COBB AccessPORT Launch Control - Request for Launch RPM Preferences - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > ECU Tuning Information > Cobb Tuning
View Poll Results: Choose Two Launch Control RPM Settings - One For Street and One For Strip
1,000-1,500RPM 4 4.30%
1,500-2,000RPM 2 2.15%
2,000-2,500RPM 2 2.15%
2,500-3,000RPM 12 12.90%
3,000-3,500RPM 29 31.18%
3,500-4,000RPM 37 39.78%
4,000-4,500RPM 18 19.35%
4,500-5,000RPM 15 16.13%
5,000-5,500RPM 6 6.45%
5,500-6,000RPM 7 7.53%
6,000-6,500RPM 1 1.08%
6,500-7,000RPM 4 4.30%
7,000-7,500RPM 2 2.15%
7,500-8,000RPM 0 0%
8,000-8,500RPM 2 2.15%
Multiple Choice Poll. Voters: 93. You may not vote on this poll
Old 06-04-2009, 03:19 PM   #1 (permalink)
The AccessPORT now has the ability to support Launch Control (LC) with our OTS maps. We have tested this feature in-house and with our existing Beta testers and this feature works as expected. Simply put, this ECU has a Stationary Rev Limiter that stops engine acceleration when the car is at a stand still. We have modified these table settings to provide a more effective means of launching the vehicle from a stand still. The stock stationary rev limiter is fairly slow so we modified these table settings to provide quicker stutter step.
To use Launch Control you would simply load a map with the appropriate Launch Control RPM setting (example Stage2+AEMSRI v100 3500LC) and the car will use existing logic to provide you with a more effective stutter step at 3,500 RPM to allow you to launch the car more consistently.
Please be advised that you can break all sorts of stuff (axles, clutch, pressure plate, etc.) by launching your vehicle from a standstill.
This poll is designed to allow you to choose what RPM range we should set launch control at in our current OTS maps. This is a multiple choice poll, so we would like you to make two choices, one for a street launch setting for every day use, and one for a drag strip launch you could load for the track.
This will be a configurable setting through the AccessTUNER software, allowing you to customize your Launch Control settings appropriate for your modifications and driving style.
Take care,
COBB Calibration Team
COBB Tuning is offline
Old 06-04-2009, 03:29 PM   #2 (permalink)
jdmcoupe's Avatar
Roy
You guys are on point good job Cobb!
jdmcoupe is offline   Reply With Quote
Old 06-04-2009, 03:31 PM   #3 (permalink)
DatBigDude's Avatar
nice im the first voter...
DatBigDude is offline   Reply With Quote
Old 06-04-2009, 05:38 PM   #4 (permalink)
Stephen
Now is this going to attempt to hold it at that rpm until the wheels get good traction or is it just going to bounce there and then when you take off go straight to redline thus still requiring me to melt down my clutch.
w00t692 is offline   Reply With Quote
Old 06-04-2009, 05:40 PM   #5 (permalink)
maxxnitro88's Avatar
Greg
yes, all they are changing is the rev limit. this is because it is necessary to work within the limited parameters of the stock ecu.
maxxnitro88 is offline   Reply With Quote
Old 06-04-2009, 05:41 PM   #6 (permalink)
Danny
it's just a 0mph rev limiter function, the same as stock, they're just asking you where you want them to put it...heh.
lessthanwise is offline   Reply With Quote
Old 06-04-2009, 05:41 PM   #7 (permalink)
Admin Ninja
obert's Avatar
obert
Very nice !!!!
Old 06-04-2009, 05:54 PM   #8 (permalink)
LC works GREAT
voted. . .
mitsukaiSI is offline   Reply With Quote
Old 06-04-2009, 05:57 PM   #9 (permalink)
realxlai's Avatar
M. Bison
after taking my car to the track on slicks I voted for 7K
5500rpm wasn't doing it for me.
realxlai is offline   Reply With Quote
Old 06-04-2009, 06:00 PM   #10 (permalink)
Danny
that brings a valid point...what limit for what power level / application...
street/track/strip launch calibrations?
Old 06-04-2009, 06:03 PM   #11 (permalink)
realxlai's Avatar
M. Bison
well if you're going to do dragstrip launches on slicks you're going to need an RPM greater than the stock 5500rpm
I love cobb. They listen to what the people want, it's great.
Old 06-04-2009, 06:04 PM   #12 (permalink)
jdmcoupe's Avatar
Roy
It should be open to any launch calibrations
(different cars ,different setups)
Old 06-04-2009, 06:07 PM   #13 (permalink)
Danny
delete.
Old 06-04-2009, 06:39 PM   #14 (permalink)
Josh
^ damn ninja edit
DevilDoc87 is offline   Reply With Quote
Old 06-04-2009, 06:59 PM   #15 (permalink)
We are implementing Launch Control in the existing maps simply to enable the use of the feature until the software is available, at which point you can set it to meet your own personal needs.
COBB Tuning is offline   Reply With Quote
Old 06-04-2009, 07:01 PM   #16 (permalink)
jdmcoupe's Avatar
Roy
ok make sense.
Old 06-05-2009, 09:27 AM   #17 (permalink)
bouncer07's Avatar
Gnehp Gnoix
Got a question.. since it reads engine trouble codes, can it read any OBD2 Port or just the 8th Gen's?
*Since I'm N/A right now I might as well go with the 4KRPM launch*
Will Vary once I have more parts installed.
bouncer07 is offline   Reply With Quote
Old 06-05-2009, 09:59 AM   #18 (permalink)
Stephen
Even after a lower vtec point?
although i would also say, 7k with slicks would be superior.
Old 06-05-2009, 10:46 AM   #19 (permalink)
Supa Ninja's Avatar
Nick
turbo-3000-3500 please
Supa Ninja is offline   Reply With Quote
Old 06-05-2009, 11:56 AM   #20 (permalink)
SpeedDemon's Avatar
Not Listed.
Yea if you wanna start breaking stuff.
SpeedDemon is offline   Reply With Quote
What RPM do you launch at? (not racing) immiketran Civic Coupe And Sedan 17 02-19-2009 11:23 AM
Launch Control like Kpro dannyd86 Bolt-Ons And All-Motor 16 05-14-2008 04:34 PM
what rpm to launch? civic tech Autocross & Sanctioned Drag Racing 2 04-18-2008 12:44 PM
Good rpm to launch at? Kennethcuevas10 Civic SI 21 02-01-2008 01:19 PM
best RPM for launch and shift el_ben2 Autocross & Sanctioned Drag Racing 2 04-20-2006 10:39 PM
