#22 (permalink) |
BTW I think Boost was saying that the problem is between the steering wheel and seat. The only thing that occupies that space is YOU.
On the other side I cannot let him dismiss this very real problem by yet again pointing fingers at the operator. Sure there are some flawed drivers out there. This issue is bigger than that.
#25 (permalink) | |
Do you adjust your BRAKE pedal freeplay every 5000 miles because the brake pedal works on the same principal as the clutch pedal. I wonder if the gas pedal is going to start getting this freeplay as well. Why no mention of this clutch adjustment in the manual??ALSO, if the clutch was the culprit IT WOULD GRIND GOING INTO ALL GEARS, not just 2nd, not just 2nd and third or some random order of gears. MISADJUSTED CLUTCH= GRIND/CLASH in ALL GEARS ALL THE TIME, its not something that will be intermittent. Last edited by 08civicman; 05-18-2008 at 01:08 AM. |
#26 (permalink) |
I wouldn't dismiss this fix. I did this on my Mazdaspeed6 and it worked like a charm. You're adjusting the travel and engagement point of the clutch pedal. If I can find the diagram that I found in the Mazda6 forums I will post it up because it is rather helpful if you wish to adjust it yourself. Took me approx 5 mins to do and it helped a lot.
Here's the thread from the Mazda forum... Clutch engagement point changed? - Mazda6 / Atenza ..and here's the diagram that works for Mazda's but is also handy in order to understand what is exactly being adjusted.... Board Message Last edited by FlyinSI; 05-18-2008 at 02:18 AM. |
#27 (permalink) | |
Thanks FlyinSI for the back-up. Some of you think that it's because of bad driver or w/e but I wasn't the only one with the problem. This in fact helps and WORKS.
#29 (permalink) |
your adjusting the throw of the pedal and clutch master cylinder, I had to do it on my Crappy ACT, You need to constantly adjust it, til theres nothing left to adjust then its time to replace the clutch. Id say you were a little too hard on yoru clutch got it glazed and its slipping. I beat on mine too early.
#30 (permalink) |
I think I might have the opposite problem with this. My clutch engagement point is at the very top. I barely have to press down and the thing will disengage, its slowely moved to the top. Does anyone know what this means? Do I need a new clutch or do I need to adjust the engagement point?
#34 (permalink) |
hate second gear... i have to shift slowly and hold the clutch a lil then shift to second or else i would feel the grind... 3rd is not an issue for me..... however when i vtec my car or should i say pound my car... shifting comes really smooth after... wierd
| 1st to 2nd gear grind in VTEC!!!:( | drumkid8 | Mechanical Problems & Technical Chat | 7 | 03-14-2008 01:08 PM |
| Do you think there'll be 2nd gear grind? | aznkukuboi | Civic SI | 25 | 09-19-2007 10:44 AM |
| 2nd gear grind | dlux200sx | Civic SI | 51 | 07-30-2007 02:26 AM |
| Third Gear Grind: Honda fix vs. Amsoil vs... | GlennS | Mechanical Problems & Technical Chat | 13 | 06-01-2007 12:34 PM |
| 2nd gear grind | CivicWithNav | Mechanical Problems & Technical Chat | 19 | 08-23-2006 06:23 PM |
