DIY: A better Bluetooth phone/A2DP upgrade (w/ auto-switch to AUX)
This turned out to be quite a fun project! This is my first 8thcivic.com DIY, so message me if any descriptions or pictures could be clearer.
SCOPE OF PROJECT: Integrate an inexpensive Bluetooth phone/music system with the factory audio system in my 2008 Civic Si. I first tried the Grom Audio USB/iPod/AUX interface car kit, and added the optional Bluetooth module. (~$180 total) It a was thoroughly disappointing experience. I searched for other options, offering either better functionality or a lower price. I settled on hacking the very reasonably-priced (~$35 on eBay) Jensen BT360 Universal Bluetooth add-on kit. (It appears to be sold overseas under other brands [Triamp/Viseeo] & models [CK-360/CK-361/VK-Q2].) ![]() The BT360 is a mid-range model from Jensen. Cheaper models don't have LCD displays or A2DP support, and more expensive models use big ugly LCD displays & include a wireless remote mounted to your steering wheel. My preferences leaned towards an unobtrusive display with a wired remote control, but this modification will work with any similar Bluetooth setup. As shipped, the BT360 is a mish-mash of audio outputs and features. Bluetooth phone audio is played through an external speaker that mounts under the dash, and A2DP music playback is broadcast by an internal FM transmitter. A "mute" output wire activates during incoming or outgoing phone calls, so if your car stereo has a mute input, the sound will be muted until your call ends. It's intended installation is pretty easy (only 3-4 wires), but not quite what I'm looking for. I'm a hacker, so let's hack it up! ![]() PROJECT GOALS: 1. Get rid of the included external speaker and have the phone audio routed to the existing front speaker(s). 2. Bypass the FM transmitter and wire the A2DP (music) output directly to the AUX input of my Honda navigation system. 3. When a phone call comes in, have the factory radio automatically switch to the correct audio input. 1. HACKING THE BT360: I originally intended to use a DPDT relay to connect the Bluetooth box to my left front speaker, switching the speaker to the Bluetooth box whenever a call was active. But while testing the BT360, I found that the phone audio was also output over the FM modulator, not just to the external speaker output. Based on the rest of my project, this modification to the speaker wiring was no longer needed. Next, I needed to determine if I could bypass the FM transmitter and grab the R/L audio signals directly. Inside the BT360 box, the FM transmitter module was easily located. Luckily, the R/L/Gnd pins were clearly marked, and a quick bit of soldering ran both signals out to a mini-headphone cable. ![]() ![]() 2. DESIGNING THE ADAPTER BOX: It would've been easy enough to just plug the Bluetooth audio into the existing AUX jack. But, that would be ugly, and I wanted the radio to automatically switch to the Bluetooth phone audio when a call comes in. As mentioned in several other DIY articles here, the original AUX jack has five/six pins. Three are for audio (R/L/Gnd) and two connect to a switch. When a cable is plugged in, the switch is activated, and the radio selects the AUX input. So, all we have to do is wire the Bluetooth box "Mute" output to short these pins, right? Not quite that simple, if we want to keep the AUX jack usable. If something is plugged into the AUX jack but you are listening to a different source (FM/CD/etc), shorting those pins won't switch the radio to AUX, because they are already shorted together. I could've lived with the limitation, disabled/removed the AUX jack, or hacked together a working solution. Guess which one I picked? ![]() The radio switches to AUX when it senses a cabled plugged in. So, to automatically switch to the AUX input, we must simulate unplugging and replugging the AUX jack. I found that a ~1/4 second delay was needed for the radio to sense the change. (With anything shorter, the radio didn't notice the change.) After investigating at a few possibilities for inserting a short delay (555 timer, etc), I came up with an easy solution using only a few simple components. A small capacitor is used to supply a short burst of power to a relay. The relay is wired to have the AUX jack's switch wires connected together by default ("NC" - normally closed), and it then disconnects them for a short time when "Mute" becomes active. I tried several capacitor values, and found that 330 uF would power my relay for ~1/4sec. The capacitor is charged through a resistor, which has to be small enough to quickly charge the capacitor, but large enough to keep the relay from staying "on" after the capacitor is discharged. In my case, ~5k ohm worked out about right. Because I wanted to keep the AUX jack functional, I need to be able to disconnect any incoming audio when a phone call is active. A "dual pole" relay passes the AUX jack R/L signals along to the radio. When the "Mute" line is active, the relay is activated and interrupts the incoming AUX audio. ![]() How to determine capacitor/resistor values for your relay: 1. Test several capacitors by charging them with 12V and then connecting across the coil on your relay. Find the value that activates the relay for about 1/4 second. (probably 200uF-1500uF) 2. Power your 12V relay through a 1/2W (or larger) potentiometer set to 0ohm, and increase the value until the relay turns off. (I used a 50K pot, and found that my relay turned off at about 4K. I rounded up to 5k to be sure it would turn off reliably.) 