Old 05-22-2007, 11:05 PM   #1 (permalink)
Installed Injen CAI today..... wow
So, today I installed the Injen CAI on my Si sedan. I love the way you can't hear it if you are just driving normally... however, when you get on it and enter into vtec, HOLY COW... it sounds amazing! I didn't tell my wife that I installed an intake, and then took her for a drive to the store. When I merged onto the highway, she kind of looked at the car like "why the hell is the car so loud", but she didn't say anything... hee, hee, hee...
I can def. tell a difference with throttle response. Perhaps a little more HP too.
The install was pretty straight forward, however I'll need to go to home depot tomorrow to get replacement clamps for two of the hoses. The stock clamps were too small. I didn't have to cut anything like the directions said. I did take off the bumper and the wheel well, then I installed the intake. It worked fine for me without cutting a hole in the wheel well. I'll post some clips of it soon.
Mad props to Injen for creating a nice fitting product. I'm glad I chose the cai over the sri.
jimhoff29 is offline   Reply With Quote
Old 05-22-2007, 11:08 PM   #2 (permalink)
inyong1988's Avatar
BIPPU
congrats
inyong1988 is online now   Reply With Quote
Old 05-22-2007, 11:09 PM   #3 (permalink)
BubzSI's Avatar
Travis
I love the CAI but I dont wanna cut my wheel well to install it..
BubzSI is offline   Reply With Quote
Old 05-23-2007, 09:28 AM   #4 (permalink)
Um, you don't have to. Just take it off first, install the intake and then put it back on. I didn't have to cut anything. It fit fine.
Old 05-23-2007, 09:39 AM   #5 (permalink)
07si sedan's Avatar
congrats
how long did the install take?
07si sedan is offline   Reply With Quote
Old 05-23-2007, 09:50 AM   #6 (permalink)
Originally Posted by 07si sedan
congrats
about 2 hours. I did everything myself though. When you take the bumper off, keep the front grille attached to the bumper. Just take out the two allen screws and that will come off with the bumper. Keep the screws and plastic clip-insert-things that hold everything together in a safe place. You don't want to lose any. Be careful with them too, they are easy to bend/break. After the install, let the engine idol for about 10 minutes before you put everything back together, just to make sure that a CEL doesn't come on. Also, you might have to go to a hardware store and get new hose clamps. The stock ones don't fit on the new hoses. Don't worry about any leaking coolant from the throttle body. Some will leak out (about 8oz or so), but it will stop. If you put on the new hose immediately after the fluid starts leaking, it will stop.
The sound rocks, but only after you go WOT around 4k rpm's. I like it that way b/c when cruising, it sounds stock. The vtec kick isn't as noticeable but you can tell that the car pulls a little more in the high end rpms.
Old 05-23-2007, 09:57 AM   #7 (permalink)
Oh, and you will have to take out the entire battery assembly. Even the little piece of metal that holds the wiring harness onto the metal battery base has to come off (with the 2 small screws on the left hand side), although you don't actually remove it from the wiring harness. It makes threading the intake tube to the throttle body through the engine bay easier. When you put the intake in, put it in from the bottom up (wheel well up), not from the top down. TAKE OFF THE WHEEL WELL before the install!!! If you do, you won't have to cut anything. Just install the intake, then put the wheel well/bumper back on. It will fit.... trust me.
Oh, and you could insert a small body into the new gaping hole that you have in the engine bay now that the stock intake has been removed.
Old 05-23-2007, 10:03 AM   #8 (permalink)
simplicated1979's Avatar
shaba
'awesome'
simplicated1979 is offline   Reply With Quote
Old 05-23-2007, 10:09 AM   #9 (permalink)
07si sedan's Avatar
good tips thanks
and about the small body thing? scary
Old 05-23-2007, 08:58 PM   #10 (permalink)
hopefully you can have pics up soon. really interested in seeing how it is without cutting the wheel well. cause i'm planning on ordering a injen cai also and i don't want to cut anything.
crazi3 is offline   Reply With Quote
Old 05-24-2007, 09:44 AM   #11 (permalink)
I'll post some pics hopefully this weekend.
Old 05-24-2007, 02:15 PM   #12 (permalink)
is stuck at work...
SiliconX's Avatar
Eric
If you didn't cut the wheelwell, then you must have a pretty decent-sized bulge in it.
SiliconX is offline   Reply With Quote
Old 05-24-2007, 02:18 PM   #13 (permalink)
Nicholas's Avatar
buddy of mine didnt cut his when he put his in and he has no bulge at all...
Nicholas is offline   Reply With Quote
Old 05-24-2007, 02:35 PM   #14 (permalink)
I don't have a bulge in it. I'll take pics tonight and post them. After the install, I just put the wheel well back in and it snapped in without any force applied.
Old 05-25-2007, 11:19 AM   #15 (permalink)
Here are some pics I took last night
CAI installed without cutting wheel well
diagram of where new hoses go
TWM shifter cable bushings
Old 06-08-2007, 12:41 AM   #16 (permalink)
Sexy6Speed's Avatar
Alyssa
ya i installed an AEM cai on my si and its amazing, im sure very similar to the injen. i had a sri on my 02 and never really noticed much, but when i put this on the si it screams...actually more like growls but u get what i mean.
Sexy6Speed is offline   Reply With Quote
Old 06-08-2007, 02:00 AM   #17 (permalink)
b0yd07's Avatar
Michael
Just curious, do you get better or worse gas mileage?
b0yd07 is offline   Reply With Quote
Old 06-08-2007, 09:07 AM   #18 (permalink)
Don't know, haven't kept track of it. I'll let you know the next time I fill up.
Old 06-08-2007, 09:15 AM   #19 (permalink)
bluetroll's Avatar
NBP Si
mileage stays the same.... or it goes up because you end up vtec-ing a lot more often!
bluetroll is offline   Reply With Quote
Old 06-08-2007, 09:32 AM   #20 (permalink)
Nicholas's Avatar
pics dont work bump for pics that work
DIY: Injen CAI install on R18 (lots of pics) peliROJO Engine 88 09-29-2008 11:16 PM
Finally, an Injen CAI for my JDM R18 Civic pengful Bolt-Ons And All-Motor 17 04-14-2007 02:16 PM
Injen CAI Installed @ the track run Video CmakSI Bolt-Ons And All-Motor 12 03-08-2007 06:45 AM
Black Injen CAI installed Ryd1ZZ Bolt-Ons And All-Motor 5 12-11-2006 10:24 AM
INJEN CAI AVAILABLE whitecivicsi Bolt-Ons And All-Motor 47 07-09-2006 12:59 PM
