#41 (permalink) |
Matt
Give it a try with the swap of the bracket piece instead of the rod because although I believe you can use the EM1 rod with a lot of pedal adjustment I equally believe the oem rod can be used with the EM1 cmc with no issue and less pedal adjustment.
Thanks for the information and luckily I had them laying around to confirm so I am thinking the EM1 bracket piece should be used as opposed to the stock one. Just to confirm to everyone else reading this, the piece we are referring to is the piece that the snap ring secures which holds the rod in the CMC. |
#45 (permalink) |
Stephen
Man, just when i think we got it right.
Honestly, i didn't think people would swap the plate and snap ring over. when i did mine i used: em1 plate and snap ring, oem rod and oem bracket. Works fine. It seemed like common sense to me to put it together this way. |
#55 (permalink) | |
Sent from my iPhone 4 using Autoguide |
#57 (permalink) |
yes the retainer for the piston.the flat metal peice is fatter that the em1's and it compresses the spring to get the the snap ring in.which is like holding the ridind the clutch consistantly. if you use the stock rod use the retainer from the em1. trust me guys. that retainer destroyed my clutch in 600 miles.
#58 (permalink) |
Matt
I just installed a new EM1 cmc today(oem rod, set screw, pedal bracket, and em1 retainer) and I am having issues. I follow the instructions from here: Guide: Proper Clutch Adjustment for CMC
I get everything good where I can push the slave in and when I turn on my car it just feels like slush. Only thing I can think of is either a bad slave(which squeaks and kinda hesitates to release when I push down) or something with my clutch. I replaced both my CMC and SS clutch line so they are flawless. I am at a loss. |
#59 (permalink) | |
LinkBack to this Thread: http://www.8thcivic.com/forums/clutch-transmission/248679-em1-cmc-warning-advice-read-before-install.html
| jen.'s si coupe!: problems, problems, problems :( post 490. please help? - Page 25 - TriStateTuners.com :: Home of Tristate Auto Enthusiast | This thread | Refback | 08-12-2011 10:30 PM | |
| jen.'s si coupe!: problems, problems, problems :( post 490. please help? - Page 25 - TriStateTuners.com :: Home of Tristate Auto Enthusiast | This thread | Refback | 08-12-2011 10:09 PM | |
| Thread EM1 CMC Warning/Advice Read before Install | 8th Generation Honda Civic Forum | BoardReader | This thread | Refback | 08-09-2011 10:14 AM | |
| WARNING: People have TSI downpipe + greddy turbo MUST READ | Ekora | Turbocharging | 32 | 05-12-2011 04:39 PM |
| Any advice on a header plzz read!!! | got-vtec? | Header Discussion | 9 | 01-18-2010 01:20 PM |
| PLEASE HELP!! SportLine install help needed NOW!! PLEASE READ!! | Yo Nadz | Mechanical Problems & Technical Chat | 5 | 01-07-2007 06:02 PM |
