Old 04-08-2007, 08:27 PM   #1 (permalink)
OMFGPWND's Avatar
David
HFP Front Lip Problem.
I recently installed the HFP front lip on my sedan. I followed the instructions word for word, and everything came out looking good. However, I noticed when on the freeway, I hear a rattling sound coming from the front. Obviously I cant point out the exact area that it is coming from, as this only happens at 70+ mph. The one thing I did not use in the supplied hardware was the optional spacers, I felt no need for them. I know without being in the car its hard to say, but does anyone have ideas and or suggestions? Any would be greatly appreciated.
OMFGPWND is offline
Old 04-08-2007, 08:28 PM   #2 (permalink)
RAWRRR
jpik2003's Avatar
Jack
first time hearing of the front lip rattling. Are you positive its coming from the lip and not something else?
jpik2003 is offline
Old 04-08-2007, 08:30 PM   #3 (permalink)
OMFGPWND's Avatar
David
Im not positive, because its impossible to see while driving. Ive had it up on jacks and everything is tight. Maybe the grill???
OMFGPWND is offline
Old 04-08-2007, 08:42 PM   #4 (permalink)
Check the undercarriage trays. If you didn't get the little pop/clicker things (for lack of a better word, I have no ******* idea what they're called) installed correctly the lip will be mounted to the undercarriage tray but nothing else to keep them in place.
That's how it is on coupes at least, so I'm sure the sedan is the same. It sounds like one of them may not be secured so the whole thing is flapping around at speed.
RWatters is offline
Old 04-08-2007, 08:46 PM   #5 (permalink)
OMFGPWND's Avatar
David
Thanks, that sounds like a likely culprit. I know that there were long retainer clips, (thats the they're called :) )
and short ones too. I may have some switched around.
OMFGPWND is offline
Old 04-08-2007, 09:59 PM   #6 (permalink)
OMFGPWND's Avatar
David
Well, I just got done checking out all the clips, and the seem to be fine. Anyone else have thoughts?
OMFGPWND is offline
Old 04-08-2007, 10:11 PM   #7 (permalink)
Skylinegtr06's Avatar
edwyn(male)
SOmething could have went in the front lip, like a small rock or something
Skylinegtr06 is offline
Old 04-09-2007, 12:25 PM   #8 (permalink)
Well, if you only hear the rattle on the freeway, something's not secured down. I'm not sure which spacers you're talking about, but maybe try installing them? Also, is it a constant rattle?
p nut is offline
Old 04-09-2007, 02:38 PM   #9 (permalink)
Does any part of the undercarriage move freely when you push on it when you are underneath the car?
RWatters is offline
Old 04-09-2007, 03:15 PM   #10 (permalink)
MBK
simple solution: remove and sell lip.
MBK is offline
Old 04-09-2007, 06:04 PM   #11 (permalink)
CUPRA's Avatar
Nunya...
I presume the spacers came for a reason, possibly to create a gap between whatever is making the rattling noise, as they knew it rattles. I say install the spacer and see what happens...
CUPRA is offline
Old 04-09-2007, 06:20 PM   #12 (permalink)
Toys For TotsMember
samx109's Avatar
Sam
check your fender liners
samx109 is offline
Old 04-09-2007, 07:33 PM   #13 (permalink)
BubzSI's Avatar
Travis
^^ ya that
BubzSI is offline
Dumb Laws C2i0v0i1c Water Cooler 56 03-19-2008 03:02 PM
So I just bought the HFP front lip..need help fast.... dsg2003gt Civic SI 9 03-26-2007 02:36 PM
front HFP lip first or fogs first? Pukuyo Inside and Out 11 11-22-2006 12:50 AM
How do I install the HPF front lip for the 06 Si CIVI7 Civic SI 2 09-18-2006 02:32 PM
