Center Console removal for Aux input install - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Honda Civic Do It Yourself Articles > DIY Honda Civic Audio
Old 03-31-2006, 07:02 PM   #1 (permalink)
Sorry about any lack of clarity this is my first write up ever. I dont actually have the part do complete the instalation but someone had asked about how hard it was so here you go: (this is based on my lx 5spd sedan but it should be pretty much the same for everyone)
Pull down on the top of the boot that connects to the shifter it just snaps in place, then unscrew the shift knob.
Pull in the circled areas starting on the right to remove the part around the shifter.
Pull starting at the bottom and working up the panel towards the stereo, I marked the approximate locations of the clips in green for reference.
The plug that the aux input connects to.
The bottom of the console is already marked for where to drill.
After that its all in the instructions for the aux input install you can get online, this was just to help clarify how to get the console apart.
ethlar is offline
Old 03-31-2006, 10:00 PM   #2 (permalink)
Skyline's Avatar
Cool, thanks
I plan on doing this myself as soon as school lets out for summer.
Skyline is offline   Reply With Quote Quick reply to this message
Old 04-03-2006, 10:36 PM   #3 (permalink)
Would you mind doing something really nice that might save some people some $$ for this little adaptor. I'm planning on installing my XM radio permanently in my Civic. Doing so, I want to plug it in the Aux input instead of using the RF signal. So, what would be nice is to have someone check the pinout of this little white connector. You just need to check which wire goes with which 1/8 Left/Right/Gnd. That would make people save in the 50$ US...
Thanks
WiDeFiRE is offline   Reply With Quote Quick reply to this message
Old 04-04-2006, 12:09 AM   #4 (permalink)
I'm gonna have to do this mod but I dont have the tools so thats a sucky situations.
Chris Dillon is offline   Reply With Quote Quick reply to this message
Old 04-04-2006, 08:48 AM   #5 (permalink)
Skyline's Avatar
All you really need is a drill, right? Surely you can track one down somewhere.
Old 04-04-2006, 10:10 AM   #6 (permalink)
i believe the part also includes a resistor somewhere to tell the head unit that the aux plug has been installed.
all thats needed is a drill and 2 size bits, everything else comes apart by hand.
ethlar is offline   Reply With Quote Quick reply to this message
Old 04-04-2006, 11:35 AM   #7 (permalink)
If you can manage the schematic of this little adaptor, you would do my day!
Old 04-04-2006, 05:22 PM   #8 (permalink)
razer's Avatar
thanks for the info! i need this.
razer is offline   Reply With Quote Quick reply to this message
Old 04-19-2006, 06:50 PM   #9 (permalink)
Instructions for Automatic Center Console removal
Hey does anybody know how to remove on the center console on a 06 Civic LX Automatic. I believe it's a bit different from what is listed above.
wavetekcivic is offline   Reply With Quote Quick reply to this message
Old 04-19-2006, 09:49 PM   #10 (permalink)
I would be interested to know how to take off the consoles for auto as well. Anybody knows?
Tate is offline   Reply With Quote Quick reply to this message
Old 04-19-2006, 09:54 PM   #11 (permalink)
i have no experience with the auto shifters for honda, but on my friends stratus, there was a single screw to remove and then the shifter came right off. i think after that the removal should be pretty much the same.
Old 04-19-2006, 10:43 PM   #12 (permalink)
I figured it out
Hey I guess I was able to answer my own question. I was over looking the hole the thing. Basically the the whole console just pops out. Just push inward but make sure you don't use to much force and pop the tabs. Everything else is basically like the pictures in this tread... My installation was not the cleanest (I couldn't get two of the screws to line up with the screw holes) on the inside but it looks professional on the outside. Sound quality is great on my IPod...much better than I expected.
Old 05-05-2006, 07:03 AM   #13 (permalink)
Is the aux input under the console normally connected to the input jack? Or is this an additional plug?
- Dave
disdigg is offline   Reply With Quote Quick reply to this message
Old 05-05-2006, 06:19 PM   #14 (permalink)
this is for the people whos cars dont come with the aux input already connected. i think its something like only DX coupes and DX/LX sedans that this applies for?
Old 05-08-2006, 10:02 AM   #15 (permalink)
tchouch's Avatar
I find the électrical schem for canadian owner. (see the attach files)
I think one of the wired have a 12v continuous.
But i don't knoe the "aux det" and "aux sgnd"
Someone can help. I don't want paid 110$ cnd+tx for the oem parts.
thanks a lot
tchouch is offline   Reply With Quote Quick reply to this message
Old 05-08-2006, 02:24 PM   #16 (permalink)
PokeyD16Z's Avatar
thanks a lot
Pinout for Aux Input on LX
Also, this can't be used on the DX...the DX wiring harness does not have the connector (as it doesn't have a stereo either).
PokeyD16Z is offline   Reply With Quote Quick reply to this message
Old 05-08-2006, 05:17 PM   #17 (permalink)
my bad, im in the midst of finals so if it doesnt have to do with engineering im not all here mentally.
Old 05-24-2006, 08:16 PM   #18 (permalink)
GlennS's Avatar
Thank you for this useful post.
