squeaking upon engaging clutch - 8th Generation Honda Civic Forum
Old 09-06-2007, 02:43 AM   #1 (permalink)
junkimchi's Avatar
This is kinda weird but there is a pretty loud squeaking noise when I engage the clutch in first and second gear. The squeaking goes away after the car is warmed up and driven for a few miles but the squeaking is very loud when the car is first started. The scene is
1. I start the car
2. put it in first
3. let go of the clutch
4. squeaking begins and stops after RPM's are a bit higher
the squeaking also continues while moving slowly in first gear.
Does anyone else have this strange noise on their si? Upon searching, some reportedly say its the exhaust hanger and some say its the actual clutch. What is going on.
my FA5 si has 4500 miles and I admit that I have drove a bit "spiritedly" but nothing completely crazy.
junkimchi is offline
Old 09-06-2007, 03:05 AM   #2 (permalink)
nayilsi's Avatar
i have it in 1st 2nd and 3rd.
Loud music = no squeaking no rattling no complains.
Old 09-06-2007, 03:10 AM   #3 (permalink)
junkimchi's Avatar
^ LOL that's usually what I do
I just don't want my clutch exploding while i'm on a big hill or something
junkimchi is offline   Reply With Quote
Old 09-06-2007, 03:14 AM   #4 (permalink)
nayilsi's Avatar
i have 5500 miles.... doubt itl explode.
there are people here who drives harder than us..... wel get to know it.
the solution to the problem would be..... shift gear with higher RPMs.... at 4 or 5 ish.... see if it helps..... works for me.
Old 09-06-2007, 03:18 AM   #5 (permalink)
VooSi's Avatar
Michael
Ive noticed that recently but wasnt sure, guess ill pay attention tomorrow see if it keeps happening
VooSi is offline   Reply With Quote
Old 09-06-2007, 03:23 AM   #6 (permalink)
junkimchi's Avatar
You can search "squeaking clutch" or something of the sort here in the forums for a good quanity of answers but they all seem to be leading in a different direction. Some say the problem was fixed after they replaced the clutch, and the others say its the exhaust hanger? It has to be one or the other... I hope its not a bad case the placebo effect in play when someone attempts to fix the problem.
Old 09-06-2007, 04:03 AM   #7 (permalink)
2000civic's Avatar
Robert
I have the same problem. I am going to go with the answer that it is the exhaust hanger, not the clutch. At first I thought it was the clutch, however upon listening more carfully, I found that the noise also happened under very light throttle in 1st through 3rd gear, when I was not using the clutch at all. Try listening while applying very light throttle, and see if it is the same for you. The noise only started happening after I changed my cat, so I am almost 100% positive it is the exhaust hanger.
2000civic is offline   Reply With Quote
Old 09-06-2007, 04:08 AM   #8 (permalink)
junkimchi's Avatar
^ i know what you mean because the sound becomes apparent when i'm just slowly creeping even without touching the clutch. I feared it could have been the clutch slipping or something but then again i'm not some clutch expert...
jw, does everyone's squeaking noises go away as the car is warmed up and in operating temperature? My noise seems to be the most apparent when i first start the car and goes away as my car is run.
Old 09-06-2007, 07:16 PM   #9 (permalink)
Joe
that happens to me also. the first time i heard it i freaked out. i only have 5000 miles. and my dad said take it into the dealer, i haven't had time though. mine only makes noise when i move.????
mycvksi is offline   Reply With Quote
Old 09-06-2007, 08:35 PM   #10 (permalink)
junkimchi's Avatar
try engaging lightly while holding the brake in first gear. I bet it'll squeak just like mine does.
btw you're in riverside? Interested in coming to a meet tomorrow?
Old 09-06-2007, 09:37 PM   #11 (permalink)
My previous car, a 02 Ep3 did the same thing sometimes. I usually went away after it warmed up. I havent noticed it yet on my new si yet with 7000 miles
roadcarver is offline   Reply With Quote
Old 09-06-2007, 10:40 PM   #12 (permalink)
Slav's Avatar
Stan
yeah this started happening to me also a few months back but it goes away and comes back as it pleases, i also noticed i happens more when its humid out and even if the car is warmed up. i took it to the dealer they said they "couldnt reenact the problem" so the lubed up a part of it and the next day it squeaked anyway. so im not sure what it is, cause the past week it has been cold and it hasnt squeeked at all, i might bring it in, when i try to get the new honda tranny fluid put in, and tell them to look at it again, anyone else have any suggestions? sorry for the long post btw
Slav is offline   Reply With Quote
Old 09-07-2007, 01:07 AM   #13 (permalink)
2000civic's Avatar
Robert
Yea mine also seems to be more prominent when it is warm than when It is cold.
Newbie guide for Manual Transmissions Tastycakes Mechanical Problems & Technical Chat 166 08-01-2009 04:24 PM
Clutch pedal squeaking TJ06CivicLX Mechanical Problems & Technical Chat 23 09-29-2008 02:26 PM
Clutch engaging late JZCivic Mechanical Problems & Technical Chat 4 06-21-2007 02:08 PM
ACT Clutch Kits, Flywheels and Greddy SP2 Exhaust skittleslegend Civic SI 43 06-22-2006 07:34 AM
