P2R spacer and gaskets install - Page 4 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Honda Civic Do It Yourself Articles > DIY Honda Civic Engine
Old 08-13-2007, 11:07 AM   #61 (permalink)
MutantCheese's Avatar
2008 NFR S2000
Originally Posted by Excelerate
The easiest way to remove the studs is to lock two nuts together back to back on the studs and then remove the stud.
BTW, you need to turn the inside nut. I just used my old faithful vice grips.
MutantCheese is offline   Reply With Quote
Old 08-13-2007, 06:26 PM   #62 (permalink)
I just got mine today, will be attempting this install tonight... but did anyone notice the gaskets do not line up with the spacer 100%? I might have to dremell out a little on each gasket.
fd to fg2 is offline   Reply With Quote
Old 08-13-2007, 06:34 PM   #63 (permalink)
GlxyGry06Si's Avatar
keep us informed cuz mine should get here on thursday
Old 08-13-2007, 07:04 PM   #64 (permalink)
iomatic's Avatar
No, I did not notice anything odd... are you sure everything's oriented correctly?
iomatic is offline   Reply With Quote
Old 08-13-2007, 09:16 PM   #65 (permalink)
yes, everything is correct, I will have to dremell about 2mm off the insides of each gasket... who measure's these before they get sent out? I can say that this would cause an slight restriction in the airflow...
FD to 8th gen Si is offline   Reply With Quote
Old 08-13-2007, 09:19 PM   #66 (permalink)
who did you buy this from?
Old 08-13-2007, 09:20 PM   #67 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
Hmmm... Wonder if all the gaskets were like this...
I should receive mine in a few days, and I will definitely check mine and report if there is any defects.
*crosses fingers*
Old 08-13-2007, 09:21 PM   #68 (permalink)
got it from Corsport...
Old 08-13-2007, 09:22 PM   #69 (permalink)
i ordered mine today from them. i hope mine will be all good cuz i dont have a drimmel
Old 08-14-2007, 01:36 AM   #70 (permalink)
Thanks Excelerate, this helped allot. The factory bolts weren't that tight.
I don't have a torque wrench, so I tighten it pretty tight.
Odd that I found the nylon gaskets slightly needed a little trimming to match the P2r spacer. Added an extra 1/2 hr or so. I'm not a great mechanic so it took me close to two hrs. My hands are all cut up.
After all, reset the ECU, when for a rip, I believe the response is better, but couldn't drive it that much, have to get some sleep.
Old 08-14-2007, 08:44 AM   #71 (permalink)
CBRGuy954rr's Avatar
i called p2r about the way the gaskets fit, and they told me not to trim them to match. they said "that is the way we used they and them made power" so i have not trimmed them.
CBRGuy954rr is offline   Reply With Quote
Old 08-14-2007, 09:42 AM   #72 (permalink)
2008 NFR S2000
Did everyone else but me reset their ECU?
Old 08-14-2007, 10:30 AM   #73 (permalink)
skiz's Avatar
Nee-kon Squad! #5 | Nikon D700
subSCRIBEd... hmmmm, plenum volume FTW.
skiz is offline   Reply With Quote
Old 08-14-2007, 10:35 AM   #74 (permalink)
I reset my ECU.
Old 08-16-2007, 10:50 PM   #75 (permalink)
just did the install. i want to feel a difference but i think i feel its more peppier. i definatly, definatly makes the throttle body a lot cooler. its definatly worth it. Great diy. it helped a lot. thanks
Old 08-16-2007, 11:05 PM   #76 (permalink)
slow4drsi's Avatar
did u used long bolts? cause it added like 3/4 of an inch right
slow4drsi is offline   Reply With Quote
Old 08-16-2007, 11:06 PM   #77 (permalink)
yeah it comes with the bolts. the spacer is 3/4 and two spacers. its prolly like an inch. make sure you get a new radiator hose too.
Old 08-16-2007, 11:43 PM   #78 (permalink)
Excalibur's Avatar
Jeremy
So now does you intake pipe hit the battery tray?
Old 08-16-2007, 11:49 PM   #79 (permalink)
CaliGuy's Avatar
J. M. back by popular demand!
I reset my ECU also. I do after any engine mods...
http://i61.photobucket.com/albums/h52/jbpray/cali-1.jpg
Old 08-17-2007, 06:49 AM   #80 (permalink)
no.
keeping track ... mods + dyno numbers sickyute Bolt-Ons And All-Motor 130 10-03-2012 11:04 AM
p2r spacer... rkalloo Mechanical Problems & Technical Chat 1 08-02-2011 01:29 PM
P2R throttle body spacer info ... !!!! sickyute Intake & Spacer Discussion 69 05-20-2011 09:43 AM
Skunk2 Pro Series TB with P2r Spacer & Gaskets NewYorkJon Intake & Spacer Discussion 15 06-25-2007 08:02 PM
Injen CAI + P2R TB Spacer Question NewYorkJon Intake & Spacer Discussion 4 06-24-2007 09:53 AM
