DIY: Install guide for OEM fogs... - Page 3 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Honda Civic Do It Yourself Articles > DIY Honda Civic Lighting
Old 04-21-2007, 12:17 AM   #41 (permalink)
vtmn215's Avatar
degunk then with a shot of wd-40 and with a bit of persistance, a smaller flat head screwdriver, your wishes will come true. Depending on where you live, You probably have a bunch of gunk clogging up the stem of the anchor. The best way to pull the center pin out of the anchors are to stick a flathead screwdriver until it hits the stem and just turn the screwdriver 90 degrees. That should be enough.. or get a panel tool.. has a V groove in it.
vtmn215 is offline   Reply With Quote
Old 04-21-2007, 03:02 PM   #42 (permalink)
The other ones I got out or tried to get out had sand and crap in it from the winter and road debris. I'll give it a shot. Thanks!
taffysi is offline   Reply With Quote
Old 04-21-2007, 03:08 PM   #43 (permalink)
truflip's Avatar
karlitO
let us know if it helps
I think me go wash my car before I tackle this install.. lol
truflip is offline   Reply With Quote
Old 04-21-2007, 03:49 PM   #44 (permalink)
Alright, I got all the bolts off guys, thanks! Do I just remove the cover. It still wont come off, looks like they're still attached to the hinges by the headlights.
Old 04-21-2007, 04:10 PM   #45 (permalink)
truflip's Avatar
karlitO
yea u gotta remove some bolts from the grill.. by the headlights.. have u looked at the collegehillshonda pdf instructions?
Old 04-21-2007, 05:07 PM   #46 (permalink)
Alright guys, thanks for your help. I just had to change the broken foglight from the driver side. I did follow the college hills instructions and had all the bolts from the grill, sides of the bumper, and bottoms off. When you peel the bumper off, there is hinges below the headlights that the bumper is attached to. Just carefully try to pull it off slowly. The bottom plastic bolts are a PITA. They were stuck with gunk and sand so what I did was used a small thin flathead screwdriver to get the centers of the bolts up and a little loose (getting the flathead under the bolt and turning it 90 degrees)..then used a bigger flathead screwdriver to pry and pull them off (sometimes turning it 90 degrees to get them further up). Seems to work the best for me. Thank you for all your help!
Old 04-23-2007, 11:30 AM   #47 (permalink)
truflip's Avatar
karlitO
guys, do you know what size the stepped screws are? the one with the rubber washers. they hold the fog lamps onto the metal brackets (from the sides)
Old 04-23-2007, 11:35 AM   #48 (permalink)
vtmn215's Avatar
eek... sorry i misread your post tru... I got no answer for you. mods delete if you can
Old 04-23-2007, 11:13 PM   #49 (permalink)
fiji06si13's Avatar
Justin aka Mr. JT
Exclamation Help!
I was told the blue wire is for the fog light indicator on dash board....Is it a ground for the indicator or does it supply power to indicator on dash?
fiji06si13 is offline   Reply With Quote
Old 04-25-2007, 09:21 PM   #50 (permalink)
SiSpeed's Avatar
I would really like to install this fog light kit on my 2007 Si but instead of a blank slot in the dash I have a VSC off button, so I have nowhere to put the switch.
SiSpeed is offline   Reply With Quote
Old 04-25-2007, 09:26 PM   #51 (permalink)
truflip's Avatar
karlitO
^^ you would have to purchase the lil switch for the headlights .. which includes the fog light switch as well.. i think
Old 04-25-2007, 09:27 PM   #52 (permalink)
fiji06si13's Avatar
Justin aka Mr. JT
just put the switch in the change holder below the VSC button....
VSC sucks......not needed on the SI at all....
Old 04-25-2007, 09:33 PM   #53 (permalink)
truflip's Avatar
karlitO
[QUOTE=fiji06si13]just put the switch in the change holder below the VSC button....QUOTE]
like this:
07 K2 Fogs. Different Question. Promise.
Old 04-25-2007, 09:46 PM   #54 (permalink)
SiSpeed's Avatar
This said to hide it under the dash and the fogs would come on when the parking lights come on. Are the parking lights the ones that turn on right before the low beams?
Old 04-25-2007, 09:47 PM   #55 (permalink)
fiji06si13's Avatar
Justin aka Mr. JT
yes
Old 04-25-2007, 10:40 PM   #56 (permalink)
SiSpeed's Avatar
http://www.handa-accessories.com/civext06.html
There is an actual fog light kit for an 07 Si here.
Old 04-25-2007, 10:43 PM   #57 (permalink)
fiji06si13's Avatar
Justin aka Mr. JT
can't view install instructions...
Old 04-25-2007, 10:44 PM   #58 (permalink)
SiSpeed's Avatar
I read the instructions and it comes with a new light switch that includes a fog light switch
Old 04-25-2007, 10:49 PM   #59 (permalink)
fiji06si13's Avatar
Justin aka Mr. JT
cool
Old 04-25-2007, 11:58 PM   #60 (permalink)
truflip's Avatar
karlitO
so your headlight switch now includes a fog light switch as well?
LinkBack to this Thread: http://www.8thcivic.com/forums/diy-honda-civic-lighting/13214-diy-install-guide-oem-fogs.html
Installation de fog? - Club Civic Quebec :: Forum This thread Refback 09-13-2011 02:30 AM
Installation de fog? - Club Civic Quebec :: Forum This thread Refback 08-21-2011 09:46 PM
Installation de fog? - Club Civic Quebec :: Forum This thread Refback 08-20-2011 11:27 AM
Installation de fog? - Club Civic Quebec :: Forum This thread Refback 08-19-2011 08:08 PM
ClickProtect This thread Refback 02-25-2008 04:51 PM
The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: Fog light install This thread Refback 02-19-2008 10:29 PM
The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: Fog light install This thread Refback 02-11-2008 04:20 AM
Lighting [Archive] - 8th Generation Honda Civic Forum This thread Refback 02-06-2008 01:45 PM
The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: Fog light install This thread Refback 01-21-2008 10:41 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-19-2008 10:59 PM
DIY: Install guide for OEM fogs... - Page 7 - 8th Generation Honda Civic Forum This thread Refback 01-16-2008 07:27 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-01-2008 07:48 PM
The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Civic > > Re: Fog light install This thread Refback 12-12-2007 05:18 PM
Fog lights install - Page 6 - 8th Generation Honda Civic Forum This thread Refback 12-09-2007 04:22 PM
8th Generation Honda Civic Forum This thread Refback 12-06-2007 10:54 AM
DIY: Injen CAI install on R18 (lots of pics) peliROJO DIY Honda Civic Engine 179 03-16-2013 09:45 AM
XenonDepot HID Install Guide unplugged Lighting, H.I.D.'s, & Neon 106 03-14-2013 08:29 PM
2006 Civic Rear Speaker Install Guide webby DIY Honda Civic Audio 50 07-25-2012 05:37 PM
HID xenondepot install guide webby DIY Honda Civic Lighting 66 10-18-2011 07:05 PM
DIY install of new head unit in sedan UK/AUS aussiebuddha I.C.E., Electrical, Security, & Navigation 4 04-04-2006 02:30 PM
