3000 Rpm = 30 Mpg
The Particulars.
My ride is an 06 SI with 20,100 miles. I always use Mobil 1 and surburban driving on Long Island so a mix of short bursts on the highway and reular 2 to 4 lane traffic with lights. I have changed my driving on the parkways to 65mph at say 2800 rpm's. My last 2 tanks have yielded me 30 mpg. In the past driving at between 70 and 75 mph and closer to 3500 rpm's lucky to get 25 mpg. Moral of the story: I slowed down a bit and am getting much more range from a tankful. At $4.09 a gallon for 93 octane I feel a bit better. Just thought I'd share with you all. |
I party better than you
The original --> "J" <--
Nice write up. I started doing this about 3 weeks ago and have noticed a hell of an increase. I havent hit vtec since april 30th. I am trying to hold off my need for vtec until May 18th...the day of the big meet. So I can
all day ![]() |
You're doing it wrong!!
How are you calculating that? You should be doing better.
My car nets around 31-32 at 70+. If I actually did slow down to 65 I could probably get close to 35. For reference the most efficient speeds are 65 in 6th and 45 in 5th according to some folks with scan guages. |
#4 (permalink) | |
#7 (permalink) | |
I've run a ScanGauge for years and the ScanGaugeII since I got my FA5 and in almost all situations with a competent driver you will get better mileage in 6th at 45 MPH as opposed to 5th. Basically the sooner you can shift the better for MPG. Exceptions would of course be if the lower gear can't provide you with the power needed causing the driver to ask too much of the engine in that gear sending the ECU into open loop, etc. |
#11 (permalink) | |
I used to do 65 on the highway all the time and got around 27ish per tank, lately I've been doing 60 and I'm getting 29-30 on each tank now. |
#13 (permalink) |
I'm still on my factory oil fill, but I do have Amsoil MTF. I ran a trip at 75 to 80 mph, and got just over 30 mpg.
My car only has about 2,200 miles on it. As it breaks in more, the mileage always goes up. There is no doubt in my mind that I could get better than 32 mpg on a long road trip. |
#15 (permalink) |
I used my GPS set in KM/HR mode and switched my Si to read KM/HR and found out that my car reads about 1.5KM/HR slow at 103 KM/HR (more accurate since KM is a smaller unit than MI. Then using my ScanGaugeII I adjusted my speed to read 3000 RPM and that's right at 69 MPH true speed. That's roughly 43.5 RPM/MPH so 40 MPH in 6th = 1740 RPM and 50 MPH in 6th = 2175 RPM. If you asked this question about my auto tranny CR-V I'd say "I dunno" since the slush box won't lock up and provide a fixed ratio until you're going nearly highway speeds.
#16 (permalink) | |
I'm still on factory fill oil at just over 4000 miles but will be changing to Penzoil Platinum any day now in preparation for getting the Hondata reflash and doing some dyno runs since I'd rather get the factory fill out if I'm going to be doing a half dozen runs on a dyno now that the engine has had time to do it's break in. |
#17 (permalink) |
As I'm just over 1000 miles now on the new Si, I've "discovered" vtec.. Interesting.. It kicked upwards into 6k rpm range, then I heard something then all the sudden the engine started "breathing" better. So I'll have to learn up about how Vtec works.
However, if the goal is mpg's, I'd NEVER get up into that kind of RPM range I'd think, rendering vtec completely useless really.. plus, the high vtec kick-in doesn't seem very beneficial for a daily commuter as I'd really rather not redline the thing all the time.. 1st impressions from a brand spankin' new Si owner, coming from a Subie turbo with a bunch of low-RPM grunt, even prior to the turbo. |
#20 (permalink) | |
| 2006 MPG=30/40, 2008 MPG=25/34.......WTF happened? | LsedanX | Civic Coupe And Sedan | 35 | 12-11-2007 09:13 AM |
| Guido 3000 | xmx250 | Water Cooler | 0 | 10-22-2007 01:28 PM |
| 5W-30 or 10W-30? | asdf | Civic SI | 47 | 10-15-2007 03:27 PM |
| Is this the first car where A/T MPG > M/T MPG? | asndragonboii | Civic Coupe And Sedan | 6 | 01-19-2007 05:08 PM |
| gear down shifted and rpm hanged at 3000. | spunkin82 | Mechanical Problems & Technical Chat | 5 | 05-17-2006 01:49 PM |