3. BUILDING THE ADAPTER BOX I bought the smallest, lowest-power 12V DPDT relays at my local electronics shop. They are only rated for switching 1A, but that's plenty for our purposes. (You could also use 2 DPST relays, or a DPST and a SPST relay, all with "NC" contacts.) A few CD-audio cables were recycled to connect the AUX jack and radio's AUX input. (CD-audio cables are only 4-pins, so the pins were moved over to a 5-pin connector) A 5-pin male-male connector adapts the modified CD audio cable to connect to the female AUX cable from the radio. A stereo mini headphone jack is the input for the Bluetooth box's audio output. Everything was assembled on a small Radio Shack circuit board and mounted in a small (1"x2"x3") project box. Total cost was about $20, buying all the parts locally at retail prices. Purchase from Digikey or Mouser, and you'll probably be closer to $10. ![]() ![]() 4. PUTTING IT ALL TOGETHER ![]() I used information from the various DIY threads here to remove the dash panels and center console. Power was tapped from the main radio connector, using 3M T-Taps for easy removal down the road. (Pin 10 is constant 12V, Pin 13 is switched 12V) My adapter box gets its power from the bluetooth box harness. The Bluetooth box and adapter box were mounted in the center console, in the empty space under the front pocket. Ground was connected to a mounting screw in the center console. ![]() I decided to mount the controls to the left of the steering column, after moving the VSA button. The controls are easily visible from the drivers seat, and are close to the existing steering wheel audio controls. Microphone was installed on the other side of the steering wheel, behind the empty 3-slot opening near the ignition switch. ![]() 5. DONE! - DOES IT WORK? Bottom line? It works pretty darn well for ~$50. The display/control box doesn't "fit in" with the stock interior as well as I would like, but it's not too bad. (It looks worse in the pictures - it blends with the dark panels in real life.) Benefits: About $50 installed - can't beat that! If I'm listening to FM/AM/CD when a call comes in, the radio switches over to AUX automatically. If I have an iPod plugged in to AUX when a call comes in, it mutes the iPod audio automatically. I've been told that the call quality is quite good. (People can hear me just fine) Play/Pause/FFWD/RWD controls all work well with my Android music playback software. Long-pressing the "End Call" button lets me voice dial my Android phone. (Long-pressing "Answer Call" button redials last number) Downsides: A2DP audio doesn't have the same deep bass as a direct cable from phone to AUX jack. (The sound quality is about the same as the ~$180 Grom setup, so is probably a limitation of A2DP) After a call disconnects, the radio stays on AUX. (Good if I was listening to Pandora/iPod/etc, bad if I was listening to FM. But, one button press on the steering wheel controls takes it back to FM) Buttons on control panel aren't illuminated. Last edited by awoolf; 02-09-2012 at 11:16 AM. |
Awesome! this is what i was looking for! Just got my BT 390 (same as 360 except for the remote is wireless).
One question: I understood the part of soldering R/L and Ground from the small FM board, but how did you disable FM module? |
#7 (permalink) | |
So, I just left the FM tramsmitter module in place. I'm grabbing the audio as it goes into the FM chip, so it doesn't matter what frequency it transmits on. The antenna connects to the vehicle ground, so removing it should greatly reduce the range of the FM signal. (It's the black wire snaking across the board in the pic below)
#11 (permalink) | ||
They shipped the item with the wrong firmware. The included manual didn't match the functionality of the item. Nowhere on the website was a real manual for the "XM-emulation" mode; I had to request it from their tech support. The controls are VERY counter intuitive. Here are a few excerpts from my support email thread with Grom: Quote:
Does this answer your question? |
#12 (permalink) |
JMark
It absolutely answers my question. Sorry to hear about your bad experience. I suppose I am lucky to not have those issues. I went with GROM mainly because I wanted something that would let me use the steering wheel controls to skip tracks and it does just that. I have Beats audio baked into the ROM on my phone so that it increases bluetooth audio quality.
#18 (permalink) | |
Zimmer
Sent from my SGH-T999 using Tapatalk 2 |
| A2DP Bluetooth Integration Kit for '07 Si? | citenx | I.C.E., Electrical, Security, & Navigation | 3 | 04-20-2010 08:35 AM |
| How do I set up my phone with the bluetooth? | GT1 | I.C.E., Electrical, Security, & Navigation | 2 | 05-07-2008 12:47 AM |
| Bluetooth phone with 2007 Civic EX w/ navi | Pins | I.C.E., Electrical, Security, & Navigation | 2 | 10-27-2006 01:27 PM |
