Is my clutch going out?
How do I know my clutch is out? Everytime I launch the car to race or something it doesn't go into 2nd... weird thing is... this is not the typical problem most get of 2nd grinding. My doesn't grind at all.... it just stays there and doesn't take it and keep revving... once I slow down, it takes it O_O wtf!? Do I need a new clutch?
At first glance, it sounds like either the clutch is weak or it's not being fully engaged. Does it ONLY happen in 2nd, or is it every gear under load? (meaning, shifting into 3rd and accelerating should produce a similar effect if the clutch is going bad.) How many miles do you have on it?
#4 (permalink) | |
Obviously I don't do that very often. Heh. |
test your clutch see if it is going...even though i really dont think it is...just for your own peace of mind...start your car put it in 3rd while ur not moving and let go of the clutch to see if it stalls out...if it does right away you should be golden and ur problem isnt really the clutch at all...
#12 (permalink) |
Here's how to test your clutch is going out. Not the most gas efficient.. but w.e.
Put it in 1st gear.. drive it to 20 mph and hold it there. Now floor it... did you notice any slipping? EX: Revs going up but speed isn't going up as fast? In my experience though with the Si's oem clutch.. it's indestructible. |
| Stock clutch and NITTO NT01 don't mix. I need a clutch!!! | itzwykd | Forced Induction And Nitrous | 50 | 07-25-2008 12:46 PM |
| Am I Wearing Out My Clutch Prematurely? | supersteve9219 | Civic SI | 13 | 04-28-2008 01:25 PM |
| I think I wore out the clutch.... | edrhee83 | Mechanical Problems & Technical Chat | 27 | 03-05-2008 03:56 PM |
| pulling it out with clutch? | dnbsi | Civic SI | 8 | 10-31-2007 03:30 AM |
| Stronger clutch needed on my AJP'd car. Clutchmasters 3 crapped out on me | zionrug | Forced Induction And Nitrous | 19 | 09-13-2007 10:25 AM |
