#183 (permalink) |
"NBA"
Someone tried with the 09 and said it's nearly impossible with how much of a curve it has. I tried it today and used GE silicone and it will NOT stick. Seems to have too much tension in the lexan. Any ideas?
#184 (permalink) |
Thee Mike Koscow (maybe)
use a automotive sealnt it's called ultra gray or ultra black (one is gray and one is black also comes in blue, red and clear) lay a beed of that stuff and tape the new flat lens down till dry and it should hold nice. or lay the cut blank that will be your lenses and heat gun and form it on the seal using the ultra gray/black
#186 (permalink) |
"NBA"
Thanks I'll try it tonight. I don't have a heat gun so I'll be using a blow dryer. If the silico0ne doesn't come off properly on the ones I've used I'll just make more cut outs. I bought 2 sheets just in case.
#187 (permalink) |
you can also use urathen intsead of silicons or sealents, also I'm not sure that you will get more heat out of a hair dryer then your fog light will produce but good luck...
you can also bake the sheet or blank and lay it over a mold or the housing but that can be tricky to do.
#189 (permalink) | |
you can try the hair dryer but I dont think that it will get hot enough to soften the lens for it the bend.
#190 (permalink) |
Todd
As far as finding a material to use as a lens, has anyone tried Bayer Apec? It's a polycarbonate similar to Makrolon, which was mentioned earlier in the thread, but has a very high heat resistance (160 degrees celcius with the least heat resistant version, all the way up to 184 C). I can't seem to find any for sale anywhere, and even if I could, it would probably just be the resin, and I don't know how to process that.
#191 (permalink) |
the product that I have is rated to like 230*C it's made by bayer and bayer (the pill guys) it was a little pricey but it's holding
#196 (permalink) |
so i want to do this but i have a problem.
the silvering that is on the housing of the light is shot. has anyone come up with a good way to re-silver it? i've called a few glass shops in the area and none of them do it and say when they send it out its pretty pricey. i am thinking of chrome/silver paint but it would have to stand up to high temps. i also thought of the shiny side of aluminum foil but that sounds way to ghetto=p anyone know of anything to fix this? |
#197 (permalink) |
I have Lexan lenses and have been using them for a couple of months with no bubbling.Last week I installed an 8000k HID kit in there and run them pretty much all the time and no bubbling yet.
#198 (permalink) |
i ended up doing this today and it went from a 8 dollar fix to a 78 dollar fix because my dremel broke and i had to go buy a new one which sucked. took me all day because i was by myself but it came out pretty good. only thing that sucked was putting bumper back on because it was dark out already
LinkBack to this Thread: http://www.8thcivic.com/forums/diy-honda-civic-lighting/121146-cracked-fog-light-lens-replacement-diy.html
| Broken fog lights - Unofficial Honda FIT Forums | This thread | Refback | 09-05-2011 10:47 PM | |
| Fog lights for odyssey the same and how to protect them. - Honda Odyssey Forum : Odyssey Minivan Forums | This thread | Pingback | 08-13-2011 07:59 AM | |
| FS: Honda Civic 2006-2008 Fog Lens Lexan | This thread | Refback | 08-02-2011 08:23 AM | |
| Factory Fog Light lens busted... - Honda Civic Forum | This thread | Refback | 07-03-2011 09:46 AM | |
| Cracked fog light | ViperGuy | Civic SI | 7 | 09-13-2008 10:46 PM |
| fog light cracked | r1ch1e | North-East | 14 | 09-10-2008 09:48 AM |
| fog light lens broke | kshakeylude20 | Civic SI | 3 | 02-13-2008 01:52 PM |
| replacing cracked fog light lens | nandro | Mechanical Problems & Technical Chat | 4 | 01-21-2008 08:38 PM |
| Cracked Fog Light | WaterCop | Lighting, H.I.D.'s, & Neon | 2 | 12-04-2006 06:52 PM |
