Old 05-15-2008, 05:54 PM   #1 (permalink)
DTNguyen107's Avatar
What stock tires does the Si have?
I'm still a nooblet in the car world so bear with me.
About to rotate my tires (just hit 10k miles) and wondering what stock tires do we have? Directional or non-directional?
I was looking in the booklet to make sure I do things right but it doesn't mention what type of tires we have. It tells me two different methods for directional and non-directional tires.
One is the "criss-cross rear tires to the front and bring front tires down" and the other is "bring the rear to the front and the front to the rear without criss-crossing".
Anyone can help me out?
DTNguyen107 is offline
Old 05-15-2008, 06:38 PM   #2 (permalink)
some one correct me if I'm wrong, but I believe the stock Michelin Pilot HX MXM4 are non-directional.
Ghetto2315 is offline
Old 05-15-2008, 06:40 PM   #3 (permalink)
Supreme Pizza!
Izzy's Avatar
Read the outside tire sidewall of the tire, it should tell you if it's direction or not. But, I do believe they're non-directional.
Izzy is offline
Old 05-15-2008, 06:44 PM   #4 (permalink)
e60.deluxe's Avatar
IIRC the Pilot HX MXM4 are non directional symetrical, and the Pilot Exalto PE2 are non directional asymmetrical.
e60.deluxe is offline
Old 05-15-2008, 08:08 PM   #5 (permalink)
Ah thanks guys. I'll check the tires when there is light tomorrow.
Another question though. I don't have my jack stands with me but would 4x scissor jacks and 1x hydraulic jack be fine?
I plan to use the hydraulic jack to jack up the front and the rear and then place the scissor jacks on the sides.
Old 05-15-2008, 08:09 PM   #6 (permalink)
Supreme Pizza!
Izzy's Avatar
If you use your spare, you can do it all with just one jack stand.
Izzy is offline
Old 05-15-2008, 08:12 PM   #7 (permalink)
e60.deluxe's Avatar
^^ yeah, also if your doing it on directional tire you can do it with 1 hydraulic jack on the side in the center.
if your crossing then i would use the spare regardless, since its not good to have all 4 corners up.
Old 05-15-2008, 08:26 PM   #8 (permalink)
Ah I wish I had my own lift right about now
Old 05-16-2008, 02:11 PM   #9 (permalink)
duerrs's Avatar
front to back only
duerrs is offline
Old 05-16-2008, 02:29 PM   #10 (permalink)
Gimenez's Avatar
Luis Gimenez
Mine brought KUMHOS hmm
Gimenez is offline
Old 05-16-2008, 03:46 PM   #11 (permalink)
B-Stylz's Avatar
Brian
I just did front to back last weekend. Worked fine and the TPMS sensors were not affected.
B-Stylz is online now
Old 05-16-2008, 03:50 PM   #12 (permalink)
Originally Posted by duerrs View Post
front to back only
Actually the stock tires were non-directional. According to the book it should be front tires go straight back while rear tires criss-cross to the front.
I don't think you know what TPMS is exactly...
Anyhow, car ride feels so much smoother now after rotating tires. It just hit me though after I finish the job. I remember reading something about how to properly tighten the nuts. Instead of tightening one random nut at a time your suppose to tighten nuts #1, 3, 5, 2, and 4 in that order. Not sure exactly. Anyone know?
Old 05-16-2008, 03:54 PM   #13 (permalink)
B-Stylz's Avatar
Brian
It monitors tire pressure in my tires!
Old 05-16-2008, 04:46 PM   #14 (permalink)
e60.deluxe's Avatar
you do a star shape.
Old 05-16-2008, 05:09 PM   #15 (permalink)
PhoR11's Avatar
Bradley
Some TPMS systems (like the one on the honda pilot I believe) actually have "locator" fuctions that tell the receiver on which corner each tire is mounted.
If the TPMS in the civic had this feature, then rotating would definitely screw up the TPMS.
Fortunately it doesn't, so you can rotate away without worry...
PhoR11 is offline
Old 05-16-2008, 05:11 PM   #16 (permalink)
B-Stylz's Avatar
Brian
So how do you rotate with the locator function then?
Old 05-16-2008, 05:30 PM   #17 (permalink)
PhoR11's Avatar
Bradley
With a scantool to tell the ECU where you're moving the wheels
Or by letting your dealership do it...
PhoR11 is offline
Old 05-16-2008, 10:04 PM   #18 (permalink)
B-Stylz's Avatar
Brian
I'd pull the fuse before I allowed that to happen!
