07 si top speed
hi im new the 8th and just got a nhbp civic si coupe and was just wanting to know what the actual top speed is. ive been reading here a lot and there are various speeds people have reached and dont know what it is for bone stock si's. i've read 157, 122, 140,145 i'm confused. has anyone just went and did a top speed run until it didnt go any faster and if so what was the speed? are the 06's faster than the 07's? do the 07's have a governor? any info is much appreciated. thanks
#10 (permalink) | |
#12 (permalink) | |
not so sure about if it voids the warranty havent checked but... what it does is: (taken from hondata.com) if you wanted the highlights i bolded them The K20Z3-06Si reflash lowers the VTEC point to 4500 rpm, advances the cam angle and raises the rev limit to 8600 rpm. We have implemented a VTEC window from 4500rpm to 5800 rpm. * Below 4500 rpm the K20Z3 is always on the low cam * Above 5800 rpm the K20Z3 is always on the high cam * Between 4500 rpm and 5800 rpm the K20Z3 is on the low cam at part throttle switching to the high cam at full throttle. This one reflash will work well with a variety of aftermarket performance parts. It will work well with: * An intake * Cat-backs (as long as they are less restrictive than stock) * A race header * * A combination of intake and race header You must have a minimum of an intake or header (to use without choking) hope this helps
#15 (permalink) | |
to the 6th power. heh
#16 (permalink) |
the 06's arent limited. its just that 6th gear is so crappy that the car just cant pull through the wind resistance. Temple of Vtec posted a vid of a 06 si on the dyno with the camera showing 157 mph on the speedo and thats what it will do given theres no wind resistence.
#17 (permalink) |
Stock(reflash takes away governer)
06=157 07=135 Its been proven, why is the 07 limited I dont know http://www.8thcivic.com/forums/showt...ight=top+speed It doesnt matter though the reflash takes off the governer and Im pretty sure most of us are getting a reflash or aftermarket tuning sometime 07 dude= why is my SI speed limited? 06 Dude= http://videos.streetfire.net/video/7...BCD755FE0F.htm Last edited by Skylinegtr06; 07-29-2007 at 10:25 PM. |
| Dyno top speed video - electronically limited and 9700 rpm | NiD4SPD | Civic SI | 90 | 10-18-2007 01:06 PM |
| GenPets | Kakashi | Water Cooler | 8 | 01-30-2007 10:14 AM |
| Speeding Tickets | RealDeal | Dealership Experience | 64 | 01-04-2007 01:11 PM |
