![]() Join Date: Mar 2007
So I heard the infamous cmc pop and loss of hydraulic pressure but not with the oem cmc but the hybid racing em1 cmc. A quick seach and i havent seen anyone with issus yet.. Has anyone had em1 cmcs break on them? I have about a good 6000 miles on the cmc. Before anyone ask, yes i did switch all the correct components from the oem cmc listed in hybrid racings instructions. Can anyone chime in as to why it failed? Thanks.
#2 (permalink) | |
12.423 @ 109 mph No AC jaja
Kevin
So trickyazn brought his car to my garage and I just had time to actually looked at it. There were no fluids outside or inside. His Slave Cylinder had no leak and it was getting little movement when I depressed it so I was assuming it could be two things, A) famous firewall breakage or B) a leak from the CMC to the CSC.
After inspecting, I found the problem, its his clutch pedal, the base of the pedal from one side "cracked" and broke apart from the rest of the unit which is only riding on one side to hold down the pressure of the CMC which is why it gave him the loss in pressure as the pedal flexes when he depress the pedal down. Anyways, I'll let the pictures do the talking Firewall is fine, no sign of crack on the frame. ![]() ![]() ![]() ![]() ![]() I used my visegrips to put it together to see if it can be rebuilt by welding the points and it seems like its possible Last edited by KSMatic; 07-05-2012 at 02:40 AM. |
#15 (permalink) |
Location: When all our tears have reached the sea Part of you will live in me Way down deep inside my heart
I am the Juggernaut!!!
You're not the only one that this has happened to, another 8th member local to me(02civic_rida) had the same issue. Replaced the broken one with a new one from Honda & all is fine now.
Last edited by 02civicsi; 07-05-2012 at 03:41 AM. Reason: But nobody said that it would not be worth it The human condition continues as such |
#19 (permalink) |
aka 3 blocks!
Taylor
I would the em1 is super soft,but this is coming from a omni cmc user.I have a comp stg.4 and the omni cmc.I completely destroyed my last pedal assembly.So now im back to my old standby em1 till i get a clutch with a softer pressure plate.
E.A.D-I be lurkin! |
#20 (permalink) | |
Kevin
Omni CMC and Broken Clutch pedal And this guy Omni CMC + CC Stg 2 = Firewall Flex?!? Seriously? Last edited by KSMatic; 07-05-2012 at 07:08 AM. |
| Hybrid Racing FTW!!! | darkhorseSi | Clutch & Transmission | 28 | 04-07-2013 11:01 PM |
| Hybrid Hybrid Racing Shifter Cables for 06+ Civic Si.. RAPE?? | 420Coupe | Civic SI | 30 | 03-13-2012 09:10 AM |
| Hybrid Racing EM1 CMC and Hybrid Racing Base Bushings | jchavez | Clutch & Transmission | 2 | 05-01-2011 08:29 PM |
