Old 07-25-2007, 11:52 PM   #1 (permalink)
Terrible grinding noise while reversing
I just got my '07 civic si sedan today and i've noticed that while reversing, it makes this really ugly grinding/buzzing kinda noise on top of the engine noise. does anybody have any idea what might be causing this? =/
erisha is offline   Reply With Quote
Old 07-25-2007, 11:54 PM   #2 (permalink)
nayilsi's Avatar
i dont know what grinds sounds like.... but yes I do have sum weird ass sound while reversing.... its natural
congrats.... what color.... IL KILL U IF ITS NHBP
nayilsi is online now   Reply With Quote
Old 07-26-2007, 12:03 AM   #3 (permalink)
Si_Chick's Avatar
E-bitch
I doubt it's grinding you're hearing... it's normal for their to be a sound, kind of like a "buzzing" when you're in reverse.
Old 07-26-2007, 12:50 AM   #4 (permalink)
-Sylver-'s Avatar
Pimp D
A high pitched Wind noise? Thats a honda reversing for ya
-Sylver- is offline   Reply With Quote
Old 07-26-2007, 01:04 AM   #5 (permalink)
Subaru71's Avatar
dSLR Squad #32
yep its normal on hondas..
Subaru71 is offline   Reply With Quote
Old 07-26-2007, 01:10 AM   #6 (permalink)
20civic07's Avatar
somtimes while going into reverse and then pushing clutch into neutral then shifting to first gear ( while the car is still slightly going backwards ) my gears will grind....
20civic07 is offline   Reply With Quote
Old 07-26-2007, 01:16 AM   #7 (permalink)
Tastycakes's Avatar
The reverse gear is straight cut (vs angled cut like the forward gears for strength) so it make a whining noise when moving. (probably done on purpose, when anyone hears that sound they know a car is backing up) It also gets no synchros so you cant be moving back or forward at all when putting it into R.
Tastycakes is online now   Reply With Quote
Old 07-26-2007, 06:13 AM   #8 (permalink)
Garrett
^word. Its a spur gear rather than a helical gear. You'll hear a bad noise if you go in R while moving forward, don't do that. It's normal to hear a mechanical/non-grinding noise while in R and moving backwards just because the whole tooth is making contact at the same time.
garrnew is offline   Reply With Quote
Old 07-26-2007, 06:54 AM   #9 (permalink)
Yeah... that's me
FBP FG2's Avatar
I have an 06 si and the only times I ever hear a grinding sound is when the car is rolling back because of the slope on the driveway and I try to shift into reverse while it's still moving. Are you moving when your shifting into reverse?
FBP FG2 is offline   Reply With Quote
Old 07-26-2007, 06:56 AM   #10 (permalink)
1stk20z3's Avatar
Casey
i thought it was a reverse supercharger. LOL!
as for a grind just dont try to put it in reverse while you are rolling backwars it'll grind like crazy.
1stk20z3 is offline   Reply With Quote
Old 07-26-2007, 10:54 AM   #11 (permalink)
that brings up an interesting question, what do you do if you're on a driveway or other hill and need to put it in R? do you just put it in neutral and let it roll back?
dnbsi is offline   Reply With Quote
Old 07-26-2007, 04:58 PM   #12 (permalink)
Subaru71's Avatar
dSLR Squad #32
You make sure u hold the brake pedal while u shift into R
the car must not move while you shift into R because the gear is not syncronized (as said above)
Old 07-26-2007, 05:04 PM   #13 (permalink)
Glowaholic
Swank's Avatar
And if it's a bit hard to get it in reverse, toss it in any other gear first then throw it in reverse, should slide in easy.
Swank is offline   Reply With Quote
Old 07-27-2007, 12:20 AM   #14 (permalink)
is it bad to shift out of reverse while moving?
Veazy is offline   Reply With Quote
Old 07-27-2007, 01:38 AM   #15 (permalink)
^^^I would like to know this also. I do this almost all the time.
mhuynh is offline   Reply With Quote
Old 07-27-2007, 05:19 AM   #16 (permalink)
Tastycakes's Avatar
I wouldnt think itd be bad to shift out of reverse while moving. As long as it pulls out of gear easy.
Old 07-27-2007, 08:51 AM   #17 (permalink)
Garrett
I don't think so. I wouldn't do that going in reverse too fast, try to stop as much as possible since your clutch has to change direction then get the wheels up to speed.
Old 07-27-2007, 09:35 AM   #18 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
It would be sweet if 1-4 had this too. (5+6 wouldn't for highway)
Old 07-27-2007, 09:42 AM   #19 (permalink)
Agnt004's Avatar
Greg
More info on gears:
http://science.howstuffworks.com/gear3.htm
Agnt004 is offline   Reply With Quote
Old 07-27-2007, 10:35 AM   #20 (permalink)
CZ-75's Avatar
Brian
The sound of straight cut gears in action:
http://vids.myspace.com/index.cfm?fu...eoID=865343956
CZ-75 is offline   Reply With Quote
Grinding noise when turing left. ajrich Mechanical Problems & Technical Chat 13 04-27-2007 12:12 PM
grinding like noise RedHonDa Mechanical Problems & Technical Chat 4 04-22-2007 02:28 AM
grinding noise from megan downpipe? 06civictx Mechanical Problems & Technical Chat 5 03-12-2007 12:23 AM
07 Problems todsulli Mechanical Problems & Technical Chat 33 01-29-2007 10:38 AM
Spinning noise gradually increasing as RPM goes up joonoo Mechanical Problems & Technical Chat 0 09-03-2006 01:54 AM
