Old 07-30-2007, 06:41 AM   #1 (permalink)
lmfdjtiko's Avatar
Tiko
this is pissing me off.. help~!
2 days ago... i wash, polish and waxed my car..
i clean the interior...
i used some "invisible glass" and some other kind of spray to wash the glass inside and the rpm plastic..
this turn out.. a day later..
it looks like water marks but its not. i tried to clean with many different kind of things, it stay there. it is kinda like very small bubble, i used some strong cleaning liquid to clean it, it goes off for a sec and it come back.....
wtf?
is it hard to change that piece of glass/plastic ?
i am going to dealership to fix this.
will my warranty cover this?
there are a lot of other problem with my car...such as.. suspension "pop" sound.. driverside window shake/rattle when i drive fast or .. just sometime...stick 2nd/3rd gear(a littl)... steering wheel is off to the right-.-.. etc wtf...
lmfdjtiko is offline
Old 07-30-2007, 07:19 AM   #2 (permalink)
Hidy ho neighbor
GeezerSi's Avatar
-> Ken
I use invisible glass to clean my inside windows, including the gages. I have never had an issue with it.
Did you sneeze while you were eating glue?
j/k - I would go to the dealer if you can't get it off. Maybe they can offer assistance. Maybe a detail shop can help?
Good luck.
GeezerSi is offline
Old 07-30-2007, 07:30 AM   #3 (permalink)
193whp FTMFW!
PSU Pinoy PSU's Avatar
Eric
Wow...my friend had the same problem....it was pretty much ingrained into the plastic. i would say just get a new one....sorry for the guages
PSU Pinoy PSU is offline
Old 07-30-2007, 07:30 AM   #4 (permalink)
1stk20z3's Avatar
Casey
use a 50/50 mixture of water and alchohol to take that off
1stk20z3 is offline
Old 07-30-2007, 08:38 AM   #5 (permalink)
mrbill's Avatar
"...and some other kind of spray to wash the glass inside and the rpm plastic." You probably don't want to do that.
If you can't get the marks out of the plastic, it's a relatively cheap part:
77222-SNA-A01ZA 44.60 retail.
And it's easy to swap. If you don't have the Helm Factory Service Manual you can get by with the XM Radio Install Instructions.
Luckily you didn't "treat" the speedometer to the same "cleaning." The part is cheaper:
77200-SNA-A01ZA 6.43 retail.
But swapping it is a pita. You'll end up needing to take off the audio panel as well so you can get to the instrument pad assembly, and you won't be able to pull the assembly apart without the KTC Trim Tool Set (or equivalent).
Be careful with cleaning supplies. That's why they usually say "test in an inconspicuous spot."
-mr. bill
mrbill is offline
Old 07-30-2007, 08:44 AM   #6 (permalink)
GlxyGry06Si's Avatar
damnnnnn. i use invis glass to get stuff off glass. maybe try goo gone, or like someone said alcohol. its probably splatter from your plastic cleaner. i always clean the guage right after i clean the plastic.
GlxyGry06Si is offline
Old 07-30-2007, 08:45 AM   #7 (permalink)
193whp FTMFW!
Eric
man...thats on of the reasons y i use water to clean the gauges
Old 07-30-2007, 09:12 AM   #8 (permalink)
inyong1988's Avatar
Junction Produce
so easy to clean that up, wash the surface with the tissues that are wet by water. and clean it, then wipe it down with the dry towel or paper towel.
inyong1988 is offline
Old 07-30-2007, 11:21 AM   #9 (permalink)
is stuck at work...
SiliconX's Avatar
Eric
Don't use glass cleaner to clean plastic
SiliconX is offline
Old 07-30-2007, 11:24 AM   #10 (permalink)
I had that same problem w/ mine too. I'll try some of the cleaning tips here first, but I'd find it hard to believe that 50/50 alcohol or just water and tissues will take off those spots when plexus, meguires plastx etc wouldn't.
LordZeal is offline
Old 07-30-2007, 01:19 PM   #11 (permalink)
Subaru71's Avatar
dSLR Squad #32
wtf?
Dealership replaced mine with no problem because it had a scratch upon delivery. You might be able to get them to replace if you dont tell them what you sprayed on it? also the other problems you have are all normal... Ive experienced them and they all went away before i hit 10k miles..
Subaru71 is offline
Old 07-30-2007, 02:00 PM   #12 (permalink)
193whp FTMFW!
Eric
i think a scratch he'd be able to get away with, but this is something you would think he'd notice before he took delivery of the car
Old 07-30-2007, 02:04 PM   #13 (permalink)
truflip's Avatar
Im curious, what is this "some kind of spray" that you used on it?
It seems like it had some strong chemicals in it.
truflip is offline
Old 07-30-2007, 04:16 PM   #14 (permalink)
Subaru71's Avatar
dSLR Squad #32
yea you got a point there.
Also to the OP, you can go to hondapartsdeals.com and just buy a new plastic piece and put it in, i dont think its too expensive.
Subaru71 is offline
Old 07-30-2007, 04:31 PM   #15 (permalink)
lmfdjtiko's Avatar
Tiko
i tried so many different ways to clean it, it goes off and appeal 5 sec later...
any1 know where to buy that piece of plastic? can you give me a direct link? thx..how can change that part... looks really hard...
and.. so you think the dealership wont fix it?
i have no idea what kinda of chemical i used on it... i just remember , invisible glass and ... some kinda turtle spray for leather/rubber.
if this is happening to me,.. it gotta happen to at least 1 of you or your friend, help me -.- or am i the only stupid/unlucky 1 here
i couldn't sleep lastnight... =( lol
Old 07-30-2007, 04:35 PM   #16 (permalink)
Did you try vinegar and water? I know it's great and very safe for removing waterspots on the exterior.
Monty is offline
Old 07-30-2007, 05:20 PM   #17 (permalink)
inyong1988's Avatar
Junction Produce
hairspray maybe. hhaha
Old 07-30-2007, 05:24 PM   #18 (permalink)
japspecjohn's Avatar
John
leather or rubber? the cluster is made out of neither durrr...that stinks though
japspecjohn is offline
Old 07-30-2007, 06:15 PM   #19 (permalink)
truflip's Avatar
Well it shouldn't be anything abrasive if its for leather and rubber.
Try mixing alcohol with some water, and wipe it. Vinegar stinks, dilute some and try that too.
Changing that cover will require good amount of work. Sure the part is cheap, but it may be troublesome doing the labour depending on your experience.
truflip is offline
Old 07-31-2007, 02:39 AM   #20 (permalink)
lmfdjtiko's Avatar
Tiko
i tried alcohol, i tried viniger ,it kinda dissapear and then more appeal... sh111tt... going to dealership at Wednesday i hope. there is so much that it almost cover the whole thing and i could see the RPM ...lol .. well .. kinda...
HELP~!!! just installed HIDs and not turning on.... LadyEmily Lighting, H.I.D.'s, & Neon 21 03-26-2007 09:09 PM
XM is pissing me off Eric'sFG2 Water Cooler 20 12-09-2006 09:59 AM
dealer pissing me off - brake noise after B maintenance NoMoreHonda Mechanical Problems & Technical Chat 11 10-23-2006 09:15 AM
Exhaust system setup!?! HELP~ taejinah Bolt-Ons And All-Motor 5 07-28-2006 01:14 AM
