#143 (permalink) |
Joey
I know this has been discussed, but does anyone good with electrical know what would be needed to have option 3...
3) The sidemarkers will be on with the parking lamps, and when you turn on the signals they will alternate (wig-wag) with the signals (IF THE PARKING LAMPS ARE ON. if the parking lamps are off they signal like option 1). ...but have it so both blink simultaneously with parkers/ headlights on? Someone I think mentioned you may need a three wire bulb. What about some sort of relay or something? Any insight? |
#146 (permalink) |
Evan
^ Yeah I know, I wanted mine side markers to be on with the parking lights/low beams and also flash insync with the parking lights - so I had to settle for the side markers and parking lights to alternate when they flash.
#147 (permalink) |
Joey
Does anyone know how the Pilot is wired? I saw one today that had sidemarkers and flashed insync with the main signal witht he headlights on. I wouldn't imagine they use a 2 filiment bulb. I wonder if they are using some sort of simple relay?
#149 (permalink) |
Rey
finally got a dremel!!! is it okay to cut a small rectangle like the vid clip then use a grinding bit all the way to the line? would that be fine? and how thin is the fender? i was practicing on the back side of an old tailgate and i think it might have been a little thicker sheet metal then the fender?
#150 (permalink) | |
Andy
With grinding it, you need to make sure it stays straight and even. You can probably use it for the bigger areas, but I recommend sticking to the cutting head, especially in the corners. Remember to take your time and don't rush or force ANYTHING. It will cut and you will break heads.. just be patient. Start in the morning and don't plan anything else. |
#153 (permalink) |
Evan
Anyone have this problem after installing their side markers?
The high beams light comes on very dim sometimes, I wired my side markers to option 3. I have no idea how this could happen but it started happening after I wired them. It's not on all the time, it only comes out every now and then which is weird. Also when I turn on the high beams the light becomes brighter, when I turn the highs off the light gets dim and is still there... Here's a picture with the low beams on only, high beams off. ![]()
#156 (permalink) | |
Andy
#157 (permalink) |
Evan
The picture makes it much brighter, its very dim in person.
It lights up very dim when my low beams are on or when I have all the lights completely off. Anyone else have this issue? Whats the deal? |
#158 (permalink) |
Erik
I have had that issue with my 08 FG2 without any type of electrical work done to it. I always thought it was just me, ha. I found that sometimes turning your lights/hi-beams on and then off seem to fix it. It is very dim but still bothersome, I agree.
#160 (permalink) |
KF
Hi guys,
I was wondering if anybody experienced rust issue after they've installed their side markers. There's snow in my area and I really hope to minimize my chances against rust. Any suggestions? I really want to install side markers on my TW coupe. Thanks *subscribed
LinkBack to this Thread: http://www.8thcivic.com/forums/diy-honda-civic-exterior-style-mods/70037-sidemarker-diy.html
| YouTube - DIY Sidemarkers (Cutting) 06+ Civic - Part 2 | This thread | Refback | 03-01-2008 01:02 AM | |
| YouTube - DIY Sidemarkers (Cutting) 06+ Civic - Part 1 | This thread | Refback | 02-04-2008 07:38 PM | |
| YouTube - DIY Sidemarkers (Cutting) 06+ Civic - Part 2 | This thread | Refback | 01-15-2008 09:34 PM | |
| YouTube - DIY Sidemarkers (Cutting) 06+ Civic - Part 2 | This thread | Refback | 01-09-2008 02:20 AM | |
| Honda » Sidemarker DIY | This thread | Pingback | 12-19-2007 09:18 PM | |
| DIY: my LED replacement guide, basic | tda1337 | Lighting, H.I.D.'s, & Neon | 68 | 11-01-2012 03:35 PM |
| DIY: OEM Navi Conversion to DVD Receiver/Etc. | CameronJr9 | DIY Honda Civic Audio | 62 | 10-26-2012 07:38 PM |
| My adventures in modding: a "Blog" of sorts | Phalanx | North-East | 63 | 10-18-2007 12:09 AM |
