Old 06-11-2007, 11:31 AM   #1 (permalink)
Kedar
Exclamation do you engage reverse without using gas? Am I causing damage?
Since I started driving the si ive been engaging reverse on level ground without using the accelerator. Seems the computer injects just enough gas to keep it running stable and you just have to release the clutch slowly til its in gear and you're off.
Am I doing damage to my clutch or any other part? Would it be better if I gave it a little bit of gas?
y2kedar is offline   Reply With Quote
Old 06-11-2007, 11:50 AM   #2 (permalink)
forty.water's Avatar
I dont think it is hurting anything...if so, i am doing the same thing...
forty.water is offline   Reply With Quote
Old 06-11-2007, 11:52 AM   #3 (permalink)
Skyline4life's Avatar
Evan
All your doing is pulling the clutch out until it catches..from what i under stand it wont hurt if your like doing it here and there, but after awhile you'll start to burn out your clutch. Just give it a little gas, and once the car gets going backwards put the clutch in, and you can roll out..I do that when pulling out of my garage.
Skyline4life is offline   Reply With Quote
Old 06-11-2007, 11:59 AM   #4 (permalink)
Scrodums
Yodums's Avatar
HIRO - ಠ_ಠ
It won't damage anything significantly. There's less clutch slippage without the accelerator, but the differences are minimal.
Old 06-11-2007, 06:07 PM   #5 (permalink)
aki
aki's Avatar
Resident Si Sedan Hater
The only possible damage would be from the engine stuttering, but you'd have to have it stuttering for a long time for that to happen. I don't apply gas much, if it all when reversing.
aki is offline   Reply With Quote
Old 06-11-2007, 06:14 PM   #6 (permalink)
LoverOfCivics's Avatar
Javier
hmmm, i just tap the gas pedal one good time and roll back
LoverOfCivics is offline   Reply With Quote
Old 06-11-2007, 06:44 PM   #7 (permalink)
RAWRRR
jpik2003's Avatar
Jack
Same.
jpik2003 is offline   Reply With Quote
Help Lower Gas Prices.. NOT a "dont buy on a certain day" idea... FG Two Water Cooler 26 11-12-2007 01:25 PM
Do you use the gas when going into reverse from a stop? y2kedar Civic SI 19 06-06-2007 12:46 PM
Gas Spike Because of Hurricane Rita - $5.00 a Gallon webby Water Cooler 21 12-31-2006 01:30 AM
Can I Damage my Car by Filling the Gas Tank TOO Full? Avenger Mechanical Problems & Technical Chat 16 11-20-2006 02:14 PM
Exxon Gas Boycott - urges towns to do the same webby Water Cooler 25 08-01-2006 10:22 AM
