM
HID xenondepot install guide webby DIY Honda Civic Lighting 66 10-18-2011 07:05 PM
XenonDepot HID Slim Ballast Kit Install/Review (Pics heavy) wilsontieu Lighting, H.I.D.'s, & Neon 16 02-22-2009 02:47 AM
xenondepot 6500k or xenondepot 8000k??? jackolee Lighting, H.I.D.'s, & Neon 10 10-03-2007 08:43 PM