In my car, I had the "cup holders get hot" issue and had to take this same console off to fix the seperated heater ducts. (The ducts in the pics in this post are mated properly--but in some of our cars they are seperated.)
Anyway, to remove the shifter console in an automatic transmistion car, put the car in drive-D-to center the shifter over the metalic-looking, plastic trim ring you'll be removing: You can pop off that metal-looking, plastic trim ring around the AT shifter by getting your fingernails under its edges and lifting straight up. Then, again with your fingernails, start at the back of the black, plastic console and lift straight up, working from the back, towards the dashboard/stereo. Work it off slowly and soon you'll see the aux. plug (and heater ducts).
Regards,
Glenn in CT
GlennS is offline   Reply With Quote Quick reply to this message
Old 06-12-2006, 07:41 PM   #19 (permalink)
ericso's Avatar
Hi there, here in mexico the EX model, as mine doesn't come with the aux jack, so i'm planing to install it but I need to know the part number to order it back in the dealership, 'cause they couldnt find it as the part doesn't come with the EX model. I'm hoping that the wire harness is inside. So if you could help me telling me the part number and what do I need to install it all.
Thanks form Mex
ericso is offline   Reply With Quote Quick reply to this message
Old 06-14-2006, 01:14 PM   #20 (permalink)
locoJack's Avatar
Me tooo, I like to know anyone have install or how to remove the console for Auto LX 06? Picture would be very appreciated.
locoJack is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Log-in
Human Verification
You may post replies
LinkBack to this Thread: http://www.8thcivic.com/forums/diy-honda-civic-audio/5351-center-console-removal-aux-input-install.html
HondaHybridClub.nl • View topic - AUX kabel (DIY) This thread Refback 09-12-2011 11:19 AM
Pregunta USB new civic? - Foros Hondaclub Argentina This thread Refback 09-09-2011 03:55 PM
Pregunta USB new civic? - Foros Hondaclub Argentina This thread Refback 09-09-2011 11:38 AM
Pregunta USB new civic? - Foros Hondaclub Argentina This thread Refback 09-09-2011 09:38 AM
AUX Civic 4D 2008 - Honda Civic Club This thread Refback 09-08-2011 07:54 AM
2006 Civic Auxiliary Jack Installation. - Honda Civic Forum This thread Refback 09-04-2011 06:59 PM
Comment retirer la console centrale (ventilation/radio/etc) ? - Club Civic Quebec :: Forum This thread Refback 08-29-2011 01:25 PM
Comment retirer la console centrale (ventilation/radio/etc) ? - Club Civic Quebec :: Forum This thread Refback 08-18-2011 06:31 PM
Comment retirer la console centrale (ventilation/radio/etc) ? - Club Civic Quebec :: Forum This thread Refback 08-14-2011 08:57 AM
Comment retirer la console centrale (ventilation/radio/etc) ? - Club Civic Quebec :: Forum This thread Refback 08-12-2011 09:31 PM
2006 Civic Auxiliary Jack Installation. - Honda Civic Forum This thread Refback 08-06-2011 01:22 PM
2006 Civic Auxiliary Jack Installation. - Honda Civic Forum This thread Refback 08-04-2011 12:46 AM
2006 Civic Auxiliary Jack Installation. - Honda Civic Forum This thread Refback 07-16-2011 01:33 PM
Untitled document This thread Refback 07-12-2011 05:35 AM
Cevap: 2007 Honda civic Sedan Aux ba?lant?s? This thread Refback 06-24-2011 12:30 PM
Pinout for Aux Input on LX - Page 5 - 8th Generation Honda Civic Forum This thread Refback 03-05-2008 01:33 AM
Untitled document This thread Refback 02-28-2008 02:08 AM
PodCentral.PH - honda civic Civic 1.8 V This thread Refback 02-26-2008 08:14 PM
XM satelite radio installed - Acura CSX Forums This thread Refback 02-25-2008 04:35 PM
Untitled document This thread Refback 02-13-2008 05:24 PM
shift knob help - Acura CSX Forums This thread Refback 02-10-2008 10:55 PM
Honda Civic Sedan 2006 - CarSpace Automotive Forums This thread Refback 02-10-2008 04:16 PM
Audio [Archive] - 8th Generation Honda Civic Forum This thread Refback 02-04-2008 11:53 AM
12v Key Off Aux Power - Honda Civic Electrical, Wiring, and In Car Entertainment - Honda Civic Forum This thread Pingback 01-31-2008 02:17 PM
Honda Civic Sedan 2006 - CarSpace Automotive Forums This thread Refback 01-19-2008 10:03 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-04-2008 05:19 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-03-2008 08:32 AM
Audio - 8th Generation Honda Civic Forum This thread Refback 12-20-2007 05:05 AM
2006 Civic Auxiliary Jack Installation. - 8th Gen Honda Civic - Honda Civic Forum This thread Refback 12-19-2007 10:57 PM
Untitled document This thread Refback 12-14-2007 04:59 AM
Honda Civic Sedan 2006 - CarSpace Automotive Forums This thread Refback 12-06-2007 11:24 PM
Center console and lower dash heating up. psyshack Mechanical Problems & Technical Chat 29 01-22-2016 02:29 PM
