DIY: Fix Squeaking Clutch - Page 2 - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Bolt-Ons And All-Motor > Clutch & Transmission
Old 02-14-2010, 09:23 AM   #21 (permalink)
Ryan
yup... my '00 si and '08 si have the same problem
ryno069 is offline   Reply With Quote
Old 02-14-2010, 03:36 PM   #22 (permalink)
Duce2k's Avatar
Took mine in for the issue and mentioned that the CMC is the culprit, all they did was lube it and the squeak came back about a week after. I will try this DIY and see what happens....
Old 02-15-2010, 09:26 AM   #23 (permalink)
Stephen
This wouldn't happen if honda would make this correctly and put a dust shield over this spot onto the connecting rod like the omni power has.
on the omni, pull the dust cover up, grease it and voila, fixed and it doesn't leak, holds in grease and is smoother
w00t692 is online now   Reply With Quote
Old 02-15-2010, 09:36 AM   #24 (permalink)
SteveOFG2's Avatar
Steve-O
^link?
SteveOFG2 is offline   Reply With Quote
Old 02-15-2010, 11:27 AM   #25 (permalink)
SteveOFG2's Avatar
Steve-O
yesterday after driving around a bit the noise has gotten worse
Old 03-25-2010, 09:37 AM   #26 (permalink)
SteveOFG2's Avatar
Steve-O
to anyone that has tried this....has the noise came back????
Old 03-26-2010, 09:13 PM   #27 (permalink)
Johnold's Avatar
John
What about the "popping" sound? I don't have squeaking but rather a popping sound. Gets kind of annoying.
Johnold is offline   Reply With Quote
Old 03-26-2010, 09:22 PM   #28 (permalink)
SteveOFG2's Avatar
Steve-O
i get that from time to time but the other day it stopped....and it started again today
Old 03-26-2010, 09:30 PM   #29 (permalink)
Johnold's Avatar
John
Yeah. in florida when it's hot out, it does it but this winter when it was cold out, it didn't do it....strange. I was wondering if this DIY with the lithium grease would also eliminate this problem too aswell as the squeaking.
I can live with the popping but it would be nice to try this simple DIY if I knew it was going to get rid of the popping aswell.
Old 03-26-2010, 11:16 PM   #30 (permalink)
SteveOFG2's Avatar
Steve-O
i just want it to be like butter
Old 03-27-2010, 08:53 AM   #31 (permalink)
sivtecboi80's Avatar
Nick
I couldnt find the permatex crap so i settled for a liquid type grease. And its been 2 weeks and my clutch pedal is silky smooth, without that dreaded creek,squeek sound!
sivtecboi80 is online now   Reply With Quote
Old 03-27-2010, 09:18 AM   #32 (permalink)
SteveOFG2's Avatar
Steve-O
yea i can only find permatex in a spray can...i have found other lithium greases in tubes but none of them come with a lil nozzle...wtf
Old 03-27-2010, 04:49 PM   #33 (permalink)
Nick
yeah i had to search around for a while picked up a spray can of lube much much thicker than wd40 at autozone and that worked well.
Old 04-05-2010, 01:46 AM   #34 (permalink)
jonofmac's Avatar
Jonathan
Figured I'd chime in. So I still don't have a returning squeak, it seems if you just get some form of lithium grease. Something thicker than WD-40 is a must, otherwise it'll dry out and you'll be squeaking again.
jonofmac is offline   Reply With Quote
Old 04-05-2010, 01:55 AM   #35 (permalink)
Ruthless909's Avatar
Ls1 JeRk
Awesome DIY!
Ruthless909 is offline   Reply With Quote
Old 04-21-2010, 09:01 AM   #36 (permalink)
Thumbs up Worked Perftect
Did this last night and my clutch feels 100% better !
civic-steve is offline   Reply With Quote
Old 04-21-2010, 01:55 PM   #37 (permalink)
Johnold's Avatar
John
check this thread out for those with a squeaky and popping clutch. 06 Civic Si Popping Noise From Clutch
i'm pretty sure it's all the same area that has to be lubed but take a look at page 3 post #53. Str8JDM has posted some phenomenal news!
Old 05-11-2010, 02:24 AM   #38 (permalink)
jonofmac's Avatar
Jonathan
Update: Also saying that it's been like 4 months and still no squeaks
Old 05-11-2010, 07:11 PM   #39 (permalink)
Johnold's Avatar
John
yeah lithium grease FTMFW!
Old 06-10-2010, 09:30 AM   #40 (permalink)
going to try this when i get home.
SI_K_Nguyen_IS is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/clutch-transmission/193724-diy-fix-squeaking-clutch.html
orkut - [Embreagem] Problema This thread Refback 09-16-2011 09:50 PM
pedal da embreagem rangendo This thread Refback 09-05-2011 10:05 AM
orkut - embreagem fazendo barulho This thread Refback 08-23-2011 09:10 PM
pedal da embreagem rangendo This thread Refback 08-17-2011 01:38 PM
pedal da embreagem rangendo This thread Refback 08-16-2011 07:56 PM
pedal da embreagem rangendo This thread Refback 08-15-2011 08:45 PM
pedal da embreagem rangendo This thread Refback 08-09-2011 02:05 PM
Civic Si questions - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum This thread Refback 07-26-2011 02:45 PM
pedal da embreagem rangendo This thread Refback 07-05-2011 07:25 PM
pedal da embreagem rangendo This thread Refback 07-05-2011 06:40 PM
www.FnHatch.de • Thema anzeigen - Kupplungspedal quietscht This thread Refback 06-30-2011 04:47 PM
6MT owners, clutch pedal squeaks and travel isn't smooth when warm - Page 14 - AudiWorld Forums This thread Refback 06-25-2011 06:05 PM
My clutch pedal is squeaking Tongman Mechanical Problems & Technical Chat 16 03-02-2012 10:08 PM
Squeaking clutch ! Guei38 Garage 10 02-29-2012 05:01 PM
Clutch Squeaking ohiocivicracer Mechanical Problems & Technical Chat 15 11-25-2009 05:44 PM
my clutch is squeaking! bluetroll Mechanical Problems & Technical Chat 6 05-02-2008 04:02 PM
squeaking upon engaging clutch junkimchi Civic SI 12 09-07-2007 01:07 AM
