1st gear questions?
Does letting the clutch grip and move the car a lil before you apply gas cause damage to your clutch? Is this slipping the clutch?
I learned to drive stick by letting the clutch grip first and then slowly apply gas as i release the clutch. My launches are very smooth but am i riding my clutch? |
well maybe i can help not 100%sure im rite. any way i would say try to apply gas while letting out the clutch, not letting out the clutch fast enough while applying gas would be riding the clutch.
learning with this method, let the clutch grip first is good to learn when it will grab, once you got that down then add gas to the mix, and then try to master it, |
Anytime your foot is on the clutch, your riding it. Idealy, you want your foot on the clutch as alittle as possible while still making a smooth shift. The slower you depress and release the clutch, the more your wearing it down although starting on hills, etc require you to ride it more then on a flat surface.
#5 (permalink) | |
From what you described, it doesn't sound like you're riding the clutch. Riding the clutch would be if you're constantly on the clutch in every gear to make it feel smooth.
#6 (permalink) | |
| 1st gear shift question | 20civic07 | Mechanical Problems & Technical Chat | 6 | 05-30-2007 08:06 AM |
| Strange 1st gear issue | alexkcha | Civic Coupe And Sedan | 12 | 05-29-2007 10:47 AM |
| Memorial Day Thread | webby | Water Cooler | 31 | 05-28-2007 09:38 PM |
| 1st gear question | kamikaze84 | Garage | 7 | 03-20-2007 11:08 PM |
| 07 Problems | todsulli | Mechanical Problems & Technical Chat | 33 | 01-29-2007 10:38 AM |
