#44 (permalink) |
I really hope they do a TSB. I haven't even bothered to to bring it up at the dealer, says they never know anything about it. All I did was insist that they change the MTF, which did make it much better, at least for now.
It's amazing how the techs never know anything that's all over the internet. |
#46 (permalink) |
Really? They must have only repaired your transmission with the same exact but new parts then because the actual fix for this issue has not been completed yet as I have stated already. You may want to bring your car in for the fix later on because I'm sure your replacement is only going to "fix" your problem temporarily, I could be wrong though. I just hope for your sake that they don't try to not give you the actual fix later on because of the fix you have already received.
#48 (permalink) | |
#49 (permalink) |
Hm, interesting. However my service manager double-checked with Honda over the phone again today and was told it is still in production. In either case, even if you did receive it already I would definitely double-check on it later on if I were you.
I don't think it will be a "recall", meaning it will not be in a letter-form sent out to all SI owners since it's not affecting everyone. And there's no VIN range to give out for it either. If they did treat it as a recall, dealerships would be swarmed with people who may or may not have the problem, and that's just too much for them to handle given that the inspection for the problem will be conducted free of charge - and that's simply too much time that will be wasted. Logical IMO. |
#50 (permalink) | |
#51 (permalink) | |
![]() But you do have a point. They did say the parts for the fix could be available as early as Jan 2008, so it is indeed possible that you have received these parts already. Do you have the service receipt with the parts and labor listed? If so, please share it with us. |
#53 (permalink) |
Very nice work, thanks for the scan!
Okay, after seeing this I can say this: You have a very responsive service team at your local dealership, and we should all hope to be treated as good as you were treated. However, after looking at the parts they ordered and installed into you car I know that you couldn't have received the official fix yet. They have simply just installed for you a new 3rd gear for you from what I can see from this. I was told about the fix in as much detail as possible. In my relayed description of the fix to everyone on my posts, I stated that the solution for the fix lies primarily in the ENTIRELY NEW gear syncro rings (it is entirely new/different from what we currently have) that Honda is manufacturing (or has already manufactured?...). I do not see on this service receipt that those parts were ordered and installed for you. From what I see on your parts listed, you were given: FORK 3-4 (transmission fork) Gear Set, 3rd (obvious) HONDABOND HT (Silicone Gasket Sealant) I don't see any syncros listed...so they really only did give you a new 3rd gear and shiny new tranny fork. This might fix the problem, but in my opinion temporarily. So that leads me to conclude that you have not received the actual awaited fix. I was informed that the new syncros will be for all gears - 1 through 6. In addition, they will replace any damaged gears that was associated to the problem, as well as any other part that was damaged in relation. So the question is, do you know if you did or did not receive those other key parts? Last edited by Vinc84; 01-15-2008 at 01:15 PM. |
#54 (permalink) |
I was at the dealer today for an oil change. I presented the Service Manager with the OP's post. He gave it a quick read, made a phone call, and told me that as soon as they got the official word from Honda he would call me for an appointment to have the parts replaced. There was no request to see it fail in action. Just do it he said. Looks like there may be hope that this is moving forward after all.
