Old 06-04-2006, 12:22 PM   #1 (permalink)
2evolved's Avatar
hondata question...
I saw the Hondata review and did read it from sickyute... nice review.. I didn't read all 7 pages of the damn thread it made me tired getting through the first 3.
I don't think I want to take my ECU out and ship it to CA or whatever.
It is something I want to consider but I rather wait until EMS or E-Manage comes out... but... heres the question.
Does HONDATA work with Standalone? I know how flashes work and its a pita to send in the ECU on a new mod. I also know there is pros/cons of flash vs standalone.
I've never tuned a Honda also I know the basics are the same as any other engine but can with someone who has better experience on them chime in on this for me!
2evolved is offline   Reply With Quote
Old 06-04-2006, 12:29 PM   #2 (permalink)
cmf
From my understanding, Hondata probably won't do a standalone (K-pro). I heard the DBW system has something to do with it, but I could be way off on that.
cmf is offline   Reply With Quote
Old 06-04-2006, 12:37 PM   #3 (permalink)
larryd's Avatar
I'm not sure what you're actually asking "Does HONDATA work with Standalone". Do you mean if you were to purchase a standalone would Hondata flash it? Simple answer to that one is no.
Also E-Manage is not a standalone, it still uses the stock ECM. Most companies who offer standalones like Apexi Power FC, AEM EMS etc etc have not offered anything for cars with DBW (Drive by Wire).
larryd is offline   Reply With Quote
Old 06-04-2006, 04:02 PM   #4 (permalink)
2evolved's Avatar
Oh I asked the question wrong...
I meant would Hondata work with E-Manage, AFC etc...
Old 06-04-2006, 04:33 PM   #5 (permalink)
cmf
Doesn't matter, those systems won't work on a DBW car as of the moment.
Old 06-04-2006, 05:15 PM   #6 (permalink)
2evolved's Avatar
So its not possible to fine tune flashes with piggy back systems?
Old 06-04-2006, 06:22 PM   #7 (permalink)
larryd's Avatar
Actually you are wrong, the Emanage and AFC both work with DBW as they are just piggy back units that retain the stock ECU.
I don't know wether or not you could use them in conjunction with the reflash but I don't see why not.
Old 06-04-2006, 10:59 PM   #8 (permalink)
cmf
I have yet to see a AFC that will work on a DBW system.
Old 06-04-2006, 11:46 PM   #9 (permalink)
larryd's Avatar
Why wouldnt it? It pulls the RPMs off of the rev signal from the ECM unless ofcourse it can't get a throttle percentage because of the DBW. I didn't think of that.
Old 06-05-2006, 04:39 PM   #10 (permalink)
cmf
DBW replaces a throttle cable/ body.
Old 06-05-2006, 04:43 PM   #11 (permalink)
larryd's Avatar
No sh*t.. You don't physically connect an AFC to the cable. It gets the signal from an electrical connection. Why that signal would be any different on DBW vs DBC is beyond me.
Old 06-05-2006, 08:27 PM   #12 (permalink)
cmf
Dude, don't get so excited.
I had a TSX (also DBW) and many have tried everything in the book. Point is, wiring to get an AFC to work is virtually impossible, hence no wiring diagrams being available to do so. The car is working on 3 years old, and still nothing. It's not there for a TSX, nor will it be for the Si. Maybe somewhere down the line, but not at the current moment. I think that is what the person that started the thread was looking for is to see if it'd work, but it won't, with or without Hondata.
If you want to do a hack job on your electrical system to prove how much you know, then be my guest, good luck. Don't read so much into what people type.
Old 06-05-2006, 09:49 PM   #13 (permalink)
2evolved's Avatar
Hey.. no war in my threads
Old 06-05-2006, 10:16 PM   #14 (permalink)
larryd's Avatar
My bad.. I've been crabby all day. I'm trying to understand why it doesnt work is what I was getting at. The throttle percentage is just an electrical signal regardless of wether its a DBW or DBC so why would there be a difference?
Old 06-05-2006, 10:18 PM   #15 (permalink)
Moderator
sickyute's Avatar
Marvie
my car is being boosted as we speak...turbo...tuning figured out! so it's possible!!!
Shift when it blinks!
Old 06-06-2006, 12:09 PM   #16 (permalink)
8thcivic Sponsor
This engine computer has extremely tight control over air fuel ratios. Under 3800 rpm the car runs in closed loop even at full throttle. So, if you adjust the air fuel ratios externally to make the car run richer, the ECU will just lean it back out again.
Hondata is offline   Reply With Quote
Old 06-06-2006, 03:02 PM   #17 (permalink)
2evolved's Avatar
wow.. i had Hondata himself post my thread!
so what if you fool the ECU by thinking its running too lean instead of rich?
Old 06-06-2006, 04:32 PM   #18 (permalink)
8thcivic Sponsor
Same thing. It will add fuel to hit a specific air fuel ratio. The 02 Sensors are wideband and are very accurate.
Old 06-06-2006, 04:57 PM   #19 (permalink)
larryd's Avatar
The statement though was that an AFC would not work on a car with Drive By Wire. The fact is an AFC will not work on these new engines with Intelligence as the factory ECU is always compensating for what the piggy back changes. This has nothing to do with DBW which is what I was getting at before.
Old 06-06-2006, 05:50 PM   #20 (permalink)
cmf
So, adding an AFC to the Civic does nothing then. What is the case with the TSX then? Same issues?
Hondata Heat shield?? 954K20_SI CorSport 12 04-29-2006 04:46 PM
Hondata 06 SI Help please! 4_Door_SI Mechanical Problems & Technical Chat 3 04-28-2006 09:00 PM
Hondata for Non-SI Poll!!! RODSCIVIC Bolt-Ons And All-Motor 26 04-06-2006 03:19 PM
exhaust question leviathan18 Bolt-Ons And All-Motor 17 03-26-2006 04:03 PM
Hondata almost there!!!!!!!!!!! Ep3racer954 Civic SI 9 02-20-2006 05:23 PM
