Closed Thread
Old 05-13-2008, 07:12 PM   #1 (permalink)
Shift Into Neutral Or Rev With Clutch In When Rev Matching
Do you guys put it into neutral and let out on the clutch then put the clutch in again and downshift or do you just put the clutch in rev then move into a lower gear then let it out?
I heard the former was bad on your throw out bearing
supersteve9219 is offline
Old 05-13-2008, 07:14 PM   #2 (permalink)
Kevin
i would like to know to, cuz i shift down to second then revmatch then let go of the clutch is that bad?
footballaholic is offline
Old 05-13-2008, 07:15 PM   #3 (permalink)
Asif22's Avatar
Mohamed El-Mubaslat
Say your going from 4th to 3rd....Clutch in, Neutral, clutch out, rev match, clutch in, 3rd gear
Asif22 is offline
Old 05-13-2008, 07:15 PM   #4 (permalink)
jeiarneesi's Avatar
clutch in then blip throttle all while down shifting.. well somewhat.. sometimes i clutch in downshift then blip then drop clutch
jeiarneesi is offline
Old 05-13-2008, 07:16 PM   #5 (permalink)
Si 07's Avatar
longer you depress the clutch more wear and tear on the clutch, whatever gets your foot out of the clutch pedal sooner is best
Si 07 is offline
Old 05-13-2008, 07:52 PM   #6 (permalink)
Will06SI's Avatar
Will
I always clutch in go in 2 gear blip let it out works good for me !
My clutch is perfect with 39k on it.
Will06SI is offline
Old 05-13-2008, 10:22 PM   #7 (permalink)
rcracin13's Avatar
that's double clutching. you can rev match while pressing the clutch pedal as well.
rcracin13 is offline
Old 05-13-2008, 10:24 PM   #8 (permalink)
I party better than you
illusionstwice's Avatar
The original --> "J" <--
SEARCH. It will find you freedome, grace, and answers
seriously though, this has been diuscussed a billion times
illusionstwice is offline
Old 05-13-2008, 10:25 PM   #9 (permalink)
rcracin13's Avatar
yea he's definitely correct. i guess i was in a nice mood
Old 05-13-2008, 10:33 PM   #10 (permalink)
REPOST
Rev Matching?
Newbie guide for Manual Transmissions
(scroll down about half way of 1st post, and read)
Closed Thread
I like to rev up in neutral... Pachodino Mechanical Problems & Technical Chat 12 06-13-2008 09:10 PM
Rev limiter in neutral andy22 Civic SI 84 05-03-2008 03:45 PM
Would someone please explain rev-matching to me? NeinLives Civic SI 34 04-16-2008 06:11 PM
Rev Matching/Gear Grinding CaliGuy Garage 46 08-31-2007 06:13 PM
Rev Matching? Silver8th Garage 39 06-09-2006 12:01 PM
