Anybody Have this specific problem?
When I am about to make a turn, sometimes I leave it in Neutral rather than 2nd and slow down to turn and if its kind of a hard brake the car shakes kind of like ABS is kicking in. When I mean hard brake I don't mean anything NEAR where abs should be kicking in. Anybody have this problem? I also had to replace the passenger side rear strut and now I think the driver side strut is popping once in awhile when I cost at like 20 and make a slight turn.
. 08 FA5 with 5,000+ miles |
Are you driving over any bumps or sand when the ABS activates? It's a pretty sensitive system and the slightest slip of a wheel triggers it.
Also when abs activates you can feel the brake pedal vibrate and move up and down, do you feel this when the symptoms occour? |
#5 (permalink) | |
Although it is less severe in a FF car, you'd learn fast and quick in a FR car that turning in neutral is a NO NO! |
#6 (permalink) | |
If he's taking a corner at 30mph, he's got other problems besides ABS activating. |
#7 (permalink) | |
I don't mean it in a severe oversteer snap, but seeing as how it's a 2nd gear turn, it can be anywhere from 20-60mph. What is certain is that while braking, weight is being shifted forward and when he takes it out of gear the car is unsettled, whuich can be enough to induce over/under steer Last edited by habitat; 05-16-2008 at 02:50 PM. |
#11 (permalink) |
I'd say it's normal if you're hitting a bump while braking.
Like others have said, the ABS system is pretty sensitive. There's a small bump on a manhole cover on a corner here that trips my ABS every single time I hit it when braking. I haven't tried disabling VSA to see if there's a VSA condition that's causing the ABS to kick in... but it's possible. |
| Where to get specific parts | wfarid | Civic Coupe And Sedan | 5 | 04-03-2008 12:24 PM |
| looking for a specific pic | samiirtuner | Introduction & Pictures | 16 | 03-29-2008 05:34 PM |
| Need Help! Looking For Specific Brake Lamp! | tda1337 | Civic Coupe And Sedan | 8 | 11-01-2007 07:37 PM |
| How to order a specific Si? | FIJIROB | Civic SI | 13 | 04-02-2007 01:25 AM |
| LOOKING for a specific picture | CivicDude | Inside and Out | 0 | 04-12-2006 11:55 PM |
