Okay guys, I wasnt allowed to post in the DIY section, so im going to post it here. I dont know if this even belongs in the DIY section haha. I thought it was time to contribute back to the community even though i dont own an 8th.
This info can minimize all the threads about fogs working on 07-08 coupes.
Anyway, I installed fog lights on my gfs 08 Si coupe tonight, and it went flawless, fully plug and play, with Stalk to make everything work like OEM. I did not splice 1 single wire for this!
Heres what you need:
Ebay Fogs ($50 shipped)
OEM Stalk (35255-SNA-M01)(07-08 uses the SAME stalk)
OEM Interior Switch Harness (08V31-SNA-10030)
OEM Relay for the Fog Lights (39794-SDA-A05)
(All 3 OEM parts came to $80 Shipped @ Bernardiparts.com, these part numbers will work on all 07-08 coupes)
TOTAL: $130 Shipped!!!
Pic of the OEM parts:
We bought yellow fogs instead of clear ones, but its up to you.
Basically here is what you have to use and what you have to throw out, the ebay fogs comes with 3 harnesses, you no longer need the one with the relay on it because you are using the OEM one.
Here are the pic of the part numbers
OEM stalk:
OEM Relay:
After you get all the parts, you can go to collegehillshonda.com and get the installation instructions, the install it just like oem, but you saved over $100 by doing it this way.
Here are the final results:
OEM stalk:
OEM Relay:
