DIY: Plasti dip/paint wheels - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Honda Civic Do It Yourself Articles > DIY Honda Civic Exterior Style Mods
Old 01-02-2013, 09:46 PM   #1 (permalink)
dodtbdm's Avatar
artwilight
whats up guys. i decided to plasti dip the wheels again, but this time i decided to paint over the plasti dip. pretty much using the dip as primer, this way if you dont like the way the color looks afterwards, you can peel it off, and not be stuck with. it took me about 3 hours from prepping to spraying the final clear coat. i was lucky enough to have someone lend me their spare wheels, so i could leave my car outside and prevent over spray. as always, do this at your own risk.
Materials actually used:
plasti-dip(2)
paint-color of your choice(3)
clear coat(1)
painters tape
jack/jackstands
heat gun(optional)
Playing cards(2 decks)
PREP WORK
clean the wheels with soap or anything you like. make sure all the soap is off, and i usually bounce the wheel on the floor to get the excess water off. i let them sit in the sun for a little bit.
brought them inside and started lining the lip with the playing cards. tape off the valve stem, and something i did
different this time was put little tape pieces where the lug goes(see images below). this will prevent the lug from catching the plastidip and
twisting it and ruining it like it did on me when i dipped them white. if you have a shop vac, i would recommend using the blower setting to get most of the water off. wipe off any extra little water, and its time to start.
doing this:
will prevent this:
i did 4 coats, they got heavier as i progressed, i only used 2 cans for all four wheels. i let it sit about 15 minutes
between coats, and i gave each wheel about a 1 minute once over with the heat gun. i didnt stay on one spot too long, but
after that minute you could tell it definately helped.
once you are done with the 4th, i personally waited 30 minutes, with 2 passes of the heat gun before applying the paint.
after that, go ahead and start spraying, use short burst and light coats to avoid getting too much in one area.
i HATE these rustoleum cans. they suck so bad. i would have to spray the ground before spraying the wheels, because with each new
press, it would spit out bubbles/globs of paint. it was annoying, but i was able to get it to work. this was the only bronze
paint i could find locally, and i didnt feel like ordering any online. i did 4 coats of bronze with 1 pass of the heat gun, and waited 45 minutes after the last coat to do the clear coat.
for the clear coat, its pretty easy, the nozzle on this can was way better. i sprayed 3 coats of clear. waiting 15 minutes
and giving it a once over with the heat gun after each pass. they came out a lot better with the clear, than the non clear
finish.
the pictures dont really do it justice. i dont know if i like the way the color came out yet. at least its not permanent.
FAQs
Is clear coat necessary?if your only going to dip the wheels with no paint after, then no. BUT if you apply paint to the dip, i would recommend it. from what i have seen on many other threads on various forums, failure to apply the clear coat after painting them will result in the paint fading fast.
how many coats of plasti-dip should i apply? kind of a tough question, but the thicker you put the plasti-dip on, the easier it will be to take off later. spray it on too thin, and you'll you find yourself sitting there taking it off piece by piece, instead of just pretty much pulling it off in one long pull.
is a heat gun really needed? short answer, no. it was about 60 degrees when i did this, which meant it wouldve taken a lot of time to dry in between coats. i bought a cheap heat gun at harbor freight, and held it about 1 foot away from the wheel and applied heat uniformly for about 1 minute.
thanks for looking, check out my other DIY.
http://www.8thcivic.com/forums/exter...ip-wheels.html
dodtbdm is offline
Old 01-02-2013, 10:48 PM   #2 (permalink)
tiZZle2.0's Avatar
those came out really nice!
great DIY and awesome job!
tiZZle2.0 is offline   Reply With Quote
Old 01-02-2013, 10:54 PM   #3 (permalink)
dodtbdm's Avatar
artwilight
Thanks!
dodtbdm is offline   Reply With Quote
Old 01-11-2013, 12:27 AM   #4 (permalink)
idkfreddy's Avatar
Freddy
Great stuff
idkfreddy is offline   Reply With Quote
Old 01-11-2013, 12:36 AM   #5 (permalink)
dodtbdm's Avatar
artwilight
thanks.
Old 01-12-2013, 04:27 PM   #6 (permalink)
KRAMDARSi's Avatar
looks pretty good! I wish plasti-dip would have been invented years ago!
KRAMDARSi is offline   Reply With Quote
Old 01-12-2013, 04:36 PM   #7 (permalink)
dodtbdm's Avatar
artwilight
Thanks man.
Old 01-19-2013, 11:38 AM   #8 (permalink)
lamboboy732's Avatar
Eric
Wonder if its worth doing this on my nice crappy hub caps until I can get a set of rims.
lamboboy732 is offline   Reply With Quote
Old 01-19-2013, 03:00 PM   #9 (permalink)
dodtbdm's Avatar
artwilight
it's up to you man. It's not permanent.
Old 01-21-2013, 09:14 PM   #10 (permalink)
Question... How did you take the tape off the lug holes when you finished without tearing the plasti dip? Wouldn't the plasti dip have formed a connected between the tape and rim?
Spooned_Civic is offline   Reply With Quote
Old 01-21-2013, 09:50 PM   #11 (permalink)
dodtbdm's Avatar
artwilight
it didnt stick to it. i also tried not to cake it on in that area. for removing the tape i just used a screw driver to push it through the hole.
Old 02-05-2013, 10:04 PM   #12 (permalink)
ive been painting with Duplicolor for years! tried rustoleom and had the same results! I hate how it "spits" every first spray lol
bb1lovin is offline   Reply With Quote
Old 02-05-2013, 10:10 PM   #13 (permalink)
dodtbdm's Avatar
artwilight
lol. yeah i hate it. its my first time using spray paint really. i found a local art store that carries a big variety of colors from montana spray paint, and from what ive heard, its really good paint.
Old 02-15-2013, 03:54 AM   #14 (permalink)
Those turned out nice!
ZetaPhoenix is offline   Reply With Quote
Old 02-15-2013, 04:37 AM   #15 (permalink)
JDM_ROB's Avatar
Robert
Real nice!!!
JDM_ROB is offline   Reply With Quote
Old 02-15-2013, 07:22 AM   #16 (permalink)
caleb1989's Avatar
Caleb
looks great, love those rims!
caleb1989 is offline   Reply With Quote
Old 02-15-2013, 09:37 AM   #17 (permalink)
CCTXdiver's Avatar
Randy
+1 rep
CCTXdiver is offline   Reply With Quote
Old 02-15-2013, 11:51 AM   #18 (permalink)
K20 Wayne's Avatar
Wayne
Nice did u do any wet sanding before hand
K20 Wayne is offline   Reply With Quote
Old 02-15-2013, 12:10 PM   #19 (permalink)
xrs54's Avatar
Nice! May try this this Spring.
xrs54 is offline   Reply With Quote
Old 02-15-2013, 04:34 PM   #20 (permalink)
dodtbdm's Avatar
artwilight
Nah, no wet sanding, just cleaned it with soap and water.
DIY: Plasti dipped wheels... with a twist! MyNamesMatt Inside and Out 110 05-20-2013 05:11 PM
DIY: White Plasti Dip Wheels dodtbdm DIY Honda Civic Exterior Style Mods 190 02-23-2013 06:49 AM
My wheels with plasti-dip CvcSi2008 Inside and Out 49 12-14-2011 07:07 PM
What do you use to clean your plasti dipped wheels? Stryderhiro Wheel And Tire Upgrades 2 07-17-2011 08:58 PM
about to plasti dip my wheels, few questions! fg2churppin Wheel And Tire Upgrades 5 02-12-2011 03:48 PM