#55 (permalink) | |
#56 (permalink) | |
I could be wrong, but that's rare (ha ha ) I'm not opposed to having them fix it...again, but I really got the feeling that I've got the goods so to speak. We shall see :) |
#57 (permalink) |
No, honestly I think "Gear Set, 3rd" basically means:
Gear that was Set: 3RD Gear (not 1st, 2nd, 4th, 5th, or 6th but just 3rd) Meaning they only gave you a new 3rd gear and only that one gear, and MAYBE the one syncro ring to go with the 3rd gear. If you received everything it simply would not be that vague...if they in fact gave you an entire set of new gears or even just the 3rd gear, whatever syncros they included whether it was just one for the 3rd gear or all 6 syncros for all 6 gears - it would all be listed on the parts and labor list indefinitely. At the top of your service receipt, the description of your problem & services rendered is stated thusly: CUST STATES HAS TO DOUBLE CLUTCH TO GO INTO GEAR - WITH ALSO THROWING SELF OUT OF GEAR BY ITSELF VEHICLE ALSO MAKING IT HARD TO SHIFT INTO THIRD OVERHAULED TRANS AND REPLACED THIRD GEAR. So much of that description is concentrated on the third gear!...As it should be since that is our problem. 3rd gear this, 3rd gear that. The 3rd gear is not the problem really, but it is the victim in this problem! The service dept at your dealership simply went ahead and tried to fix your problem by replacing your 3rd gear - this has been done for many other people besides you already. It does not fix the problem for good, only temporarily. They basically opened up your transmission and just replaced your 3rd gear - that was their solution to the problem. However...the 3rd gear itself isn't the problem. The problem is in how gear box itself is laid out and the current gear syncros in our gear box. That is why the official fix involves replaced the syncros as well as placing the gears in a newly set up box with a improved "pattern" if you will, for improved shifting that has been designed to tackle and eliminate the 3rd gear issue. Does everyone understand what I'm trying to say? Simply replacing the 3rd gear is not the solution. It's just going to be a brand new gear to grind up again... It's like giving a brand new arm to manic-depressant-suicidal-emo who can't stop himself from slitting his wrists - he's just going to cut up that new arm all over again. To fix the problem for good, you'll need to find out what's wrong with the poor bastard and fix him so he'll stop being a retard. ![]() Orbit1, your problem could be fixed, I can't say I know 100% that it's not, but I'm just trying to help you in case you're trying to convince yourself that it is even when I'm trying to point out that it makes no sense. I hope it doesn't offend you, instead I hope it inspires you to double check everything later on - especially when the official parts for the fix are actually released in an announcement...and not in some 'selective testing' or whatever you might think it is that you received. Does anyone else have any input on this? Last edited by Vinc84; 01-14-2008 at 06:45 PM. |
#58 (permalink) | ||
Vince, I've got a question that you may have already discussed, but I looked already and couldn't find it.
Do you have any ideas, personally, as to what this fix package may encompass, and what they'd have to do in order to apply it? Like...what would they be replacing and how would they go about doing it. I have to admit I'm a little nervous to let a technician touch my transmission, when they can't even seem to put the right oil in my car (three times now I've had 5W-20 put in even after I asked for 5W-30, not to mention it is on the cap).
#59 (permalink) | |
In conjunction with the transmission repairs, you may or may not also even receive a new clutch. If your service technician finds that your clutch has been worn down to a serious enough state or if it's even BLOWN because of the 3rd gear problems - then you will receive a new clutch free-of-charge as well. Furthermore, it is also critical to know that the MTF in our transmissions should now be Amsoil Syncromesh or equal (your Honda may offer their own new MTF which is basically the same thing). Honda recognizes that the original MFT was not effective enough and so that probably contributed to transmission faultiness INCLUDING the 3rd gear issue. So make sure you get that done as well if you have not already done so. In order to fully know what needs to be done to your car specifically, you must have your Honda service technicians inspect your vehicle's transmission as well as the rest of your vehicle's drive-train/power-train to fully access what needs repair in the given circumstances. I cannot promise that you won't have to pay for any of it - but I can assure you that you will at least receive the basic transmission repairs for this problem. If however they find that something else has been damaged but they are not willing to cover for it, you will have to unfortunately probably pay for that out of your pocket whatever it may be. I understand that everyone is nervous and upset that these repairs will have to be done to their transmission - but we have no choice but to get it done because we'll be doing much worse without it getting done. Just have some faith that your SI WILL be the way that it should have been when you paid out the money for it. I still love my SI and trust in Honda to fix all of this despite how messed up this whole thing is. SI FTW!
#60 (permalink) |
Vince, your info is right on from what I was told at my dealership. My car was in an unfortunate accident back in early December, so I had the dealership look at the transmission while it was in for the bodywork. Their first reaction was "can't replicate", but after I took them out and replicated it myself they understood what the issue was. They made a call to Honda and the story that was relayed to me was just what you've been saying. The service manager told me there were several tsb's out on it (change oil and change shifter fork), but I should just wait until the redesigned parts are available (which should be within a week according to their timetable back in early December). I can't really add any info to what you've said, but I can confirm your info is what I was told by my dealership.
