Installing 165ca1 - Focal 6.5" 2 Way Coaxial Speakers without cutting your sedan - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Honda Civic Do It Yourself Articles > DIY Honda Civic Audio
Old 12-14-2008, 11:53 PM   #1 (permalink)
r3v
r3v's Avatar
Rachel
Today is my birthday. One gift I received is 165ca1 - Focal 6.5" 2 Way Coaxial Speakers. So I had to face the dilemma—give up the dream speakers or cut my car.
I don’t own a saw.
So, when my friend came over with his saw, he presented this genius idea—invert the inserts from the grills!
Here we go!
You should probably install some washers on the back of your screws, so you’ll have to fold back the plastic stuff. Watch out for that nasty stick stuff beneath:
Take everything out, then. . .
First you pop the insert out of the speakers.
Then you remove the nasty glue.
You hold the speakers up and mark and drill holes.
In addition to the stuff that came with the speaker, you add some insulating—that stuff for windows from any hardware store is best.
Then you line up the holes and screw in the screws
And put your car back together
and check out your cats having a convention during the install.
I know this is some very speaker-specific information. But, although I think everyone deserves a set of Focals, I hope this also can help you out with other oversized 6.5" speakers.
r3v is offline
Old 12-14-2008, 11:54 PM   #2 (permalink)
Zeuceone's Avatar
lol wut
Old 12-14-2008, 11:58 PM   #3 (permalink)
tearsofblood139's Avatar
Angel
nice DIY
tearsofblood139 is offline   Reply With Quote
Old 12-14-2008, 11:58 PM   #4 (permalink)
SOLO8thGenSi's Avatar
Joey | Yoey | Joeh | OCD-boy
lol cats.
always there to lend a helping-paw
SOLO8thGenSi is offline   Reply With Quote
Old 12-15-2008, 12:01 AM   #5 (permalink)
ILDS™
jrMartinez24's Avatar
Rickeh™
nice DIY
jrMartinez24 is offline   Reply With Quote
Old 12-15-2008, 12:32 AM   #6 (permalink)
Si Speed 317's Avatar
Dan- GT30R Fanboi
Job well done
Si Speed 317 is online now   Reply With Quote
Old 12-15-2008, 12:35 AM   #7 (permalink)
24boosted's Avatar
Hows it sounding now?
24boosted is offline   Reply With Quote
Old 12-15-2008, 12:37 AM   #8 (permalink)
r3v
r3v's Avatar
Rachel
OMG! I knew my Alpines were crap. But now I KNOW they were. With my test CDs, I even heard the rustling of paper from the live audience from a really well-recorded show.
I want to sell my house and move into my car . . .
r3v is offline   Reply With Quote
Old 12-15-2008, 01:21 AM   #9 (permalink)
Purpul Plane 4ever!
Nomar06's Avatar
were the kitties yelling out instructions???
Originally Posted by mattsbobo View Post
Personally I like to wear my Ted Nugent-esque loincloth, grab my bow and arrows, and my half gallon of scotch then I go terrorize my apartment complex.
Nomar06 is offline   Reply With Quote
Old 12-15-2008, 01:27 AM   #10 (permalink)
r3v
r3v's Avatar
Rachel
immer so.
my kitties are teh bomb.
Old 12-15-2008, 02:21 AM   #11 (permalink)
How do they sound compared to the Alpines? What did you do with the Alpines? Place them on the rear deck?
Thnx
vlonjati is offline   Reply With Quote
Old 12-15-2008, 03:46 AM   #12 (permalink)
Thnx
If you are comparing side by side installs of the same speakers, The focals will be smoother, less bright, more detailed, and yield more midbass.
lyttleviet is offline   Reply With Quote
Old 12-15-2008, 03:49 AM   #13 (permalink)
Also, anyone wanting a complete seal, just build a 1/2" MDF or Birch ring.
Old 12-15-2008, 11:41 AM   #14 (permalink)
r3v
r3v's Avatar
Rachel
Thnx
lyttleviet answered your sound comparison question better than I would have.
I already have alpines in the rear deck, so I'm just going to sell the fronts to a friend of a friend.
An MDF ring worked out fine in the rear, but there wasn't enough room to place a ring and the speaker--either the plastic or the metal would have to be cut. Maybe birch would have been ok.
Old 12-15-2008, 01:16 PM   #15 (permalink)
Micah's Avatar
micah
happylate b-day
Micah is offline   Reply With Quote
Old 12-15-2008, 03:15 PM   #16 (permalink)
splew's Avatar
Andrew
You probably should have sprayed a little rattlecan primer on those holes you drilled for rust protection. Although it's probably no big deal. Little or no moisture gets on the inside of the door.
splew is offline   Reply With Quote
Old 12-15-2008, 03:31 PM   #17 (permalink)
r3v
r3v's Avatar
Rachel
I know. I thought of that after the fact. Even though I had used primer for the cargo net install. Oh well. I've already ripped my door panels apart 3 times now. When the 4th time comes around, I'll touch it up.
Old 12-18-2008, 12:26 PM   #18 (permalink)
JeShUa's Avatar
50 LOW
You should add how to take the doors off or a link to it.
Also is the wiring straight forward from stock LOL.. I've never dealt with speakers.
Old 12-18-2008, 01:52 PM   #19 (permalink)
r3v
r3v's Avatar
Rachel
Well, I used the factory wiring, but bypassed the factory amp and wired them to my amp in the trunk. When I had originally wired the Alpines, I had to use a little wire adapter that Crutchfield sent me. (If you order your speakers from Crutchfield, they'll send you one too.)
And you are right. There are lots of good instructions out there for the coupe, but no one seems to share too many instructions for the sedan.
To take the doors apart on a sedan:
1. Pull the window and door lock panel off:
Squeeze the little plastic tabs and unplug the wires in the bottom. Two sets for the driver, one for the passenger.
Sorry, but I don't have any pictures for the rest of this
2. This will reveal one screw.
3. On the handle, you unscrew one Phillips screw and pop out one of those little plugs where you push in the middle and pry off the sides. This thing is not easy to remove.
4. Pop the door panel off. Start by the speaker grill and pull. You will have to lift up to get the window sealant off.
5. From behind the door panel, squeeze the 4 tabs around the door handle and hove it through the hole in the door.
6. You can now install your speakers.
Old 04-10-2011, 02:41 AM   #20 (permalink)
akaidabat's Avatar
Tono
Pic on final product ?
akaidabat is offline   Reply With Quote
installing component speakers pirate0 I.C.E., Electrical, Security, & Navigation 9 06-07-2010 02:11 PM
installing speakers tacovic18 I.C.E., Electrical, Security, & Navigation 10 05-03-2009 03:06 PM
Focal Speakers or Alpine JamesDee I.C.E., Electrical, Security, & Navigation 8 11-14-2008 02:46 PM
Installing Rear HFP lip for Si sedan, cutting? asdf Inside and Out 12 10-10-2008 12:44 AM
Question about installing speakers skippy911 I.C.E., Electrical, Security, & Navigation 10 03-24-2007 01:11 PM
